Question about Kenmore Refrigerators
Ice maker water line coupler
I'm taking off the doors to my Kenmore ref/freezer and can't figure out how to take the water line coupler apart without breaking it. It's a plastic thing with inserts on both ends that apparently lock the tubing in place. I've tried prying off the plastic bushings but they seem very fragile and I don't want to break them.
Its a little late, however, this is easy. Your coupler should have two red ends. They don't spread apart. Instead push them together, notice each one moves about 1/16 of an inch. This releases a tension ring holding the lines together. When pressed firmly together the lines slide right out. I know, I tried pulling and instead broke the fitting. I have two Kenmore fridges 5 years apart and they both are the same.
Posted on Nov 29, 2010
Where do I direct the hot air from an hair dryer to thaw out the water line in my hotpoint side by side refrigerator ?
Hotpoint ref.
made by GE
There is 2 different place they freeze up inside door water line for cold water dispenser & water feed to ice maker.
for cold water disp. Water line depends on model # will start at bottom of door loop over the disp. control and back down from top of control to cup area to defrost this line best way is to shut down ref and leave door on freezer open can take up to 12 hours.
taking door apart is a major project.
If its your ice maker fill tube easy fix turn water supply off.
on back of ref. there is a water line going up to the top of freezer
this tube will pull out from back the whole fill tube will come out
take to sink thaw with warm water replace tube You may need some caulk to seal area tube meet ref.
Mar 24, 2015 | Hotpoint Refrigerators
Water won't dispense
The part of the=> 2188542 Water Inlet Valve may be defective while you may be getting ice from the ice maker side of the=> 2188542 Water Inlet Valve Let me know iof you have questions, Thanks Sea Breeze Questioins?38124827-761f-4fe9-a92b-e27c07b1020b.jpg
Jan 06, 2014 | Kenmore 57029 Side by Side Refrigerator
Kenmore side by side frig freezer .ice maker won't make ice and red light inside next to ice maker is blinking
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Sep 15, 2011 | Kenmore Refrigerators
Free standing kenmore ice maker ---water running sound frequently--any suggestions?
NOTE: This
Leo Ponder
imufo2
Sep 14, 2011 | Kenmore 51lb. Clear Ice Maker
Our side by side refrigerator/freezer's ice maker stopped producing ice. We still can get water through the door, but no water is going into the ice maker. We checked the sensor to make sure it was...
NOTE: This
Leo Ponder
imufo2
Sep 12, 2011 | Kenmore Refrigerators
I have a Sears Kenmore model #363.9522611 with a ice maker and water in the door. Purchase April 1992. The water does not come out the door and the ice maker is not making ice.
NOTE: This
First I would check the fan in the freezer. Listen to see if it is running
http://www.applianceaid.com/procedures.html
I'm
Leo Ponder
imufo2
Aug 16, 2011 | Kenmore Refrigerators
Kenmore Coldspot/ Acceler-Ice, the ice maker won't work the machine will dispense water for us to drink but not fill up ice- maker could it be the filter and if so where exactly is the filter? Model#...
If its leaking same part needs replaced.The water valve at the bottom rear of fridge
.I'm including my article on Refrigerator Repair for your help and convenience.;
Leo Ponder
imufo2
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 30, 2011 | Kenmore Refrigerators
NOT MAKING ICE JUST HOOKED UP WATER LINE AND TURNED ON TWO HOURS AGO
if you have just purchased the ref. and hooked it up it will take 24 hours for the ref. to get to correct temp.Plus the ice maker wont start to work until the freezer temp gets to 15 degrees.if the ref. has been in use then check the power button on the ice maker itself and make sure the power is on.
Nov 03, 2010 | LG LFC22740 Bottom Freezer French Door...
Refrigerator leak
the water fill tube for i/m is on the back of ref. the tube you have is to the water dispenser. look in freezer floor, is it full of ice? if so, remove all ice and clear drain hole for evap. if not, reassemble what you took apart and inspect tube under ref. while someone runs water dispenser. find leak and repair.
May 20, 2008 | Maytag MZD2766GES Side by Side...
Kenmore Refrigerator stopped dispensing water
Look up through the ice despencer on the front door of the freezer. Is the flapper door open? If so it needs to be fixed. If its not then try leaving the freezer door open for 3+ hours to defrost the frozen line in the door. If that doesnt work, the water valve must be changed.(located behind fridge, take off back cord board panel at bottom, the valve is blue)... GOODLUCK!
Dec 31, 2007 | Refrigerators
Refrigerators Logo
628 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
