Question about Trust WB-3600R Web Cam
Code 10 N?zov probl?movej udalosti: PnPDeviceProblemCode Architekt?ra: x86 Identifik?cia hardv?ru: USB\VID_0C45&PID_627F&REV_0101 Identifik?tor GUID triedy inštal?cie: {6bdd1fc6-810f-11d0-bec7-08002be2092f} K?d probl?mu PnP: 0000000A N?zov ovl?dača: snp2sxp.sys Verzia ovl?dača: 5.9.0.0 D?tum vytvorenia ovl?dača: 01-26-2007 Verzia OS: 6.0.6001.2.1.0.768.2 Identifik?cia miestneho nastavenia: 1051
Pnpdeviceproblemcode 19
I would manually un-install, and then reboot so the system could re-install. Also do a complete system virus scan, just to be sure
that a bug isn't operating.
Sep 17, 2012 | Dell Latitude D630 Laptop Computer PC...
Tip
USB FLASHDISK/ Pen Drive WRITE PROTECT, CAN'T FORMAT, SIZE 0, ERROR SOLUTION
Dear Guys, If you find the problem same as the contents above. Please kindly following this step :
  1. Find VID (Id Vendor) and PID (Id Product) of your type Usb Flashdisk/ Pen Drive, Use This Software USB VIEW, see this picture to find :
2. after you already find your VID and PID, you can enter this website to find correct software to use. http://flashboot.ru/iflash.html , maybe this web use Rusian Languange but no need to worry you just fill up your VID or PID at search Box, see this picture
Good Luck, Or If you need my support, i will do.....
on Mar 22, 2010 | Computers & Internet
MY PEN DRIVE IS DETECTED BUT SHOWING THE OPTION '' PLEASE INSERT DISK IN DRIVE ''
Following this step :
1. you just need to see your ID Product (PID) and ID Vendor (VID), you can use this software to find your PID and VID, USB VIEW, for reference see this picturefd97e60.jpg
after already found the PID and VID, take only for digit behind X.
2. visit this web http://flashboot.ru/iflash.html to find correct software for your flashdisk, just filled up at box like search.
3. or after you know the VID and PID you can contact me to find correct software for your pen drive type.
Good Luck
Mar 21, 2010 | Electronics - Others
Problem Event Name: PnPDeviceProblemCode Architecture: x86 Hardware Id: PCIVEN_8086&DEV_2A42&SUBSYS_01761025&REV_07 Setup class GUID: {4d36e968-e325-11ce-bfc1-08002be10318} PnP problem...
Problem signature:
Architecture: x86
Hardware Id: USB\VID_0421&PID_0355&REV_0490
Setup class GUID: {4f919108-4adf-11d5-882d-00b0d02fe381}
PnP problem code: 00000027
Driver name: ccdcmb.sys
Driver version: 7.1.32.68
Driver date: 05-18-2011
OS Version: 6.0.6001.2.1.0.256.0
Locale ID: 1033
Oct 02, 2009 | Acer Computers & Internet
Description: I am trying to get into my old laptop hard drive
It could be because you're not running the same os the picture files were created with, so you can't read them. I'd try hooking up to an xp system and see if you don't have better luck. That's what the x86 architecture problem code is referring to: XP.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 30, 2009 | Dell Studio 1537 Laptop Computer PC...
Code 10 error
okay some ppl have been having the same problem with that device cause the PID number isn't the same
First find out what VID and PID Numbers you have
Step 1 go to device manager locate the "Linksys wireless G usb network adapter" (the name in quotes may be different for you but find your card which should have a similar name)
Step 2 right click on it and go to properties
Step 3 go to details tab
Step 4 either write the VID and PID numbers down or leave that window open to come back to later
Then you find the INF file and open in notepad (the one you downloaded 1xxx for vista)
Lastly in the INF file you locate the section under
; Added support for Belkin and Linksys
And place your VID and PID numbers in the appropriate spot
;Belkin F5D7051
%F5D7051_DeviceDesc% = RNDIS, USBVID_1799&PID_7051
%F5D7051_DeviceDesc% = RNDIS, USBVID_050D&PID_7051
then save the file, re install the driver and restart your PC...
Good luck, let me know
Apr 23, 2009 | Computers & Internet
Trust WB-3600R Web Cam Logo
119 people viewed this question
Top Trust Computers & Internet Experts
micky dee
Computer Links
Robin Hill
Robin Hill
Are you a Trust Computer and Internet Expert? Answer questions, earn points and help others
