Question about Kenmore Washing Machines
Kenmore top loader, water won't drain
It seems to be working fine through the wash cycle but wont drain water after rinse cycle and stops completely!!! no noise nothing it just stops completely while the water is still there.I took it apart thinking it must be bad motor couplings(two plastic three pronged pieces with a rubber bushing connecting the two) but the couplings look fine nothing is broken! should I still change the couplings or do I need to look for something else??? Please advice.Thx.Sam.
  • 347 Answers
Sounds like the pump is out. If you are certified to work with electrical, you can check power to the pump .May also be in the timer assembly too which can also be checked for operation.
Posted on Jun 13, 2017
SOURCE: I also need the answer...
where is the lint trap located
Posted on Apr 07, 2008
SOURCE: drain but clicks instead...agitates and drains fine 110.92195110
I'm having the same issue with my hoover family 1300. Any ideas on that? would it be the same? mine is a front loader.
Posted on Jan 23, 2009
  • 640 Answers
SOURCE: washer wont spin
the the motor coupling ..unit want wash or spin,,,if you would lik to try your hand at replacing it lety me know,,onthejob
Posted on Feb 01, 2009
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
  • 121 Answers
SOURCE: Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
Posted on May 02, 2009
My Kenmore 500 top loading washing machine wont work right. sometimes it will work and other times it wont. I will put a load in it and sometimes when it hits the rinse cycle it seems like it gets stuck...
for the top loading washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.and the unit top load have drain pump you must be up the drain hose up to 90cm from floor lever to make the water lever is make in normal,the water automatically goes out by drain pump.
and for unbalance most of all top loader have problem in unbalance, the main reason is overload or the type of cloth you wash.
Nov 02, 2013 | Kenmore 24032\24036 Top Load Washer
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/
Sep 01, 2009 | Kenmore Washing Machines
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Kenmore washer quit working
it may be waiting for a faulty heater to kick in. try it on a cold water wash, no heat and see if it continues the full wash. if it does not then it may have a faulty timer.
Mar 16, 2009 | Washing Machines
Dec 06, 2007 | Washing Machines
Washing Machines Logo
41 people viewed this question
Sal De
 Brian Main
Brian Main
