Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
Water is dripping from the center of the temp control on my top freezer model #363.9728610 ref.
  • kabar44 Apr 18, 2009
    I took the drain connection loose on the back of the ref. and unstopped it and cleaned the gunk from it and now waiting to see if it solved thr problem. Thanks
  • 15,935 Answers
This is a condensation issue.
Please check the seal for the refrigerator that it is making contact all the way around and that it is free of debris.
A good way to check is put a flashlight in it at night - and turn off the lights and shut the door.
If you can see light - that is where the air is coming in, and keeping the humidity level high in the box.
Alternately - the condensate drip tube may be clogged... and now overflowing.
Check your owners manual for your particular model to see how to clean the tube.
Thanks for using FixYa!!
Posted on Apr 18, 2009
16cuft top freezer and bottom refrigerator. Condenser is in the back. Both ref. and freezer are freezing. how to fix it? 2nd whirlpool refrigerator 16cuft freezer is fine but ref. is not cold?
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Sep 15, 2011 | Whirlpool ET1MHKXM Top Freezer...
Ice on top of inside refrigerator and items in back top shelf are frozen turned down temp to 3 and it melted , put back up to 5 and new ice formed on top of refrrigerator
.I'm including my article on Refrigerator Repair for your help and convenience.;
Leo Ponder
imufo2
Aug 28, 2011 | Roper RT14DKX Top Freezer Refrigerator
Refrig freezing food and roof of rig dripping water and freezing
Leo Ponder
imufo2
Aug 25, 2011 | Refrigerators
Have a Whirlpool refrigerator/top freezer model ET1CHMXKT06. Water from freezer drips into refrigerator. How do I stop this?
Check drain in the freezer which probably runs through the Ref. Pour water in Drain in back of
freezer and see if it drains. some may be getting inside ref.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 10, 2011 | Whirlpool Refrigerators
Water is dripping from the top of refrig from what appears to be a control unit of some type.. The freezer and icemaker work.
If the water is dripping into the ref. from the freezser chances are you have a clogged drain where the water runs out of when the machine goes into defrost. Take everything out of the freezer and look at the back of the machine and see if you have ice built up. The vents that ru from the freezer to the ref. are loacted in the middle and chances are ice has gotten into them and is thawing and running into the fridge. Unplug the machine, take the back freezer wall off and clear the ice away. I use a screwdriver to tap into the drain hole to clear the ice but you can use hot water as well. Once you see water draining properly down the hole, put it back together and your good to go.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Nov 02, 2010 | KitchenAid KTRP22EM Top Freezer...
Fog and dew dripping in ref
It may be high humidity of the air outside of the refrigerator or you are storing highly humid things inside along with the settings of the fridge.
Jun 07, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is leaking into the refrigerator.
most likely the defrost drain in the freezer is frozen shut. take out the back wall of the freezer and check under the evaporator. if its a whirlpool built kenmore you may find a sheet of ice on the floor of the freezer under the plastic floor/tray. if this is the case, remove ice, thaw drain with a turkey baster and hot water. wrap a piece of thicker copper wire (pencil lead size approx), around the defrost heater and push into drain about 2-3 inches, making sure it doesn't touch the sides of the drain, this will keep the drain from freezing shut. if its a frigidaire built remove the control from the inside of the ref and silicone around the opening where the water drains from the freezer into the drain cup that is built into the back of the control panel. that will keep the water from running along the ceiling of the ref and dripping. hope this helps. if not put model number with problem.
Apr 19, 2009 | Kenmore Refrigerators
WATER DRIPPING FROM TOP OF REFRIGS MAIN COMPARTMENT
The drain is clogged.
This water should be going down the drain to a pan under the ref.
The drain starts under the cooling coils in the freezer but can be clogged anywhere. Some models will have access in the main ref in the top - rear, a small cover can be removed. Some will have access on the back of the ref. you can see the drain tube and an elbow where it come out of the ref. remove the elbow and check for clogs.
Dec 11, 2008 | Whirlpool Refrigerators
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
