Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Husqvarna yth20S42 partial loss of drive power can tran oil be checked. The tractor has 170hrs operating time.How can you tell if its the belt or the trans. thanx Rod.
  • rj_wangler Apr 18, 2009
    thanks buster banks turns out it was just a build up of dead grass
    and dirt. The linkage to the transmision couldn't move all the way.
    thanks for your input rj wangler.
  • 74 Answers
I would thing its the belt I have same mower u can check rear end by removing a check plug also sure that u can adjust the belt try that 1st
Posted on Apr 18, 2009
Tractor husqvarna yta 18542. Sometimes it won,t go up a hill. It just stops. It,s only 6 months old. What are the 2 adjustment screws on the tranny. Do they have something to do with belt tension ?
There is no adjustments for the belt on the gearbox,there will a brake adjuster on the side, if the brake is badly adjusted it will increase the gearbox oil temperature resulting in loss of drive, slacken the 1/2 nut to reduce brake friction.
Dec 01, 2017 | Husqvarna Garden
When a husqvarna lth 2142d ride on lawnmower losses speed what is problem
21 hp briggs big motor
if not a drive belt or gearbox issue
is the Governor set properly
rider mower serviced regularly
carby jets adjusted
no stale fuel clean fuel filter
valve clearance to spec
newish plug
not burning oil
Oct 24, 2016 | Husqvarna Garden
Husqvarna 4623 zero turn mower will not move
Maintanance - How to purge Hydraulic drive system Published 01/13/2010 11:56 AM ' Updated 06/02/2015 02:52 PM
How do I purge the hydraulic system?
Hydrostatic transmissions use oil, under pressure, to provide movement for the tractor. The fluid is pressurized with a pump inside the transmission. If any air is in the fluid, the pump will try to pressurize air. This condition is known as cavitation, and is detrimental to the pump since it allows the pump top operate dry. When the pump cavitates it is not pressurizing any fluid, so the transmission is not able to provide the movement needed.
If your mower is new, or has been stored for a long period (longer than 2 months) the transmission needs to be purged before use. Also, if you experience loss of drive, or slower response, then the transmission should be purged first.
The following procedure will remove trapped air inside the transmission(s).
IMPORTANT: SHOULD YOUR TRANSMISSION REQUIRE REMOVAL FOR SERVICE OR REPLACEMENT, IT SHOULD BE PURGED AFTER REINSTALLATION BEFORE OPERATING THE TRACTOR.
Step 1- Place the rear of the mower safely onto jackstands on a level surface with engine off and parking brake set.
Step 2- Disengage transmission by placing freewheel control, located at the back of the frame, in the freewheeling position.
2a- Mowers with seperate pumps and wheel motors the freewheel is activated by turnign the bypass valves, one on each pump, two full turns.
The oil resevoir needs to be filled to the specifications listed in the owners manual before starting the purge procedure.
Step 3- Sitting in the operators seat(riders), start engine. After the engine is running, move throttle control to slow position. With motion control levers in neutral (N) position, slowly disengage clutch/brake pedal.
Step 4-Move motion control levers to full forward position and hold for five (5) seconds. Move levers to full reverse position and hold for five (5) seconds. Repeat this procedure three (3) times.
NOTE: During this procedure there may be some movement of the drive wheels, but they are not under load. The air is being removed from hydraulic drive system.
Step 5-Move motion control levers to neutral (N) position. Shutoff engine and set parking brake. Check and add oil as needed for units with an oil resevoir.
Step 6-Engage transmission by placing freewheel control into driving position, or by closing the bypass valves on the pumps.
Step 7-Sitting in the operators seat, start engine. After the engine is running, move throttle control to full speed. With motion control levers in neutral (N) position, slowly disengage clutch/brake pedal.
Step 8-Slowly move motion control levers forward, after the tractor moves approximately five (5) feet, slowly move motion control levers to reverse position.
After the mower moves approximately five (5) feet return the motion control levers to the neutral (N) position. Repeat this procedure with the motion control levers three (3) times.
Step 9-Your mower is now purged and now ready for normal operation.For further information or assistance, we recommend contacting your lo
Aug 06, 2016 | Husqvarna Garden
Why does my husqvarna running slow
Try changing the drive belt, even a slight slip on the belt will appear as a loss of power.
Aug 11, 2014 | Husqvarna Garden
New tractor power loss on a grade, deos not develop full speed
Hello Joe
If you have an automatic or hydrostatic transmission then you have a lemon, which means once the oil heats up in your transmission it thins out and clutchs and swash plate have no grip on the drive system which is hydraulic pressure needed to hold on the shaft and axles this happens all inside the transmission you cant see it but you can tell when going up slight hills and when you have the blades engaged it crawls like a turtle get you warranty out Joe..... dont touch anything that may void your warranty..... just call service department they will send service man out to your home even after that keep a good eye on your tractor since its still under waranty for further problems.
Joe your 20 year old craftsman had a better built ****** by sears and you probably had a 6 speed or five speed even hydostatics were good too,they dont have much problems except belt slipping its an easy fix this new tractor u need service man right away.
Joe
Oct 08, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Hydrostatic on husqvarna cth 180 xp losing power
Check the drive belt. This belt runs from the engine to the transaxle. Look for abnormal wear and if the sides of the belt look glazed/shiny. Check the pulley mechanism that tightens the belt for proper operation and belt tension while engaged.
Try reducing the speed selector. This is equivalent to running in a lower gear. Your tractor works hard just to turn the blade. Going uphill requires additional power, so some reduction in speed is to be expected.
May 06, 2012 | Husqvarna Garden
Husqvarna 2754 ride on mower , the transmission seems to be weak it cannot go up hills it could before . How do i fix this?
most likely the trans drive belt has worn down and is now slipping,maybe tighten or replace.
Dec 24, 2010 | Husqvarna Garden
2008 Husqvarna YTH 2348 is loosing power...
it has a leak from the head gasket,ive done many with the same problem.pop the head off and change the gasket,also check the rings ect while apart
Dec 30, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna YTH180 runs but won't go into gear
Check the drive belt. If it looks good and turns the pulley on the trans you will need to have the trans looked at.
Sam
Jul 12, 2009 | Husqvarna Garden
Hydro.tran.
have you changed the drive belt since new? also check tension pulley for drive belt, if ok and belt is in good condition, you have a bad drive.
Sep 24, 2008 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
536 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
