Question about Bosch Axxis WTL 5410 Electric Dryer
Filter lamp flashing
Hi. When I run my 7-year old 5410 dryer, everything starts normal but after about 3-5 minutes the filter lamp is flashing and heat and motor stops. The same if I run in timer mode: If I set it for 40 minutes it changes after a while to 8 minutes and heat is turned off. I have off course cleaned the filter and condenser so I can eat food on them. I have also checked the NTC temp-sensors (in front and at the heater); both seemes ok. Dismantled the heater, no blocking there. Fans in front and rear are clean. Why is the LED still flashing!!! Any clue?
  • EGfix Jan 06, 2008
    I found another 5400 dryer at a wasteyard, took that controlboard instead and my dryer started to work again.
    Problem solved! Thanks anyway Bernard.
    Eric
The condenser has two "channels" one for the moist hot air that are easy to clean and inspect. The other flow is perpendicular where cool air drawn from outside and passes through. These channels, viewed from the side can get blocked over time with dust/fluff. I blasted mine with a pressure washer and it was obvious from the change in light when looking through it that it was clogged before I blasted it.
Posted on Sep 19, 2007
SOURCE:
I have a 5 year old LG front loading dryer, model # DJG2524W. When I went to start to dry a load, the dryer started, and then stopped after only a second or two. The check filter light was flashing. We...
Hi
I believe that everything else is fine rather it is the thermal fuse that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if it is bad then it should be replaced, as it cannot be reset. If the fuse is fine then it can be due to the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 24, 2011 | Dryers
Gas lights up for about 5 minutes and then burns out. Try to turn on dryer again, but flame won't light. I let dryer sit for aout 30 minutes and turn on again - flame starts up, but will only last...
If the flame is shutting of before it reaches the operating temperatures the likely failure is a restricted venting system. There is a high limit thermostat that will cause the flame to shut off if there is a lack of airflow due to a restriction in the vent system. Remove the lint filter screen and clean in with soap and water. The filter may appear clean but it could have a clear film of fabric softener residue covering it causing a restriction in the air flow too. After cleaning the filter reinstall it before running the next test.
For testing purposes only, disconnect the dryer vent hose from the back of the dryer and put a normal load of clothes in the dryer and start the dryer. If the clothes dry in the normal amount of time that would confirm a restriction in the vent hose or the venting system. NOTE: Do not leave the vent hose disconnected after running the test. Reconnect the vent hose.
You will likely find the clothes drying in the normal amount of time indicating a restriction in the venting.
Aug 02, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Hi, I have a F & P top load washer (model GW701-U) over 10 years old. I use cold water washing. The water fills up very very slowly- just dribbles. After about 7 minutes of the water filling up, the...
Turn off the water to the washer, unscrew the hoses ( do one completely before moving to the other)Once you unscrew the first hose you will see a small filter screen inside the opening on the washer,Remove the screen and clean it, replace it and reattach the hose,Now go to the other hose and do the same thing, once both are done and hooked back up, turn the waterback on and everything should work as normal.
Dec 02, 2010 | Fisher and Paykel Washing Machines
Tv desn't turn on,power light just flashes ten times and then stops and then again
Error Indication Information
Error No. Error Information ERROR DESCRIPTION LAMP LED OSD LAMP OFF
(Note 3) (Note 4)
POWER LED TEMP LED
Note:
1.When any of the above errors has occurred, the LED will flash as shown above every 5 seconds.
2.When two or more errors have occurred at the same time, the LED will light up or flash as shown above, and then
change to another every 5 seconds in turn.
3.Warning OSD appears when the Air Filter is clogged 90%, accumulated operation time of the Lamp reaches 5000 hours,
or accumulated operation time of the Air Filter reaches 400 hours.
4.LAMP OFF: The LED will flash right after the Lamp goes off.
5.IC2301 is mounted on LCD Main C.B.A. which is included in the Projection Unit.
6.IC6001 is mounted on TV Main C.B.A.
Clogged air filter
more than 90%
15)
16)
17)
18)
1)
2)
3)
4)
5)
6)
7)
11)
8)
9)
10)
12)
13)
14)
- flashes 5 times -
every 5 seconds
IC2301(pin82) detects the clogged air filter, then indicates the
error when the air filter is clogged 90%.
Front Fan stop or
Lamp Fan stop
flashes orange
once every
5 seconds
IC2301(pin12) detects the Front FAN stop or Lamp
FAN stop, then indicates the error when the Front FAN
or Lamp FAN is stopped.
Lamp Cover open
Temperature Sensor
short or open
flashes orange
twice every
5 seconds
flashes orange
3 times every
5 seconds
flashes green for
140 seconds.
flashing red for
60 seconds.
light up red.
flashes once
every 5 seconds
flashes once
every 5 seconds
flashes red for
10 minutes
flashes once
every 5 seconds
Abnormal
Temperature
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Request for Lamp
Replacement - - lights up
Power Ballast Error
(abnormal
Lamp voltage)
flashes 3 times
every 5 seconds
Power Ballast Error
(abnormal
temperature)
flashes 4 times
every 5 seconds
Power Ballast Error
(other causes) - -
Request for Filter
Cleaning -
Abnormal Voltage
on 16 V line of
LCD Main C.B.A.
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Abnormal Voltage
on 14 V line of
LCD Main C.B.A.
flashes 3 times
every 5 seconds
flashes 3 times
every 5 seconds
Abnormal Voltage
on 7 V line of
LCD Main C.B.A.
flashes 4 times
every 5 seconds
flashes 4 times
every 5 seconds
IC2301(pin76) detects the Lamp Cover Unit condition
(open or close), then indicates the error when the
Lamp Cover Unit is open.
IC6001(pin85) detects the Duct FAN stop, then
indicates the error when the Duct FAN is stopped.
IC2301(pin74 and 75) detects open or short of the Temperature
Sensor (R2911) on Front Thermistor C.B.A., then indicates the
error when Temperature Sensor is open or shorted.
(The error is not detected for 1 minute after Lamp ON.)
IC2301(pin74 and 75) detects the temperature attached near
the Front FAN by the Temperature Sensor (R2911) on Front
Thermistor C.B.A., then indicates the error when the
temperature becomes more than 43 C (109 F).
IC6001(pin86 and 87) detects open or short of the
Temperature Sensor (R2901) on Lamp Thermistor C.B.A.,
then indicates the error when Temperature Sensor is open or
shorted.
(The error is not detected for 4 minutes after Lamp ON.)
the Lamp by the Temperature Sensor (R2901) on Lamp
temperature becomes more than 60 C (140 F).
IC2301(pin11) detects the error of LCD Power C.B.A.,
then indicates the error when the temperature fuse
(117 C)(243 F) in LCD Power C.B.A. is open.
IC2301(pin11) detects the error of LCD Power C.B.A. and Lamp,
then indicates the error when an inner malfunction of LCD Power
C.B.A. occurs, the Lamp voltage becomes more than 130V or
less than 30V, Lamp current becomes more than 5A, or the Lamp
is cracked.
IC2301(pin11) detects the error of the Lamp, then indicates the
error when the Lamp is short-circuit.
IC2301(pin48) detects +16V line voltage on LCD Main
C.B.A., then indicates the error when the voltage
becomes less than +13V.
IC2301(pin47) detects +14V line voltage on LCD Main
becomes less than +11V.
IC2301(pin45) detects +7V line voltage on LCD Main
becomes less than +5.7V.
IC2301(pin44) detects +3.3V line voltage on LCD Main
becomes less than +2.5V.
flashes 3 times
every 5 seconds
flashes 4 times
every 5 seconds
Abnormal Voltage
on 3.3 V line of
LCD Main C.B.A.
- flashes 5 times
every 5 seconds
Forced cooling
The failure of Lamp
light up
Temperature Sensor
short or open
Abnormal
Temperature
Duct Fan stop -
When accumulated operation time of the the Lamp reaches
5000 hours, OSD (replacing the Lamp) appears on the screen.
Note: The Lamp time is stored in EEPROM (IC2305).
When accumulated operation time of the Air Filter reaches 400
hours, OSD (cleaning the Air Filter) appears on the screen.
Note: The Filter time is stored in EEPROM (IC2305).
During forced cooling, this indication is indicated.
IC2301 (pin11) detects the failure of light up processing of
the Lamp, then the POWER LED is changed as follows.
1) POWER LED flashes green for 140 seconds (while turning on).
2) POWER LED flashes red for 60 seconds (while cooling).
3) POWER LED lights up red (standby).
Note: If the Lamp will not light after attempting turning on the
power 2 or 3 times, the Lamp, the LCD Power C.B.A. or the
LCD Main C.B.A. may be defective.
Error Symptom Problem Possible Solutio
May 30, 2010 | Panasonic Viera TH-50PX80U Plasma TV
LG DLE2512W dryer approx 3 years old error message to "check filter". Dryer has stopped working. What is the problem? Do you have a schematic of the dryer I can download?
I just had this problem with my 5 year old today. I unplugged it (after checking the line and the regular filter to make sure that they were clear). since there didn't appear to be a real problem. It works fine now. It wasn't having any problems before the light started flashing and it doesn't appear to be having any now. Hope this helps
Mar 14, 2010 | LG DLE2512W Electric Dryer
Dryer not starting
Check your lint filter first, and then try to restart it. Also, make sure the door is completely shut. If this doesn't do it, check your condensation hose for blockage. These dryers are very sensitive to lint build up, so make sure to change your lint trap after each load. It's not only a good practice, but it's necessary with this machine
Feb 27, 2010 | Bosch Axxis WTL 5410 Electric Dryer
LG DLE5977W dryer has stopped and developed a motor hum. How can I fix it?
I am assuming that the hum indicates the motor is running but the drum is not turning.  Possibly a broken drum belt however the check filter warning is indicating low air flow so the blower wheel could be broken at the connection to the motor shaft.
Jun 01, 2009 | LG DLE5977 Electric Dryer
Blinking green light and clicking noise AFTER bulb replacement
do this. press and hold device and menu button on set for 5 seconds. this will retrieve a 2 digit error code .. the led will flash the first digit and pause the flash second digit. This unit is known to have capacitor problems on the power board. getting to these capacitors involves taking alot apart. let me know error codes and we can continue troubleshooting
Jan 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Tv Shuts off occasionally 1min upon power up shows red lamp light
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Feb 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Bosch Axxis WTL 5410 Electric Dryer Logo
184 people viewed this question
Top Bosch Dryers Experts
Elie Balas
Tommmix
Level 1 Expert
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
