Blue green screen on my desktop. Autofocus on my desktop doesn't work.
My color on my screen is very bright. I have tried to adjust to solor but it just will not work. everything is a bright gren.
  • 981 Answers
Where did you try to adjust the color?  In display properties, or on the monitor controls?  Make sure both have green at a normal level.  Then, make sure your cabling is OK.  Then, try a different video source for the monitor and see if that fixes it; if it doesn't, you get to repair the monitor.  If it does, you can just reinstall the video drivers on the PC.
Posted on Apr 18, 2009
How do I adjust screen brightness?
Hey there,
If your Notebook doesn't have a menu button or any sort of hard-wired option of adjusting to screen brightness, there are a couple of means to doing it in Windows.
First, if you have an NVIDIA card, you can go to the NVIDIA Control Panel in your Windows Control Panel. There should be an option in there that says Adjust Desktop Color Settings. You can increase the brightness from there.
If you don't have an NVIDIA Card, right click on the Desktop and goto Personalize. Click on Windows Color and Appearance, click on Show Color Mixer, then slide the brightness scale to make your screen brighter. Click okay and that should do it.
If you require and further assistance, post a reply to this thread. I'll be happy to assist you further.
Regards,
Aaron Busch Senior Tech of LiveFix Support Services (LiveFix.net)
May 01, 2011 | Compaq Computers & Internet
All of a sudden, the color changed to a blue/green...
You might have brought the magnet near the screen so it happened like this it will automatically adjusted after few days
May 20, 2010 | Computers & Internet
I cant get the color right. its to red??? any help? i did notice with the back cover off, there are 6 adjustment screws
yes! those are the screen and focus adjustments. 3 for screen, 3 for focus. try this. go in menu....turn down color, brightness, contrast all they way down. you should then have no picture, but in your case a little red. then go to back of tv and turn those 3 screen adjustments all the way down. slowly turn the screens back up until you get barely a picture. because remember, your brightness and contrast is all the way down. the picture should be dim but seeable and with red, green, blue adjustments, make it a black and white picture. when balanced..... turn up color , brightness, contrast in menu. enjoy!
Nov 14, 2009 | Philips Magnavox 9P6034C 60" Rear...
How to adjust color on sk-32h570d
This is from the MANUAL
www.westinghousedigital.com/pdf/197_User_Manual.pdf
PAGE 27
A-1 Settings
Use the Settings sub-menu options to manually adjust the display quality. Use the ◄/► keys to adjust the
option level.
Adjust the luminance level.
Adjust the brightness to darkness ratio.
Adjust the balance of the red, green, and blue colors in the display.
Adjust the color intensity.
Adjust the sharpness or softness of the display.
Adjust the brightness level of the screen backlight.
AND this is from the troubleshooting procedures in the manual
PAGE 64
Wrong, abnormal or missing colors
・ If any colors (red, green or blue) are missing, check the video cable to make sure it is securely connected. Loose or broken pins in the cable connector could cause an improper connection.
・ Press and select Picture | Settings to adjust the Hue and Saturation settings. You can also select
Picture | Advanced to adjust the Color Temperature settings.
・Connect the TV to another computer and check if the problem is with the computer screen.
Other than that there is no mention of color adjustment
May 08, 2009 | Westinghouse Electric SK-32H570D 32 in....
Color
see if there is a "default" option, if not set everything back to the middle, if the colors are still off you sure its not the convergence?
most big screens allow you to change "color temperature" it's like a default adjustment for 3 different brightness levels.... ie...COOL, WARM picture will show obvious changes in brightness
Apr 24, 2009 | Philips 50P8341 50" Rear Projection...
One bulb is too bright
there is an adjustment inside the back of the tv to turn the color down
Mar 02, 2009 | RCA P52926 52" Rear Projection Television
Screen hazzy and issue with blue convergence
bad convergence would cause show to look as if it was supposed to be a 3-d movie, if a bulb was going out then people would look purple blue -green,or some other off color, so likely the green bulb is going out from the color of the people you described.
Feb 06, 2009 | Philips 60PP9202 60" Rear Projection...
Adjusting brightness for my gateway 3520 laptop
Most likey the dim screen while running on batteries is the power saving feature. This can be changed in the operating system configuration. Assuming you have Windows, you should be able to right click on the desktop, click Properties then the Screen Saver tab. I have a desktop so I won't see the same details as a laptop. Just go to the appropriate settings & change them to give you higher performance for use with the battery. You may also be able to adjust the brightness with the Function key & another key combination. Look at the blue or green colored silkscreening on some of the keys on your keyboard & maximize the brightness while running on batteries only. Next time you reboot, it should remember your previous settings. Hope this works for you.
May 19, 2008 | Computers & Internet
Aadjusting screen colors
They should be adjusted to set voltages. however it is best to shut the color level to the lowest setting then try t balance the screens to achieve the best black and white picture. then turn up your color level. Your brightness level should also be set to 50 % then when you adjust for the best B&W picture. You will have better color and brightness when you reset your color and brightness levels. Hope this helps.
Feb 01, 2008 | Hitachi 57F500 57" Rear Projection...
Green picture
I'm not sure about this model but most projection tv's have a focus/screen control block usually located behind the front grille where the speakers are. The grille usually comes off easily. If there are no circuit problems you can adjust the red green and blue picture tubes there. Also the focus. It will be written somewhere screen and focus: Three for screen and three for focus. If you find the screens then adjust them slowly clockwise for increase brightness on the red and blue and you may have to reduce the green. Adjust for best picture. If the picture does not adjust too good then the tubes are weak. Only if there are no circuit problems Hope this helps
Dec 30, 2007 | Mitsubishi WT-42313 42" Rear Projection...
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
