Question about Nintendo GameCube Console
New install have power..no picture..advise on select using comcas
Do not have anything else connected to t.v.
    Problem Solver:
  • 3 Answers
You have to connect the A/V (yellow, red, white things)
Posted on Apr 19, 2009
Hi i had reseted my voyage 200. Must i do anything before install new programs?
well,
Technically you can just install the new programs using your ti-connect device but it would be advised to search ti.com/calc for a new operating system, commonly termed OS. It is just a suggestion that will make the calculator run much smoother.
Mar 28, 2011 | Texas Instruments Voyage 200 Calculator
My schreen has no picture. The camera still takes and downloads pictures ok but I cant use the viewer. The schreen lights up after you take a picture but no picture shows. I cant get into any menus to...
Sounds like either a bad LCD or a loose connection to the LCD. Very risky and time consuming to try to fix aat home. Diagnostics and service by a Nikon Authorized Service Center is advised.
Dec 21, 2010 | Nikon D70s Digital Camera
I'm trying to install WD Caviar Green 1TB in my Dell Dimension 4600. It appears as though the exhisting hard drive used a SATA connection w/molex power connection. I have tried downloading the WC...
I BELIEVE THAT WD PROVIDES A CD WITH "WD DATA LIFEGUARD UTILITIES." IF YOU USE THAT DISK AND SELECT "DRIVE TO DRIVE COPY" SELECTION. THIS SHOULD CREATE A CLONE OF YOUR ORIGIONAL DISK. SELECT THE NEW DRIVE TO BOOT FROM EITHER IN BIOS SETTINGS OR FROM THE BOOT SELECT "F12" OPTION.
THE PC SHOULD BOOT FROM THE NEW DRIVE IF SELECTED
ED P
Aug 09, 2010 | Dell Dimension 4600 PC Desktop
Loss of Signal
Please make sure the antenna is tuned to proper SWR.
Also double check the power wire connections.
Let me know if you have no clue about tuning the SWR.
May 26, 2010 | Cobra 19 DX IV CB Radio
Can I load my pics and texts to pc and how do i save these to sim
to move your phone and pictures to your pc, do these steps.
note 1. if you didn't installed the samsung pc suite yet, do these.
>> if your pictures are stored in the phone memory, do these..
1. move all the pictures to your memory card.
2. insert your sd card to its adapter and insert them to your for laptop, sd card slot. for desktop, you need to have a memory card reader. by then it will be read by both pc and laptop as mass storage device and you can easily drag and drop files from both pc to your memory card.
OPTION (you can also do these)
1. configure your phone pc connections settings, check ask for pc connections, you can find the settings through, menu, select settings, select phone settings, select pc connections, check '' ask on connections''
2. connect your phone, it will ask for pc connections, select memory card, your computer will read it the same way as mass storage device, once read, you can drag and drop files from pc to your memory card.
i believe there is no way you can back up your messages by using your phone, not unless you have a program to do it, like PIM backup, or messages backup or something like that..
Note 2.
if you installed your samsung PC suite program,do these.
>> connect your phone, let it be searched by the PC studio, once connected, do the following.
1. open your communicator, select messages.
2. synchronize your phone message to the program,
3. highlight all the sms, mms(both inbox and outbox or sent) open the menu, select export to pc, once successful, the software will ask you where to save it. create a new folder (SMS backup) and save it there.
4. do the same way for your MMS, (both inbox and sent)
5. check the file in your computer NPS if the export was successful, you will find there the file which you had assigned a name.
>>to save pictures to your computer using samsung pc suite, do these..
1. double click your phone icon, the pc suite will read it, wait for it until it displays the panel.
2. from the panel, select files either from your phone or from your memory card.
3. once selected, highlight the picture images,press and hold and drop to the computer icon, the file will be saved from there. to check the files save, open your documents, default saving folder is not NPS but my pictures folder.
please consider that if highlighting images can not be done, then do it one by one, click and hold the images and drop to the computer icon. and to organize your file for immediate retrieval, create a folder from your NPS( you can see it to my computer my documents) and rename it as IMAGE BACKUP or your phone name_image back up (i.e; impression_image_backup)
Note 3. to transfer your files to your new cell, please consider this, if the phone your going to buy is not a samsung or the same brand as your previous phone then you will be having these effects,
1. the messages you have backed up will not be recognized by your new phone software program, then i advise you to copy your messages to your sim, the only advantage of it is, if your sim can only hold several text messages, hence you can not save all.
2. the phone book contacts may also not be recognized, hence i advice you to create 3 back up for your phone book contacts, A) make it as npf file extension for your samsung phone. B) the other as csv file extension C) outlook contacts or vcard extension file. you can select this in the drop down menu during saving or back up.
and to answer your question, you can't save your pictures to your sim, as your sim is not designed for it, unless, your network provider sim is providing this service.
you can check from your phone book settings, what is the default memory of phone contacts storage. for your pictures, you can check also from settings, just select memory settings and select default memory.
last thing, you can do the above steps for your new phone, the only difference is that, you will not be using the samsung pc suite, but your new phone's pc suite.
hope i answered your queries..
regards and take care.
Mar 01, 2010 | Samsung SGH-A877 Impression Cell Phone
How to get the pcitures from the camera to the computer
There are 2 ways of doing this:
1. You can use the camera as a plug and play device. (Dont install any Kodak software and you will find your camera as a removable device. You can simply right click on it and select get picture.)
2. Have Kodak Easyshare Software installed, connect the camera and select transfer all.
If this doesnt apply to you, please advise what happens when you try to transfer? Do you get any error messages?
Oct 22, 2009 | Kodak EasyShare C613 Digital Camera
I'm trying to transfer pictures from my computer to the picture f
You can start copying pictures to SV811 digital picture frame if you get the message “Use PC interface to copy files.” Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
1. Connect the USB cable from the frame to your computer
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw )
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and press “Home” icon to navigate to your copied pictures.
Dec 20, 2008 | Kodak EasyShare SV811 (8858946) Digital...
Installing a internet modem
you open case
have comp turned completly off
install ethernet card into proper slot screw down
turn on comp goto control panel network setup wizard follow instructions from there
remember first your modem has to be recognized by your service provider first before you can get that connection and they give you the service to connect
say like cox qwest or other service provider
May 09, 2008 | Dell Inspiron 5100 Notebook
Can't download photos to my new Vuescape 1.4 " digital picture frame
When you plug the frame to the computer, the frame will prompt two choices. The choices will be either “USB power” and “USB Connect”, or “USB Power” and “USB download”.
A. If you have the one that says “USB connect”, select it and press either the power button or the mode button. Which one depends on the version. On one, power will work, but mode will do nothing, on the other, mode will work but power will do nothing. So try either and you should be fine.
OR
B. The one that says “USB download" you will choose that option and then press either the mode or the power button, as explained above.
If this process if followed, the pictures that are saved to on board memory will be displaying on the frame. You should then be able to open the viewer program.
I hope this helps. But if you need to reach their customer service, the number is 800-639-3803 or support@fsgroup.net.
Dec 25, 2007 | GPS
Nintendo GameCube Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
