Question about SanDisk Sansa m230 MP3 Player
Driver download when i have connecting my sansa sandisk m230 to pc windows xp sp3 a dialog box appears stating that "one of your usb device is malfunctioned and windows does not recognise it". pl help me to solve this problem
SOURCE:
SOURCE: my mp3 player doesn't work
My Mp3 dosn't work when i turn it on it says updating and when i put it on the charger it tells me instalzing i don't know what to do please help me.
Posted on Dec 05, 2006
SOURCE: Sandisk Sansa View 8GB = would not connect
I jsut purchased an 8GB sansa view mp3 and I downloaded it like I was suppose to and it does not work in Rhapsody at all, also in the windows media player it shows that the device was installed correctly but it still doesn't work and I still can't sync my songs to it. The sansa icon won't even show up
Posted on Jan 27, 2008
SOURCE: REG - windows not recognised
For some models pressing select and the + volume button for 10 sec resets the device and it is recognized by the pc on connecting. Check ur manual to check the way to reset ur device. You can download the manual from http://www.sandisk.com in case you have misplaced it. Drop me a mail at balneet_83@yahoo.com to let me know if the solution worked for you.
Posted on Aug 09, 2008
jazzyboy11
  • 728 Answers
SOURCE: Windows not recognised
Press and hold the lower volume button and plug it in to the computer simultaneously and keep holding the minus button until a box appears where the message of usb device malfunctioned and click on it. Then follow the instructions and it should be recognized.
Posted on Nov 27, 2008
meeknotweak
  • 341 Answers
SOURCE: Sansa Fuze 8GB hard drive shows up as unknown device.
Have you tried changing the USB Mode in your MP3 Player?
On your sansa, go to "Settings" then System Settings" then "USB Mode," then change it to MSC, if that does not work, try the other modes, just in case.
Hope this helps!
Posted on Dec 25, 2009
How to unlock sansa 1 gb mp
Sansa Connect No-Wifi Recovery Tool
Make sure your Sansa Connect player is charged and the HOLD switch is in the unlocked position. Press and hold the power button for 20 seconds, then release it. This will force the Sansa connect player to reset and restart.
If your player still will not start after trying the reset, you may need to run the Sansa Connect Recovery application.
With a copy of the Sansa Connect Recovery application installed on a PC, you can connect your to the device via the USB cable to the PC, and restore the device software to an uncorrupted state.
However, all of your subscription settings and content will be removed from the device.
STEP 1 - Download and install the recovery tool.
STEP 2 - Put your Sansa Connect player in Recovery Mode
1. Press and hold the Power button for approximately 8 seconds to turn off the player.
2. While holding down the Right button, and Volume Up Button,
press-and-release the Power button. Keep holding the Right and Volume Up button. After a few seconds, the player will start and a Recovery Needed message will on the player's screen.
3. Connect the player to a PC.
4. A SanDisk Device Recovery dialog box will appear on your PC. Choose Recover Sansa Device and click OK.
5. Follow the steps in the SanDisk Device Recovery application.
Hope this will help you.
Jan 02, 2010 | Audio Players & Recorders
Computer won't recognize clip
Try checking the usb ports to make sure it is not have driver problems:
1. Go to the Windows Desktop, click on the "Start" button, and then click "Run" or "Start Search" if you are using the Windows Vista operating system.
2. Type the following text into the text box: "devmgmt.msc" Click OK.
3. Select your computer when the Device Manager window opens, and then select "Action" from the options at the top of the window.
4. Choose the "Scan for hardware changes" option from the drop down menu that appears.
5. Insert any USB device such as a mouse or flash drive into the USB port in question. Now simply check the USB device to see whether it is working in order to test the port.
If it is have driver problems. Go to http://www.sandisk.com/ and download the driver again.
Sep 30, 2009 | SanDisk Sansa Clip MP3 Player
By mistake formatted all Data including software
The software is only for Windows 98 otherwise the player is a plug and play device (Windows 2000, XP & Vista). Click here if your operating system is Windows 98.
Can you see the MP3 player on device manager?
Jul 28, 2009 | SanDisk Sansa m230 MP3 Player
Is there driver/ software for Win ME for the Sansa Clip mp3?
a friend told me that if the device shows as"connected" when hooked up (it does) AND the battery charges correctly (it does), then (a)the USB connection had enough juice; and (b) the PC recognizes it - i just had to FIND it. device manager/ MyComputer: nada; same for ANY file/ folder with "sansa" or "sandisk." working thru WMP (Windows Media Player), however, I discovered that drive E - for a portable hard drive, NOT currently connected via USB - was STILL showing up in the "Copy to CD or device" field. sure enough, it was the SanDisk clip player (even though it was NOT under the "Recognized Portable Devices" subsection). without using the installation disk at all, it downloaded tunes just fine. *note: the installation disk seemed to be an .exe file ONLY for the Rhapsody music service. as noted above, it was unnecessary. also - my USB ports are 1.1 and not 2.0, and package stated USB 2.0 was a "minimum requirement" - not true*
Jun 17, 2009 | SanDisk Sansa Clip MP3 Player
How do you delete songs of the sandisk mp3 player the model is m230
Windows XP puts the Sansa drive into MTP mode by default. (see: http://en.wikipedia.org/wiki/Media_Transfer_Protocol )
In order for the Sansa device to be seen as a drive letter, it needs to be in MSC mode.
OK, enough background! On your Sansa device, go to Menu | Settings | USB and select MSC. Once you exit the menu and connect the device to your Windows XP machine it should be recognized as a drive letter.
This method worked for my Sansa M240. Hope this helps!
Jose
Jun 05, 2009 | SanDisk Sansa m230 MP3 Player
Window media player is not recognizing my sansa m230
Refresh drivers - connect player to PC. Right-click My Computer & select Manage. Click Device Manager on left pane. Player will show on right pane as USB Mass Storage device or Portable Device.
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers: right-click the entry with the error & select Uninstall. On top menu, click Action then select Scan For Hardware Changes.
Feb 21, 2009 | SanDisk Sansa m230 MP3 Player
I need to get my computer to recognise the SanDisk Sansa M230 MP3 Player. I DON'T want to download something that will play around with the entire computer. One Driver ONLY> Cam
What i would recommend you to do is to uninstall the device and reinstall it back...to uninstall it...assuming that you are running windows xp...click on start, right click on my computer and go to properties..you should have your system properties open then click under hardware then device manager...look for the sansa device..it usually located under portable device..if its not showing there i would recommend you to look for under disk drives and see if its there..right click on the device and click on uninstall...after you unintall it unplug your device from the computer....Then follow this link below to download the porting kit...http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en .Then check the mode of yuor device to make sure it sunder MTP not msc...To check the mode go under menu, settings and choose usb mode...After you check the mode open up your windows media player click on tools, options and click under privacy...clear the history and caches...after you finish you can plug the device on the back of the computer not the front then windows should recongnize it and it should work properly..if that doesnt solve the problems upgrade your windows media player to 11 even though you have done that already..and try to reconnect your device..make sure you have it connected on the back USB>>>
And if that doesnt work try to obtain the driver for your sandisk device go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Please rate accordingly
Thank you
Computerrep
Jan 27, 2009 | SanDisk Sansa m230 MP3 Player
Album and genre control
Your USB settings are wrong. In the menu, select MSC for the USB and not auto detect. xlthim
Jul 20, 2008 | SanDisk Sansa m230 MP3 Player
Sansa M230 not seen in Explorer or Windows Media Player
We had the same problem with Windows XP. We found some help on the Sandisk web site. On the device go to the Settings menu, then USB. We changed from AutoDetect to MSC mode and everything is working again. Our computer saw all of the songs on our computer fine. Some of the old songs on the Sansa didn't show up on the detect list in Windows Media Player, but they were still on the device.
Mar 23, 2008 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
52 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
