Question about Refrigerators
The refrigerator isn
I have the side by side model that's supposed to be "built-in" but sitcks out 4 inches. The refrigerator is not cold enough even though the setting is on max. I have the frezer on the middle setting & it's fine. How do I clean it? There s probably an accumulation of dust. I pulled it away from the wall and cleaned behind it.
  • 3 Answers
If you allow the refrigerator to completely defrost by unplugging it and leaving the doors open, the coils (which are hidden from view usually behind the back interior wall) will allow air to flow around them once again ( after the heavy ice buildup melts away ) It usually drains down into a pan under the refrigerator . This is what contols the temp in the cold portion of the refrigerator. Likely the defrost coils have quit working. This is a common problem and requires a new defrost coil be installed to keep the ice from building up on the coils.
Posted on Apr 18, 2009
I have a kitchenaid side by side refrigerator model #KSSC42MFS05 and the freezer isn't getting cold enough to freeze ice cream and the ice maker isn't working.
Look at the rear wall of the freezer for a layer of frost building on the outside of that panel. If yes the refrigerator may be missing defrost. That would explain why the feezer temperatures are warming. If the ice maker is above 5 degrees F it will not be able to make ice. Things to check are the=> 2162044 Defrost Timer
The=> 2000631 Defrost Heater
and the=> 4387499 Defrost Thermostat
I would like you to locate the defrost timer and turn the center with a flathead screwdriver slowly clockwise until compressor and fans turn off. Leave like this up to 30 minutes. This will cause the defrost to begin. If timer does not restart the compressor an fans after 30 minutes simply turn the timer again slowly clockwise until the compressor and fans restart. If the timer need to be turned like this then this would indicate that the defrost timer is defective and will need replaced. Let me know if you have questions Thanks Sea Breeze
Sep 25, 2012 | KitchenAid Refrigerators
Plum in a Amana fridge freezer
hello. I am assumming that your model has the ice and water dispenser. Not all models do. On the rear of these models with the ice and water feature you will find a small [1/4 inch] line that has to be connected to a cold water supply source. If you go to most any hardware store you can get the little kit necessary to make this connection. The kit consists of a length of 1/4 inch tubing, the connector to attach to the tube at the rear of your appliance, a valve and a tapping kit to tap into your closest cold water source. If the fridge is near the kitchen sink, you may choose to connect under the sink. If not, make sure you purchase a kit with enough 1/4 inch tubing to reach your nearest cold water pipe. J.
Jul 20, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Maytag , model RSC20A
if old it might be wise to replace it. or spend money on a service call
Jan 04, 2018 | Refrigerators
Ge side by side not cold enough in fridge or freezer
if there is no frost build up in freezer section sounds like a refrigerant leak
Apr 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
67 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
