Question about Motorola Mobility V535 Cellular Phone
Motorola v535 When making or receiving a call I can only hear through the loud speaker.the ear phone is not apparently working
0 characters
1 Points
I dropped my cellphone and now I can make a call but I can't hear the person on the other end. They can hear me, what can I do?
Hello and Welcome to FixYa!
The problem is simple, I have had this issue with many of my cellphones. The reason behind this is a faulty Ear-piece (The Small speaker unit that is on the upper side) If you have a Loudspeaker in your Phone you may hear from the load speaker because Loud speaker is always a by-bass to Ear-piece. The Loud Speaker may also be damaged as your phone got impulse. Neither you can listen to them when making a call nor receiving a call. The solution is to get your phone serviced, I'll not tell you to replace the Ear-piece directly. Because there are also cases when the Ear-piece is ok but due to the phone slider or flip open the body strip got damage due to which this response is generated. So to cut the story short you have to go to a nearest server center and ask them to service your phone as you are having this problem. They will diagnose, then act accordingly.
I'ts not at all expensive. And I'll not recommend you to do it yourself, as you may end up in more mess.
I Hope you will have a clearer picture now. Concerned, Nooh.
Aug 03, 2011 | Cell Phones
When I receive an incoming call I have to put them on speaker or I can't hear...same with outgoing calls....
The main reason for this problem is because of the ear piece. The ear piece is something you keep close to your ears while making calls. The speaker is an alternate way to listen music or to listen the caller loud or for ring tone.
Check your ear piece. Either it would have damaged due to water or would have lost the connection to the circuitry.
May 19, 2011 | HTC Cell Phones
When i call someone on my phone they can hear my voice but i can't hear their voice.
Try to use the loud speaker if it works then the problem is with the ear piece only.You need to replace it.
Thank You
Nov 13, 2010 | Motorola Mobility ROKR E8 Cellular Phone
Motorola I776, Only works on speaker phone.
Replace the flip assembly, the ear receiver is dead and thats why you cant hear, replace the flip and you'll be fine, its not expensive and this is a common issue with motorola flip phones.
Jun 22, 2010 | Motorola Mobility i776 Cell Phone
Can't hear anything when i make or receive a call unless i use the speaker option
Your AK mobile brand Motorola has an ear piece problem.
Means the speaker in your phone used for hearing someone when they call is damaged, and it needs to be replace.
So take it to your nearest repairer to remove the damaged earpiece and fix another for you.take care.
Jan 24, 2010 | AK Mobile BRAND MOTOROLA A810 BLACK 1YR...
Cannot hear callers voice during a call but caller hears mine
if you cant hear caller voice. do one thing go to gallery and go to voice recorder and record some voice then save that then go to media and play recorded sound if its working means your loud speaker is working but not ear peic means (ear speaker) not working. so then you need to change ear can do your self just watch video on online.
Dec 29, 2009 | Nokia N72 Cellular Phone
well i think your ear peice is gone the speaker
Jul 05, 2008 | Motorola Mobility V547 Cellular Phone
No call volume om samsung e250
This because in your handset there will be 2 speakers
1 is loud speaker and 2 nd one is ear piece speaker....
so the loud speaker is working fine ...
There may be some loose contact in the ear piece speaker or the speaker might have got damaged ...
so if you are good at opening then just open your handset and check if there is any loose contact in the ear piece speaker .. is so fit it correctly ..
or you replace the ear piece speaker with the new one ...
if you are not good at opening then just contact the technician ...
he will do it ...
The ear piece speaker is very cheap so no problem .. just buy the ear piece speaker which is compatible to your handset in the shop if you are doing it by your self ...
the technician might take the service charge for this that s all but the ear piece speaker is too much cheap ..
any doubts reply me
i am always here to assist you
thank you
bye ...
May 14, 2008 | Samsung SGH-E900 Cellular Phone
Motorola razr v3 - no hearing sound on ear speaker
Check the middle button on the side. Hold it in and raise the earpiece volume to the highest before you throw the phone away.
Jun 17, 2007 | Motorola Mobility RAZR V3
Motorola Mobility V535 Cellular Phone Logo
27 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Chris Hunt
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
