Question about Refrigerators
THE ICE MAKER KEEPS THROWING LOADS OF ICE OUT
  • 3 Answers
There should be a wire arm that detects when the ice bin is full and tells the icemaker to quit dumping... check to see if that is hung up...
Posted on Apr 18, 2009
It will not shut off. Just keeps making ice ?????
Ice Maker Doesn't Turn Off If your ice maker keeps making ice, even when it is full:
1Lift the bail wireto shut off the ice maker, and remove the ice bin. Then, using a screwdriver if necessary, remove the ice maker, clean it thoroughly, and then reinstall it.
2If the problem persists,consider removing and replace the entire ice maker and valve. With this type of problem, you can have it repaired, but it's often wiser and less expensive in the long run to replace the unit entirely.
Mar 23, 2015 | Refrigerators
Why is my ice maker on my whirlpool conquest with the model number GS6SHAXKSO1 throwing circuit outlet?
ice maker has motor to rotate ice out of tray. something is wrong with the motor or wiring to it.
Sep 21, 2014 | Refrigerators
Why won't Ice maker make ice?
Scotsman Prodigy - bad Ice thickness probe
May 10, 2014 | Prodigy Scotsman CU1526MA-1A Ice Maker...
Ice maker freezing up at water chute.
It's probably the water fill valve seeping which requires replacing that valve on the back of the refrigerator.
Jul 21, 2013 | GE Profile PSW26P Stainless Steel Side by...
Is it worth fixing a 10 year old KitchenAid Superba side by side?
Pull it out... - turn OFF the water inlet valve..
........... if it still keeps everything cold,,, keep it,,
Jul 08, 2017 | KitchenAid Kitchen Aid Superba Series...
Our model 532 keeps over filling the ice maker causing a build up on the back and down all of the drawer. We can turn it off and thaw the entire box and the water keeps filling the tray even though the ice...
The fill valve for the ice maker could be stuck partially open and dripping into the ice maker. If this is the case shut off the water line to the ice maker and if the water stops you will need to replace the ice maker fill vavle
Aug 10, 2009 | Sub-Zero Freezers
Jenn-air ice maker, stand alone unit, will not shut off, keeps producting ice.
There should be a sensor inside the ice maker bin that tells the ice maker when its full. It may be a wire or an arm on top of the ice. If you accidentally knocked that off the ice maker won't know when the bin is full and just keeps making ice
Jul 07, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Water supply tube keeps freezing off water supply.
its hard to tell but most likely the valve is not closing all the way. but it could be the ice maker calling for too much.... www.whirlpoolpartssurplus.com
Jun 23, 2009 | Frigidaire FRS3R5EMB Side by Side...
Refrigerator keeps throwing receptacle switch plate
I'm assuming this is on a GFCI outlet? May be a problem with the outlet rather than the Fridge. I had an outlet that would do the same thing when it encountered loads. I replaced it and everything was fine.
May 23, 2009 | Kenmore Refrigerators
Ice maker over fill, water keeps running
If water keeps running to the ice maker all the time even when it doesn't call for water , the water valve for the ice maker is leaking(located in the back of the refrigerator,bottoom right),but if overflow only when it calls for water(no more than 7 seconds) the problem is in the ice maker control board, you can replace it but it will cost almost as a new ice maker.
Apr 14, 2009 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
