Question about Hussmann Freezer 12 Facing Straight Glass Front Ice Cream Dipping Cabinet - With Rear Storage Doors
Chill chamber coolers
Beer in cooler freezing and need to find the controller to raise temp alittle higher . Temperature showing 15 degrees
True T-49 refrigerator/freezer temperature calibration
Contact the manufacture, it is most likely going to be covered under warranty. If the knob is not removable, (check for a set screw on the side of the knob it will take a small allen wrench) Then the thermostat (temp controller) will need to be replaced, if it isn't a style that you can calibrate.
Jan 30, 2014 | True Refrigeration True T-49 2 Door Bottom...
How can i change a delfield 407-dhl from a freezer into a cooler
Refrigerators and freezers are almost identical except for more controls on a freezer. Just raise the thermostat to the temperature you need. If it won't adjust that high, you will need to replace it.
Dec 02, 2013 | Freezers
I have a up right hoshizaki model fh1-AAC unit will not come out of defrost
These machines do not work like you think. The display will show the defrost mode even when in the freeze cycle. After a defrost cycle, the cooling system comes on but the display will not show any temperature numbers until the conditioned space gets to within 15 degrees of where you have it set to cool to. So, if it is set to 0, the box needs to hit 15 degrees before it shows numbers. You have a cooling problem. Several thing can cause this. may need a tech to check.
Sep 12, 2012 | Hoshizaki Freezers
I want to use this to store beer but i need to know the highest temperature that this can function at. does this run at a temperature higher than 28 degrees?
NO, IT IS UNSAFE TO KEEP FOOD HIGHER THAN THAT TEMP, YOU CANT BUY A UNIT THAT TEMP SET IS HIGHER THAN FOOD KEEP SAFE LEVELS, SORRY.
Jun 29, 2011 | Kenmore Freezer 11.6 cu. ft. Upright...
It seems that the temp more often goes up to 20-30's and that food is not as frozen when I check it. When temp goes up I check it for next couple of minutes and usually within 10 min the temp is back down...
This is normal. All commercfial freezers must defrost 3 to 5 times a day, or they will freeze over at the coil and then stop freezing. A timer in your freezer turns off the compressor and turns a heating element on for 10 to 15 minutes. During that time the coil heats and melts frost from the coil. Usually within 30 minutes the temperature will briefly rise to 20 t0 25 degrees F and then quickly drop down to 0 degrees F. The food rarely defrosts in this short period of time..
Sep 01, 2010 | Turbo Air 23 cu. ft. / 651 liter...
Temperature
If this unit has a control it would be located on the outer left side in the lower right hand corner. There would be a dial, the higher the number the cooler the temperature. Many of these chest freezers did not have an adjustable control.
Apr 13, 2010 | Kenmore 15 cu. ft. Chest Freezer 16542
Freezer runs constantly,seal is okay,frost free,have tried lowering the temp,food stays frozen. zeecudaboro@tds.net
It seems to me that the thermostat is no longer sensing temperature. IT will either stay on (it controls the compressor) or wont come on at all when it becomes a problem. You can order one thru sears.com if there is not a appliance parts store nearby. To check before buying, heres what you do. You need to know the temperature (use a thermometer that reads below zero). it has to be at least 10 degrees or cooler. if it is then turn down thermostat dial to 1. if it shuts off then the thermostat is ok. if it doesnt turn off (the compressor) replace t'stat. let me know the temp. and if this works for you hope this was helpful...
Mar 30, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I want to use my freezer for beer. Can I raise the temperature by changing the thermostat? Any other suggestions besides using a fridge?
Not sure of your make/model. If its a standalone freezer you could exchange the termostat with a Fridge, or you could jury rig a seperate line voltage thermostat with probe in the compartment, which you would plug the fridge into and would override the internal thermostat (internal thermostat would always be calling for cooling because the line voltage thermostat would be set higher--any time the temp increased above the set point on the line voltage tstat the relay would close and the freezer would run). An anti freeze alarm coupled to a simple relay or contactor would work for this purpose... depending on how handy you are I could explain all the necessary components...
Oct 11, 2009 | Frigidaire 13.7 cu. ft. / 388 liter...
Freezers Logo
223 people viewed this question
Top Hussmann Freezers Experts
Dennis Boxerman
jasbo
jasbo
John Tripp
John Tripp
Are you a Hussmann Freezer Expert? Answer questions, earn points and help others
