Help me out
My murcury sytem just enter self mode and i was told it has currupted some file so the system refuse to open up so what do i do
  • DX_USA2010 Nov 05, 2008
    IHAVE ABIG PROBLEM IN SOUND IN MY COMBUTER IHOPE FIND SOULUTION
    Sergeant:
    Champion:
  • 293 Answers
If this has a system CD or Recovery CD then use it. Boot upon the CD on startup. Else re install your OS.
Posted on Sep 18, 2007
6ya staff
SOURCE:
Sytem restore wont innitiate
Check whether Volume Shadow Copy Service, System Restore Service is started and Set to Automatic
1. Type Services.msc in Start Menu search box, hit Enter. 2. Make sure that the Volume Shadow Copy Service is Running and set on Automatic. 3. If the Status of System Restore Service is not Started, Start it. Also set it on Automatic if it is not.4. restart your computer.
Now try to do a system restore.
You may also download the Norton removal tool and completely remove all the components of Norton. Check if that helps.
Check how the computer works in safe mode.
http://windows.microsoft.com/en-US/windows7/Start-your-computer-in-safe-mode
If the computer works fine in safe mode, then do a clean boot.
Refer this KB article:http://support.microsoft.com/kb/929135
Also, run System File Checker tool (SFC.exe) to make sure system files are intact and to replace the file. Follow these steps:
1. Click Start, and then type cmd in the Start Search box.2. Right-click cmd in the Programs list, and then click Run as administrator. If you are prompted for an administrator password or confirmation, type your password or click Continue3. At the command prompt, the following line, and then press ENTER:sfc /scannow
http://support.microsoft.com/kb/929833
Nov 24, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Unable to restore
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the delete or F2 key
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart if this fails to fix the problem
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution
restart back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time
click start all programs accessories system tools you should see your system restore option
hope this helps you
Nov 26, 2011 | ASUS Eee PC 1001P Netbook
What do you do when my laptops says that Windows could not start because the following file is missing or currupt
Hello.
Boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, all your updates will roll back to that date.
To access System Restore in Windows 7: Open the Start Menu. Click on All Programs, Accessories, System Tools, and System Restore.
Hope this helps.
Feb 26, 2011 | Gateway Computers & Internet
I need drivers my laptop currupted i can't open it anymore
Without the cd there isn't much you can do. Unless you can find one you'll have to hope your laptop has a system restore option but you would also risk losing all your data doing so.
I doubt you can get to safe mode, but give try safe mode with command prompt and type chkdsk in the cmd window.
Mar 23, 2009 | Toshiba Satellite 1955-S801 Notebook
Boot problem
If you cannot boot to safe mode, you may need to reinstall the OS, as it might be currupt.
Good Luck.
Jan 28, 2009 | Dell OptiPlex GX270 PC Desktop
My printer refuse to print dont no why hp deskjet 3325
identify if the print drivers are correct, has the printer been printing fine then has stop? if so, currupted print drivers can cause this issue. uninstall the drivers then reinstall them. don't allown the auto detect to install the drivers for you, it will just install the currupted ones again that are stored in the inf directory.
Dec 16, 2008 | Computers & Internet
Sytem Wont Start
Hi suisboy,
This sounds similar to a problem I had with a clients PC. The best way to debug this is to swap out one component at a time and see it it fixes your problem. However, if you can't do this then I'd suggest you try the following in this order.
  1. Remove all cards from the PCI bus leaving only the graphics card in place.
  2. Unplug all drive cables from the motherboard and power from the drives.
  3. Try to boot the motherboard. If successful try this, several time and if you don't have any problems you are okay to proceed.
  4. Enter the BIOS and load load the Default settings.
  5. Enter the BIOS and make it run the system check to fully test the memory.
  6. One by one re-attach your drives, if the system is stable continue to add you PCI cards until you hit the problem again. This will be the incompatible or faulty card.
This procedure should allow you to find the component that's causing your bus timing fault.
I hope this will help you diagnose your hardware.
Regards,
Spare head 2
Jan 06, 2008 | Mercury P4VM800M7 Motherboard
Window xp
The problem may be due to curruption of the system file.
One of the solution is :- Go to Start > Run and type 'sfc /scannow' (without the quotes). This will run the System File Checker that will replace any damaged or corrupted system files.
If it is not solved yet, try with a updated antivirus for a trojan or spyware.
Dec 31, 2007 | Microsoft Windows XP Professional for PC
My keyboard and mouse pad doesn't work; there also is something going on with the power up. it takes a couple attempts and i have to hold the power button. with a keyboard & mouse plugged into the usb...
sounds like currupt files to me have you tried a system restore point enter safe mode using f5 or f8 key then goto system restore in start menu, programs, Accessories, system tools, sytem restore if all fails copy all files needed onto an external hard drive and re-load windows on you laptop. hope this works for you
Aug 17, 2007 | Averatec 6200H Notebook
Open Questions:
Computers & Internet Logo
164 people viewed this question
Ekse
Marvin
Marvin
