Question about The Step2 Company Tag Along Trailer Plus
Need help with tag-along trailer for Step 2 wagon
The wagon is about 7 years old I got from a friend. No instructions, can't get the tag-along trailer connected to the wagon. I can't find an instruction booklet anywhere on the web, and Step 2 doesn't have any help on their website. Anyone have any ideas?
How can I chech the heating element to see if it's working?
Good Afternoon Friend,
I understand you have a 7 year old Kenmore dishwasher, which you want to know how to check the heating element to see if it's working. Typically, this is not a do it yourself job, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to diagnose your appliance and determine if the heating element is working. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire 24 in. FDB510LC Free-standing...
Tip
PS3 disk stuck or other blu-ray problem can be fixed by yourself. You need to...
Have a look at this video if you feel that your PS3 isnt loading correctly or is struggling to read disks, and the corrupted files on the hardrive
If this hasn't worked i would recommend visiting PS3 Problems
on Jun 30, 2010 | Sony Playstation 3 (PS3) Console
I am doing this on behalf of my son,he has a 1989 kawasaki zxr 250,it had a ticking niose when riding,got worse the faster he went,took it to his motorbike mechanic,was told it was his starter motor,[this...
You could purchase a service manual for the 250. Then you will need tools, some very special. You will need a place to work and probably a mechanic friend to look over your shoulder from time to time. You should speak with the parts guy or gal at the Kawasaki shop considering the parts you will need for this 25 year old motorcycle. I'm sorry, you can not get step by step instructions on how to reassemble an engine here
Since you are this far along, you may well want to consider the actual condition of the engine. Bore clean and smooth? Piston? Bearings, etc. You may also want to consider the general condition of the bike. Consider, when you are all done, you will have a very expensive 25 year old motorcycle. This is not impossible but it will be an involved expensive project.
Mar 21, 2013 | 1989 kawasaki ZXR 250
How Do I change the clutch on a 1986 240 Volvo station wagon?
You do not need a simple "solution" from an online forum. What you need is detailed service information. I would recommend spending the small fee (under $30/year) and subscribing to the service information for your vehicle at alldatadiy.com. There. you will find step-by-step instructions along with diagrams and lists of any special tools needed to complete the task.
Apr 08, 2012 | 1986 Volvo DL
Please help western australia.britax trailer lights not connected properly.this is how currently connected.left hand trailer light top pin yellow,side pin green,bottom left pin brown,bottom right pin...
plug wiring is in
the following web site
ww.narva.com.au
the site is very specific for 7 pin , 6 pin and rectangular to round 7 pin
the small tag that you have to use to put the plugs together is identified at the top oh the round plugs
you can get the site by googling and typing in ---trailer plug wiring australia
Apr 02, 2017 | GPS
Little tike wagon wheel replacement
Did you solve your problem. I have the exact wagon, and need to replace all four wheels aswell.
Any info is appriciated.
Jul 26, 2010 | Little Tikes Adventure Wagon
How do i install a wiring harness for a trailer on a 2002 ford focus wagon?
  • Loosen and pull back the carpeting in the back of the trunk behind the taillights.
  • Step 2 Remove the plastic wingnuts that secure the taillight to the vehicle's body.
  • Step 3 Separate the taillights from the vehicle's body, but do not disconnect the wiring.
    Installing the Connector
  • Step 1 Examine the wiring harness on each taillight. There will be a plastic connector on each side that must be separated to insert the wiring harness connector.
  • Step 2 Thread the trailer wiring connectors through holes in the body behind each taillight. Follow the instructions provided with the connector to determine which connector belongs in which side of the vehicle.
  • Step 3 Insert the wiring connectors into the vehicle's wiring harness.
    Reinstalling the Taillights
  • Step 1 Push the taillights into position against the body and reinstall the plastic wingnuts that secure them. Be careful not to crush the wiring.
  • Step 2 Route the trailer wiring underneath the carpeting in the trunk, so that the trailer connector can extend out between the trunk lid and bumper when in use, and be tucked into the trunk when not in use.
  • Step 3 Reposition the trunk carpet over the taillight housing.
  • Jul 02, 2010 | 2002 Ford SVT Focus
    Need coupling that goes on the bike that is towing. Where can I find the part? In Step PF-250 Pathfinder
    Call Instep at 800-242-6110 select option for replacement parts. They helped me find a replacement spring coupling for a bike trailer that is 7 years old. Hopefully they can help you find the coupling you need.
    ddtapp@gmail.com
    Oct 27, 2009 | InSTEP PF250 Bicycle Baby Bike/Biking...
    Wiring towbar for t25 volkswagen
    Hi Paul,
    This should help,
    Plug Types/Application
    7 Way - RV Trailers, Horse and Utility Trailers
    6 Way - Horse, Stock and Utility
    4 Way - Utility Trailers
    Columns are Color, Function, Mark on the plug.
    Seven wire Trailer plugs
    Horse, stock or utility trailers:
    White = Ground - 1
    Blue = Electric Brakes - 2
    Brown = Tail and clearance lights - 3
    Black = Battery, aux power - 4
    Yellow = Left turn/Brake - 5
    Green = Right turn Brake - 6
    Orange or Purple (not both) = Auxilliary or Reverse - 7
    Recreational Vehicle:
    White = Ground - 1
    Green = Tail and clearance lights - 3
    Red = Left turn/Brake - 5
    Brown = Right turn Brake - 6
    Yellow = Auxilliary or Reverse - 7
    Six wire trailer plugs:
    White = Ground - GD
    Yellow = Left turn/Brake -LT
    Green = Right turn Brake -RT
    Brown = Tail and clearance lights - TM
    Red or Black (not both) = Battery, aux power - A
    Blue = Electric Brakes - S
    Recreational Vehicle: (color, use, plug mark)
    White = Ground - GD
    Brown = Right turn Brake - RT
    Green = Tail and clearance lights -TM
    Black = Battery, aux power - A
    Red = Left turn/Brake - LT
    Four wire plugs:
    White = Ground
    Ground should be 10ga.
    Others 14 ga
    Best regards
    Mike
    Sep 15, 2009 | 1986 Volkswagen Wagon Camper
    Installing a 7-pin trailer towing recptical on a 1991 Ford F150.
    I believe you can look up the manufacturer of the trailer plug kit and find the wiring diagram there. On alot of the trailer plug kits, they have pics and diagrams in the package. The 7 pin plug (truck side) is available with the pig tail set up that plugs directly into the wiring harness for the lights. Then all you would have to worry about is the 2 wires for the electric brakes.
    Nov 29, 2008 | 1991 Ford F150
    The Step2 Company Tag Along Trailer Plus  Logo
    186 people viewed this question
    Top The Step2 Company Toys Experts
    ray gallant
    Are you a The Step2 Company Toy Expert? Answer questions, earn points and help others
