Question about Brother HL-2040 Laser Printer
The paper light blinks continously on my Brother HL2040 laser printer even though I have paper in the tray. I have changed the cartridge and drum and changed the drive settings as someone else had suggested. Any idea as to what to do next.
  • 10 Answers
Did you try to reset the printer?
WIth the printer ON
Open toner-drum door
Hold GO button until all four lights are on
Release GO button
Close door
Printer will cycle through selftest and all lights will be reset
Posted on Apr 20, 2009
Printer says "drum end soon". I don't even know
The drum is the part of the printer that the image of what you want to print is stored on by a laser drawing on that drum. That drum is then charged with an electrostatic shock that will draw up toner particles from your toner tray that will eventually be transferred to a piece of paper that will be heated to fuse the ink particles on the paper. That drum is photo sensitive and eventually looses its ability to be charged. You will then have to replace that drum.
Feb 09, 2011 | Brother MFC 7840W Printer
HL2040 paper light blinking
Open the paper cassete and check if you have load paper in it.The second thing you can do is to open your printer front cover, remove the drum unit and check for paper jam inside the printer.
Oct 21, 2010 | Brother HL-2040 Laser Printer
HL2040 drum light is lit and printer not working. There is a new cartridge in place.
Replace the drum. It is the device that the toner cartridge sits in. You can also take out the drum and see if there is a 'slide' that cleans the drum, slide it back and forth several times and make sure it is 'locked' into the park area. Also refer to Brother manual or their web site for further answers.
Oct 05, 2010 | Brother HL-2040 Laser Printer
Red "Paper" light stays on; printer will not print.
Paper light flashing could mean several things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 11, 2010 | Brother HL-2040 Laser Printer
Brother HL2040 - Shading of toner all over my page when I print
The drum is a very sensitive part. Should not touch with bare hand, expose to light for long, etc. With what did you clean,it.
May 19, 2009 | Brother HL-2040 Laser Printer
Red paper light blinking
To replace the drum, just pull out the toner cartridge from the front, the drum is the part DR-2025 that is connected to the cartridge. Push down the little purple lever and remove the cartridge from the drum.
Jan 26, 2009 | Brother HL-2040 Laser Printer
Brother HL-2040 laser printer
Make sure to clean all the rollers you can see and make sure to check the paper sensor, and clean all rollers and paper paths with some Isopropyl Alcohol (AKA rubbing alcohol)
Sep 04, 2008 | Brother HL-2040 Laser Printer
Changing the toner on a brother HL-2040 in my office
It should be one unit??? look at the toner cartridge and look for a shiny cylinder that is the drum.
you can google brother hl2040 drum and click on images on the top right of google to see what it looks like
Aug 21, 2008 | Brother HL-2040 Laser Printer
Paper light on...!!
Turn the printer off. Take out the toner drum and cartridge. Remove the toner cartridge by pressing on the blue lever on the left side. Check for paper. Replace the cartridge. At the rear of the toner drum is a blue slide lever on the right side for cleaning the corona wire. Move the lever back and forth, left and right, about 30 times. Reset lever to far right side with arrows lining up. Set the drum and cartridge aside. Remove the paper tray and look inside for a jammed sheet of paper. Flip the back lid down and check for paper. Snap the back lid up, replace the paper tray, and replace the drum and toner cartridge. Turn the printer on. Press the ready button 3 times quickly. It should print a specifications sheet. If it does, try printing from your computer. If this did not help, Brother tech support is 1-800-276-7746. Robi
Nov 10, 2006 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
157 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
