Question about Psi Blue Max 2200 High Pressure Gas Power Washer
I need the part that the water hose connect to and then that part connect to pressure pump for a blue max 2200psi 1.6 gpm i thank it is a ck valve can you help me find that part thank you edward
Take the old one to a hardware store or homedepot and get a brass replacement
Posted on Jun 09, 2009
Red lion rl-mp16 pump not working
TO MUCH PRESSURE ON CK VALVE. DRILL A SMALL HOLE UNDER THE CK VALVE SO PUMP CAN START MOVING WATER AND IT CAN BUILD PRESSURE TO OVERCOME THE HEAD PRESSURE ON CK VALVE. AN 1/8" HOLE BELOW CK VALVE ON NIPPLE CONNECTING PUMP DISCHARGE TO CK VALVE, SO WHEN THE PUMP STARTS IT IS NOT PUSHING AGAINTS A STATIC HEAD. CAUTION: DONT DRILL HOLE SO THAT POINTS TOWARD FLOAT, KEEP IT LOW ENOUGH " UNDER WATER" SO THAT IT WONT SPRAY OUT OF PIT.
Apr 10, 2014 | RED LION rl-mp16 sump pump,utility,1/6...
Craftsman 2200psi powerwasher does not have much water pressure, why.
This could be several things. There is a bypass valve that opens when you are not using the sprayer. This keeps the water from causing problems by building pressure. IT dumps the water back to the suction side of the pump from the output side. IT might be out of adjustment or it could be stuck open. The other thing is that the valves in the pump itself are not closing.
May 18, 2013 | Garden
We have a new honda gx390 pressure drain cleaner with bertolini pump we can not get max pressure to the hose can you help
Assuming that you have a pressure gauge to determine actual system pressure. Without pressure gauge, you could use the sound of the engine as test for capacity pressure (if engine and pump are paired correctly, engine will labor at full throttle under high pressure). Using your machine at rated capacity will decrease the life of the unit. Better to use at 75 ~ 80 percent of cap. (2500psi on your unit). Pressure is developed thru the restriction of the tip/orifice assuming that the pump is working correctly. Tip should be correct for the capacity of the pump. Check the pump capacity for gpm (or test by removing tip connect water supply, then with engine running, catch water in bucket for exactly one min. and measure quantity). Example, 4 gallon per minuite should use a tip with 4gpm markings. If wrong tip size is used, (too large, low pressure, too small, pump will go into unload condition resulting in low pressure) . If thru testing you determin that the correct size tip is installed, suspect valves or unloader. Leaking valves or orings that seal valves will cause low pressure and also cause a pulsating sensation. Worn unloader will cause pressure to rise and fall in a slow cycle. Good luck with your repair
Apr 26, 2011 | Honda Pressure Washer PSI 3000
Craftsman Pressure Washer 580.752160 reagent/chemical not being dispensed when wand in low pressure position.
It is very common for the chemical injector valve on these to get gummed up from residual soap sitting in the valve. To clean it follow the chemical hose back to where it attaches to the pump. There will be a hex headed hose barb attached to it. Remove the barb from the pump. Underneath it you will find a spring and a ball bearing. Rinse the parts thoroughly and reassemble. You should also check the chemical strainer that goes into your chemical bucket. They can also become clogged and should periodically be cleaned.
Sincerely,
Aron Kerr
Landa Northwest, Inc.
www.landanw.com
Mar 07, 2011 | Craftsman 2700 Max Psi Pressure Washer 23...
No pressure, the inlet filter is clean, all hoses and connections are tight, oil levels are correct, hose size to pump is correct with no kinks. Has the pump gone?
In this case it sounds as though either your unloader valve has failed, the water seals have failed or the check valves in the pump need replaced. Unfortunately there are no tests that can be done on this unit to verify which component has failed because it uses an integrated unloader valve. The only way to tell which component has failed will be a visual inspection of the internals of the pump by a trained service technician.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
Mar 02, 2011 | Karcher 4000 PSI 36 GPM Gas Pressure...
Low Pressure
I worked at a tool rental while attending college and had the opportunity to work on a variety of pressure washers, however, they were of the commercial type. Commercial washers are slightly different in that they usually have seperated components for easier service. Attached to the pump by fittings or rubber hose were the pressure regulator (which has the bypass unloader inside), chemical injector, pressure gauge as well as the hot water release safety all external to pump. Your pump has all these components in one case. By far the most troublesome component is the pressure regulator/unloader which when failing will result in low pressure because it will bypass water back into the intake as you suspect is happening to yours. Here are a few things to check. I believe that your pump is 2500 2.4 gpm. Test gpm water capacity by running pump normally with hose and proper tip attached. Spray water into bucket for one minute and verify that you are pumping 2.4 gallons of water (or what ever gpm your machine is rated). Measure the amount of water that your machine delivered. If it delivered proper gpm and pressure is low then problem could be worn or improper tip. The pressure is created at the tip and pressure will drop as the tip wears. As the unloader/bypass wears, water will bypass at a lower pressure. (Try lowering the pressure regulator all the way ) If water measures less than rated delivery than the machine is bypassing water due to worn regulator/bypass, checkvalves pitted, oring in front of checkvalve worn or cut or missing, or body of pump where checkvalve/oring seat is pitted allowing water to leak past valve. The cap that is removed to access checkvalve must presses against checkvalve with enough force to prevent water from leaking thru oring and body of pump. Examine checkvalves and orings with maginfy lens and look for pitting. Valves surface and orings must be very smooth and tight fitting to work properly. Body of pump where checkvalve oring snuggs against must be very smooth. Any surface where oring seats must be smooth. As water bypasses it cuts metal and orings just like a leaking faucet so look for cuts in metal and rubber. This info and my experience is better suited for larger pumps and higher pressure but maybe it will help. Good luck with your repair.
Jul 11, 2010 | Karcher 2500 PSI Pressure Washer
Power Washer has no pressure, any ideas
1. If you have an inlet chemical injection valve make sure that the hose is intact and that the valve is closed.
2. Purge all air from the line by holding the nozzle actuation lever open until all air has been purged. When you connect the water supply hose turn it on before connecting the high pressure hose and let the unit self purge to the pump outlet high pressure hose fitting. Then connect the high pressure hose.
3. You could have a stuck spring and ball inside the high pressure head of the pump. You can tip the unit on its' side and add a substantial amount of WD-40 to the water supply hose fitting in an attempt to free the springs and balls.
4. Try BRIEFLY running the unit without the hose connected to see if there is high pressure water ejected from the high pressure fitting.
5. Inlet water screen at hose connection is clogged (hose screen and rubber) Check screen for debris.
6. The water strainer is clogged. (Almost looks like an LPG regulator just after but in line of the supply hose connection to the pump)
Order of troubleshooting
1, 2, 5, 6, 4, then 3.
Thanks for using FixYa!
Kelly
Mar 19, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
No pressure. Have cleaned inflow filter, checked water supply and cleaned and lubed the uploader valve.
if there is water comming out of the back of the pump then your piston seals need replaced , if the lace vibrates then one or more pump valves are blocked ) theres 6 in total /in pairs ) , try running the machine with no hose/lance connected as the lance nozzle often blocks up /malfunctions
hope this helps , if it does please vote
Nov 13, 2009 | Alfred Karcher K2400HH 5 Hp 2.5 Gpm @ 2400...
Had the Northstar 3000 psi Pressure Washer for 2 months and it started leaking oil from the pump during use. Took it to Northern and they are replacing the pump under warranty but said it was likely...
It is easy to check if your hose and quick connects are supplying enough water to the pump. Your pressure washer gallon per minuite requirements are printed on the machine and also on the pressure tips in GPM. Your post indicates 2.5 gpm but check your documentation of GPM. Next remove the tip from the wand and connect your hose with current quick connects to the machine. Start engine and direct the pressure wand into a bucket for exactly one minute. Measure the amount of water in the bucket, it should be very close to stated gallons. Do the same test with tip installed and compare measurement. If pump is starving for water you will not get proper amount of water in the bucket and the water hose will collapse. Two to four gallons of water per minute is not very demanding and should be delivered even with very small opening. You can even just direct the hose into the bucket for one minute and check how much water your hose is capable of delivering. I believe that you will find no problem with water delivery to pump. I would certainly enlighten Northern with your findings and question their evaluation. When you start using your pressure washer again try using it at lowest pressure to get the job done. Lowering the pressure to about 75% of max will increase the life of the pump and engine. Good luck with you pump
May 08, 2009 | Northstar Pressure Washer 3000 PSI
Psi Blue Max 2200 High Pressure Gas Power Washer Logo
170 people viewed this question
Top Psi Garden Experts
John Trevino
fordexpert
Jay Finke
Jay Finke
Are you a Psi Garden Expert? Answer questions, earn points and help others
