Question about Kenmore Elite 45986 Front Load Washer
Won't spin. Error code F25 - Kenmore Elite 45986 Front Load Washer
  • 483 Answers
If you remove three screws along the bottom front the bottom panel comes off.
On the inside, on the right wall, is a plastic bag with a paper labeled "FOR SERVICE TECHNICIAN ONLY".
This has a section titled "FAILURE/ERROR DISPLAY CODES" with all the error codes along with an explanation and recommended procedure. For F25, this is:
DRIVE MOTOR TACHOMETER ERROR
If the control is unable to properly detect motor speed, the machine shuts down.
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
Possible Causes/Procedure
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
2. Unplug washer or disconnect power.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
Posted on Apr 18, 2009
SOURCE: Whirlpool Duet Washer Trouble Code F25
Best Solution is to return it and buy another kind like LG or something
Posted on Mar 01, 2008
SOURCE: F25 error code
this is scary. I got a brand new whirlpool duet sport I ordered from Costco.com. After 19 days of waiting for delivery it finally arrived and was installed by the whirlpool dlvy people. I read the instructions and started my 1st load within an hour of being installed. It never worked. Ok it work 6 mins and stopped on every cycle I put it on and then I got the error code 25. I called their customer svc number and they could not even tell me via the phone what that meant. I am suppose to have another delivered here HOPEFULLY next week but after seeing others having repeated problems I do not know if I should just say no take it all back.
Posted on Jul 26, 2008
huuum
  • 750 Answers
Hello twelsh2
Welcome,
You said, you started my washer and after a few minutes I'm getting this F25 code. Water starts to go in but it never starts washing. Any thoughts?
This is what F25 is telling you.
Condition
If the control is unable to properly detect motor speed, the machine shuts down. If a failure occurs during high-speed spin, the door unlocks after 3 minutes.
Check and Repair
1. Verify the shipping system including shipping bolts, spacers and cables are removed.
2. Unplug washer or disconnect power for 5 minutes (Rests the system)
3. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations
If you can not find the fault , Please call service.
We have service sponsors available in your area here in our web site if you need one!
Let me know what you find!
Huuum
Please remember to leave a rating!
Posted on Oct 13, 2008
Fame_Guru
  • 483 Answers
SOURCE: Fault code F25
I got this working for many on this site :)
Thanks
Fame !
Posted on Jun 16, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore HE2 plus front loading washer f25
F25 indicates a possible drive motor tachometer error. (NOTE: The tech sheet is located behind the front quarter panel– remove the three hex head screws at the very bottom to remove the panel. The tech sheets will be folded up in a little plastic pouch.
The f25 error code is a motor tachometer error. To determine the problem you will have to remove the top cover and the front access panel. On some models, the rear panel will have to be taken off for easier access to the motor control. Now with the washer-unplugged remove the each plug one at a time and make sure the pins in the connector are not bent then reseat them on the board. Now retest the washer. If the washer still fails, you will need a meter to ohm the motor.
With the washer unplugged, locate the motor harness. Now unplug the motor connector to ohm the motor. Follow the list below to check the motor.
* Pin 1 to 3 6 ohms
* Pin 1 to2 6 ohms
* Pin 2 to 3 6 ohms
* Pin 4 to5 115 ohms
If the readings are close to what is listed above the motor is fine.
Live voltage checks are dangerous, and possibly deadly. Exercise caution at all times. If you are not comfortable working with live electricity I suggest you call an experienced service technician. I have provided you with a wire diagram with what the voltages should be. If the voltages are correct I would then recommend that you replace the motor control.
http://media.fotki.com/1_p,ssqftgqdqbftqgbxgtqsskgwtqkq,vi/sbbsgkqrgxstbrqrgwf/1/1303472/5961857/image5533851340308453439img-or.jpg
http://media.fotki.com/1_p,ssqftgqgtstgdfrxgtqsskgwtqkq,vi/wwkfkbqwwxkftrskdkw/1/1303472/5961857/image1769329000959650960img-or.jpg
http://media.fotki.com/1_p,ssqftgqbrdddksdxgtqsskgwtqkq,vi/stbrqrgwfxsbdkgqfbr/1/1303472/5961857/image5269611314094350944img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
My whirlpool front load washer will not spin out. its showinf error code F25
According to the tech sheet, F25 indicates a possible drive motor tachometer error. (NOTE: The tech sheet is located behind the front quarter panel- remove the three hex head screws at the very bottom to remove the panel. The tech sheets will be folded up in a little plastic pouch. Since there a various reasons for your problem, I just can suggest starting point since there is a code displayed.
Dec 23, 2016 | Whirlpool Washing Machines
F25 code on 3000 series maytag washer
Google search brought up:-
F25
A serious and difficult fault to repair. Call a technician.
Nov 13, 2016 | Maytag Washing Machines
Error code f25 replaced inlet thermador
call a repairman we do not know what you have .
Mar 16, 2016 | Washing Machines
F25 error code
The "F25" error code means the control board senses the inlet thermistor shorted. The inlet thermistor is a part of the hi-limit thermostat which is located on the heating element box.
- The hi-limit thermostat kit Part number: AP3094323
Read more: http://forum.appliancepartspros.com/dryer-repair/54078-whirpool-duet-dryer-error-code-f25.html#ixzz2n2Rmgm7a
Dec 10, 2013 | Whirlpool WED9400S Electric Dryer
Front loader maytag stop in middle cycle give error F25
Remove your service panel and look for your tech sheet inside a jacket in the inside of the service panel. An F-25 is usually a broken wire between the main control and the motor control.
Oct 09, 2011 | Washing Machines
I have a F25 code pop up and it will not spin
If this is the washer and not the dryer then error code:
F25 = DRIVE MOTOR TACHOMETER ERROR
This is a major error you can try some of the items listed below?
after 3 minutes.
cables are removed.
6. Check the drive motor for powered rotations.
Nov 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Fault code F25
Thanks
Fame !
Apr 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite F25?>
mostly likely need to replace speed control board
Oct 19, 2008 | Kenmore Elite 45986 Front Load Washer
F25 error code
Hello twelsh2
Welcome,
Condition
Check and Repair
Huuum
Sep 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
518 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
