DeLonghi Stiromeglio Compact PRO 300 Iron Logo
A
Anonymous Posted on Sep 22, 2013
Steam switch doesn't turn off - DeLonghi Stiromeglio Compact PRO 300 Iron
Circuit diagram for ESP2 singer steam press
I do not have access to specific circuit diagrams for the ESP2 Singer Steam Press. However, I can provide some general information that may be helpful.
The ESP2 Singer Steam Press operates by using an electric heating element to heat a water reservoir, which produces steam to press clothes and fabrics. The electrical circuitry of the steam press includes a power switch, heating element, thermostat, thermal fuse, and indicator lights.
The power switch controls the flow of electricity to the steam press, allowing the user to turn it on and off. The heating element heats up the water in the reservoir, producing steam that is released through a pressing plate. The thermostat controls the temperature of the heating element, ensuring that the water is heated to the desired temperature. The thermal fuse acts as a safety device, preventing the steam press from overheating and potentially causing a fire. Finally, the indicator lights inform the user of the steam press's current operating status, such as whether it is heating up or ready to use.
If you're experiencing issues with your ESP2 Singer Steam Press, it's recommended that you consult the user manual or contact a qualified technician for assistance. Modifying or repairing electrical equipment without proper knowledge or training can be dangerous and may cause injury or damage to the equipment.
I bought steam generator iron, iron work but doesn’t produce steam
Mix 1:1 water and white vinegar. Fill the water reservoir with mixture and hold the iron like you would normally. Keep pushing the steam button until steam comes out.
Nov 01, 2017 • Irons
My Rowenta pro precision iron steam station gets hot but doesn't steam. How do I get the iron to produce steam?
There are two cause. One the boiler resistance doesn´t turn of because of snap disc or bimetal thermostat fault or because a coil in the working valve (security valve). But if you can heard a click of opening movement of valve when you push the button it is able to be a thermostat.
No steam is coming out i think it needs cleaning
Some irons like Rowenta have a self cleaning feature. If yours doesn't make a solution of 1/2 vinegar and 1/2 water and put it in your iron. Plug it in and allow it to heat that up. keep working your instant steam button for a while. Hopefully the vinegar will help remove the calcium build up and let it work.
Nov 11, 2012 • Irons
Bosch TDS 1445/05 Sensixx station doesn't making steam
HI!
I HAVE AN Bosch TDS 1445/05 Sensixx AND THE IRON PLADE NOT WORM AT ALL. I CHECK THE POWER.I CHANGE THE THERMOSTAT/THE CONDENSER WITH THE LAMP/.BUT STILL NOT WORK. THE BOILER WORK GOOD.PLEASE HELP ME.WHAT CAN I DO MORE. THANK YOU
Oct 06, 2012 • Irons
I have an elitech steam generator. It has stopped producing steam and a blue light on the base flashes? I have never used tap water and have changed the filter but it still doesn't work.
follow the steps: God bless you
If a routine cleaning of steam vents, channels or holes does not clear the blockages, you can use a steam iron cleaner. This is a mild acid type of cleaning mixture specially prepared for such a job. No other form of fluid should be tried; it may damage seals or jointing compounds used inside the iron.Use distylled water very IMPORTANT.
God bless you
Jul 24, 2012 • Irons
3answers
Steam Press sp-660 will not steam with distilled water
Steamfast brand SP-660 steam press
contact Top Innovations
1-800-711-6617
2helpful
2answers
Steam Question
Found the answer. The steam button is built into the handle. Push the button and you have steam.
Top DeLonghi Irons Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a DeLonghi Iron Expert? Answer questions, earn points and help others
