Question about Nikon Speedlight SB-600 TTL Flash
Problem with SB-600!!!!
Its been 2 weeks that i got my SB-600 and saddenly stoped working!!! im just shocked! what happend to it?? i changed the batteries and still not workin! no sound no light no response!!!!
  • 2 more comments
  • marlin tci Jul 01, 2008
    Same problem as the above. I have the SD600 for about two weeks and it will not turn on.
  • amaynez23 Jul 09, 2008
    I have the exact same problem as above, and I already cleaned the battery cap with no success.
  • joenardo Aug 19, 2008
    I have the same problem. Just quit working. Has not been used that much. Cleaned contacts, changed batteries, no flash, no sound, nuttin'.
  • Arven692 Sep 07, 2008
    Had just three months. Will not turn on! Just stop working! Changed batteries, cleaned contacts as suggested and stil nothing! Seems this is common problem with this product, from what I see on this site. The Nikon SB 600 seems to be a poor quality product.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 206 Answers
Batteries may have leaked. Open battery chamber and clean ---especially the contacts situated at the bottom -- with pencil erazor. Blow out any loose bits and with new batteries try to switch the unit on.
Posted on Sep 25, 2007
SOURCE:
Changed batteries because some had corrision on them and now flash won't work at all?
Did you clean the contacts in the SB-600 when you discovered the corroded batteries? I use a pencil eraser followed by alcohol on a Q-tip. Make sure that all of the contacts are shinny and there is no remaining sulfate residue. If that does not solve the problem, there are other issues.
Aug 14, 2012 | Nikon Speedlight SB-600 TTL Flash
SB 600 wont turn on
Did you overheat it?
I know this is basic, but are you sure the batteries are good and installed correctly?
Jul 07, 2009 | Nikon Speedlight SB-600 TTL Flash
SB-600 Flash will not charge/everything else works.
check wire connection to capacitor measure voltage on it/
Be carefull high voltage!!!
May 12, 2009 | Nikon Speedlight SB-600 TTL Flash
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    SB-600 will never be on ready
    The capacitor may be weak, or there is a problem at the component level that is not allowing the inverter to reach full voltage.
    The flash will need shop service.
    Jerry G.
    Apr 20, 2008 | Nikon Speedlight SB-600 TTL Flash
    Sb 600 under exposure.
    You probably haven't changed the camera and/or flash back to TTL mode from wireless mode.  Make sure they are both set to TTL, not commander mode and you should be fine.  Note that the LCD on the flash will indicate which mode it is with a little graphic.  On the D70 you had to switch between TTL and Commander mode to set it up to work using the built in flash as the commander, so you just have to switch back.
    Jan 21, 2008 | Nikon Speedlight SB-600 TTL Flash
    SB 600 Not resetting...
    my sb 600 speedlight won't turn on. Do I need to reset it? It has fresh batteries. Never been dropped
    Speedlight SB-600 Display flashing.
    My SB 600 is doing the exact same thing. I used Nikon's online support service and this is the response I got: "I would try doing the 2 button reset on the flash and then see if that helps. Also disconnect any battery packs you may have connected especially if its a third party battery pack. If none of the above work then please service the speedlight" Sounds like they don't know what it is, either. I tried the reset to no avail. I'm not sure I want to send it in to have it fixed, since it does seem to be working. But you're right, it's annoying.
    May 17, 2007 | Nikon Speedlight SB-600 TTL Flash
    Nikon Speedlight SB-600 TTL Flash Logo
    338 people viewed this question
    Top Nikon Cameras Experts
    Ric Donato
    Ekse
    pictureman4u
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
