Question about Microsoft Metrologic MS3780 Fusion Barcode Scanner
METROLOGIC BARCODE READER WAS WORKING NOW NOT WORKING
SCARNER MAKES ALL THE RIGHT NOISE AND LIGHTS COME ON PUT NOT READING THE BAR CODE CABLE IS OK MODEL MS 3780
  • sst7 Apr 23, 2009
    HELLO I CHANGED USB PLUG PUT STILL THE SAME AS BEFORE
USB CABLE PLUG IS DAMAGED. HOW DO I REPLACE IT OR FIX IT. ITS VITAL TO OUR BAR CODES. CHARLES FRAZIER TEXAS FARM BUREAU 254-751-2580 THANKS
Posted on Apr 21, 2009
HOW CONFIGURE SCANNER VOYAGER MS9540 TO READ BAR CODE 39
THE BAR CODE IS READ CODE BUT NOT WRITE THIS CODE IN THE COMPUTER FOR EX: WORLD
Oct 23, 2009 | Metrologic Instruments MS9540 Voyager...
Hooked scanner up to new computer. Reads bar code
It sounds like you are connecting to a serial port and you are trying to scan into a program that needs keyboard data. Download the "Softwedge" program from the Metrologic website.
Mar 27, 2009 | Metrologic Instruments 9520 Voyager
Scanner makes the right nosie and the ligth come on when scanning but does read the barcode
What type of cable are you using to connect to a host?
You will need to configure the scanner for that type of connection, for example, usb, keyboard wedge, serial etc.
If you have purchased it new, you should have the configuration barcodes on the instruction manual, otherwise you wil be able to download the full manual from metrologic website.
Mar 26, 2009 | Microsoft Metrologic MS3780 Fusion Barcode...
Ms9535 bt not reading barcodes.
I'm using the same Barcode reader, the Metrologic MS9535 VoyagerBT.
The brief humming noize is called a "Rasbery tone" in the manual. It means that the barcode reader is not configured to read that kind of barcode, a barcode Code if you will.
There are many types of barcodes so you have to go to the Metrologic Website and get the Barcode Configuration tool to configure your barcode reader to read the type of codes you will be using.
Alternatively there is a book with configuration barcodes you can scan to configure your barcode reader manually.
Sep 28, 2008 | Metrologic Instruments MS9535 VoyagerBT...
MY METROLOGIC BAR CODE
What Is The Communication Method You used, usb or Kbw,
Aug 06, 2008 | Metrologic Instruments Metrologic Barcode...
Metrologic 9520 help...Please
Is it 13 digit barcodes you are trying to scan?
Also, does the cable go straight into your till (straight cable) or is it connected to you keyboard via a wedge?
Jan 19, 2008 | Metrologic Instruments 9520 Voyager
Default Barcode as the one used in the manual
I don't have a manual with me tonight .. but I think its a code 3 of 9 with a twist. If the codes in your manual only have 2 barwidths (narrow and wide) my memory is correct. If there are more than 2 barwidths its c128.
A standard c3 of 9 barcode has a start-stop pattern that decodes into an '*'
When '12345 is rendered into a C3of9 barcode the code actually holds *12345*
Barcode readers spot the code by looking for the *. Metrologic's codes are using a different start stop pattern. Again if memory services me they use a '#' so this makes the code "unreadable" by all but a verifier. It also means that most barcode production programs can't print it ...becuase they impose the standard for start/stop patterns.
The easy way to create one of those cards (for Metrologic) is to forget all the yadda I'm giving you. Instead figure out which pages you need . Next copy the pages of barcodes you used to get the setup correct. Then do a cut and paste job onto a blank page of paper. It goes quite quickly and the barcodes copy well.
If none of that helps then PCscan a page of codes in your manual and email the image to me. My eyeballs are (sadly) calibrated to read barcodes and I can quickly tell you what you've got.
Good lucuk
Dec 31, 2007 | Metrologic Instruments Voyager BT MS9535...
My RS-232 scanner beeps at the bar code but nothing appears on-screen.
The "Beep" just means that the scanner has been presented with a valid barcode. (nothing more) The scanner has probably not been set up correctly as this is a common issue. the settings need to be set correctly for your environment. you should have a code book with some bar codes in (part of the manual) which can set all the options within the scanner, There is an option to recall defaults here is the electronic manual ftp://ftp.metrologic.com/pub/download/productmanuals/00-02544.pdf
Oct 03, 2007 | Metrologic Instruments 9520 Voyager
Scanner blocks when scanning a bar-code
the metrologic scanner you are talking about has a barcode in the maual under the keyboard wedge section it is called stand alone keyboard this will cure your problem when you scan it. the reason being it fools the scanner into thinking there is a keyboard connected. hope this helps Pete
Aug 16, 2007 | Metrologic Instruments 9520 Voyager
Microsoft Metrologic MS3780 Fusion Barcode Scanner Logo
1,027 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
