Question about Dryers
The dryer is not blowing hot. One time it does, and with the back off you can see the orange heat and it gets hot...then you start it again and it just starts to get orange, then goes cold, almost like a switch turns off and keeps it from getting hot
  • traceyp Apr 18, 2009
    I have a small tumble dryer half the size of a normal one that is about 2 years old it is blowing cold air the model is zanussi TD62 .the quotes i have had is mad it would be cheaper if i bought a new one but i love this machine and if could would like to get it repaired for a relistic price
  • 77 Answers
It could be one of two things. If you have a meter, you can check them. First, the thermal fuse. It can be located when you take the back of the dryer off. Of course remove the power first. The thermal fuse looks like a little white disk with a tiny fuse in the center. Check continuity across it. The second thing is to check the over limit that is mounted to the housing of the element. Use the continuity test the same as the thermal fuse. Good luck.
Posted on Apr 18, 2009
Dryer wont heat for more than 10 minutes when cold
did you clean the vent line?THAT COULD MAKE IT RUN HOT THE AIR CAN'T BLOW OUTSIDE,BUT WITH THE DRYER HAVING HEAT WHEN IT STARTS AND THEN AFTER LIKE 10 MINUTES NO HEAT IT SOUNDS LIKE YOU HAVE BAD GAS COILS,WHEN THE COILS ARE STARTING TO FAIL THEY WILL WORK FOR LIKE THE FIRST 10 TO 20 MINUTES AND WHEN THEY HEAT UP NO GAS,WHEN THE COOL THEY WILL WORK AGAIN,I WOULD CHANGE THE COILS AND CLEAN OUT THE DRYER AND VENT LINE,THIS SHOULD BE DONE ONCE A YEAR SO YOU DON'T HAVE A FIRE AND YOUR CLOTHES WILL DRY ON TIME,EVERYONE THINKS SOMETHING IS WRONG WITH THE DRYER AND ALL THAT HAPPENS IS THE VENT LINE AND THE DUCT WHERE THE LINT FILTER SLIDES INTO FILLS WITH LINT AND THE AIR CAN'T BLOW AROUND GOOD ANYMORE,ALSO WITH A SHOP VAC VAC UP THE LINT WHERE THE BURNER AND MOTOR IS AND THEN SET THE VAC UP TO BLOW AND BLOW THE MOTOR AND GAS BURNER OUT,DO THIS AND YOU'LL HARDLY HAVE ANY PROBLEMS WITH THE DRYER
Sep 30, 2017 | Whirlpool Cabrio WGD6400SW 7.0 Cu. Ft. Gas...
Ge gas dryer heats but doesnt dry
if the flame is lighting you have lint blocking the air flow either in the dryer or in the vent line,also if you have a flame for the first 10 to 20 minutes and then the flame doesn't light you have bad gas coils located on top of the gas valve,when the coils are bad they can work for the first 10 to 20 minutes until the coils get hot and then they fail and you'll see the ignitor glowing orange but no flame,bad gas coils.then when the coils cool down they can work again.hope this helps.you can try removing the vent line from the back of the dryer and see if the flame stays on,if lint is blocking the air from blowing out the flame won't stay lit long enough to dry the clothes.
Dec 01, 2013 | Kenmore 73952 Gas Dryer
Not gettin enough heat
if the dryer is heating most likely it hasn't been cleaned out.you have to clean out the duct that the lint filter slides into and if the vent line is long remove it from the back of dryer,stick a leaf blower in the vent and blow all the lint outside,this should be done once a year and also vac out and blow out the cabinet where the motor is more so if it's gas,lint catches fire and you have an open flame in there.next time send brand name and model number off of machine you're having problems with.all a dryer does is move air,if there's a block somewhere it will take longer to dry the clothes,also if this is a gas dryer you could have bad gas coils,the coils will run for the first 15 to 30 minutes,when they get hot no more heat,when they cool down they will work again,next time you run if it's gas,start it,after 15 to 30 minutes look at the ignitor,if it glows orange but no flame the coils are bad.
May 15, 2013 | Kenmore Dryers
Sears 417.80042990 keeps blowing thermal fuse
Did you clean out the lint filter at the front, heat is the enemy. Clean out all lint from front, if you are handy, get around back and remove all lint and dust by blowing compressed air.
Sep 21, 2012 | Frigidaire FEQ332E Electric Dryer
I have a Maytag performa. It would not run at all. I checked the thermal fuse and found it to be kicked. I replace it as well as the hi limit. I put it back together, it runs now but it does not get...
You will need to replace the "gas valve coils" on the dryer. If you will post your model number, I can direct you to the parts you need.
Jan 14, 2011 | Dryers
Maytag dryer runs but doesn't heat up
1. Open the small access door in front of the dryer and start the heat cycle. The ignitor must glow a bright orange so that it is hot enough to light the gas. If there is no orange glow, then the ignior needs replacement.
2. If it glows then cuts off, then glows, again and cuts off, the thermocouple sensor wire is out of position. It needs to be very, very close to the ignitor. This thermocouple sends a temperature signal when it senses that the ignitor is hot enough to ignite the gas. Unplug the dryer. Re-position the thermocouple wire mount so that the thermocouple wire is almost touching the ignitor. You may also "bend" the wire. Plug power back on and heat.
3. If it still does not heat, then the automatic gas valve that is controlled by the thermocouple sending unit is broken. The automatic gas valve cannot be safely "fixed" and must be replaced.
Hope it's just the thermocouple wire.
Oct 05, 2009 | Maytag PYE2300AY Electric Dryer
Fuse blowing
Your exhaust vent is blocked.
Timed dry is High heat.
Permanent press is a medium heat and intermittent.
The dryer does not get as hot as often in Permanent press mode. Therefore the fuse does not reach critacal and blow.
Remove the vent at the rear of the dryer and run a timed load.
If it dries correctly, repair your vent blockage.
If not, repost and I will lead you to the next step.
Feb 19, 2009 | Kenmore Dryers
KENMORE 80 SERIES NOT HEATING
you need to check the heating element and the thermal fuse in the back of the dryer, they should be their. do you have an ohme meter, if not barrow one or you can pick one up cheep and lowes or homedepo .
Dec 13, 2008 | Kenmore 659 Electric Dryer
Dryers Logo
49 people viewed this question
Top Dryers Experts
