Question about Nokia 6680 Handheld
Bootimg Innitially, was running down of Battery and slow in processing but now it hangs at the first stage of booting before Nokia wecoming Logo appears.
  • 1 more comment
  • EGBUNU SHEHU
    EGBUNU SHEHU Oct 27, 2007
    thanks for your concern, i really appreiate. i tried but it didn't work.
  • vondat Nov 08, 2007
    my nokia 6680 frequently hangs..when i use my sms service, i have to switch it off first before i can be able to send it..additionally it has a slow processing time. do i need to have it reformatted? please help...
  • Anonymous Nov 12, 2007
    which eva way i turn it seems theres nothing anyone can do to help with this ph. A n6680. no new software updates available, tried looking at alternative ph like the 6681 model, HELP PLZ. Ph is still white screen no way to get into it at all. Any suggestions plz.
  • 3 Answers
Your phone probably needs a firmware ugrade which can fix many operational problems including the ones you have mentioned. Go to http://www.nokia.co.uk/A4226014 and download the firmware upgrade for your phone and install it to your computer.  connect your phone's usb to your PC and install the firmware upgrade software to your phone.
Posted on Oct 26, 2007
    Sergeant:
  • 452 Answers
U just remove memory card and then try to boot it up,,  and once save ur data in ur memory card only then restore ur phone then try,, aftr that flash ur handset from nokia care.
Posted on Oct 19, 2007
SOURCE:
Lenovo logo stuck issue
So what is the question?If you are saying that the boot process hangs at the logo screen, what do you see besides the logo? A floppy disk , non-bootable CD or a flash drive can cause this if the machine is trying to boot from any of these. Remove all removable media (CD's , flash drives, etc. ) and try again.
Nov 14, 2014 | Computers & Internet
My nokia 3110c phone is shutting down after i turning it on
hi,
it was tested by me in nokia classic series ,3110c ,3500c ,5130c etc blinking or hang only in NOKIA logo or handshake...no need to go to nokia care or cellphone shop to spend money..just do this tricks...
long press the *, 3, send, and power on...try up to 5 times and see for the result....
i hope it will help you ,thanks for trusting fixya..
Apr 13, 2011 | Nokia 3110 Cellular Phone
Can not be opened and if i opened it only the nokia logo and it will shut down
my phone can not be open..i do what you have said but it didnt work on my phone..somebody help me please?
Apr 13, 2011 | Nokia 7210
My nokia 6303 Hang while it start only nokia appear after tht dark screen appear no process further, cell cannot start.
Problem with the Nokia 6303i Cell Phone
  • My nokia 6303 Hang while it start only nokia...
Jan 08, 2011 | Nokia 6303i Cell Phone
Phone does not go past through the nokia animated logo then shuts down
Possible errror in the software and needs a reinstallation of the software.The fault should clear out.
Make sure the battery is good and the battery contacts are clean, if not this can also make the phone to shut off as the power requirement goes up when the phone boots up after the logo, hecne it can shut down if the battery is bad.
Check this out.
Sep 19, 2010 | Nokia 6120
Hape lambat sering mati mendadak
if your saying that your phone is slow than usual, have it reset to factory settings, if it doesnt work, there are some possibilities.
1::: LCD is dameged (including Display IC) making the display slow or delayed. 2::: UEM ic is damaged, making "processing" power slow 3::: FLASH IC is damaged also making "processing" power slow
all of these aren't user serviceable, then i suggest you take them in for repair, either from where you bought the phone or any authorized nokia repair shop.
Aug 18, 2010 | Nokia 1600 Cellular Phone
My n 72 is hang process is slow & battery back is low
hi
clear ur sms inbox nd save all ur data in ur memory card nd if it doesnt solve then u have to upload nokia n72 software for hanging problem and simply change ur battery for battrey problem nd if doesnt help then its a hardware fault...thanx
May 22, 2010 | Nokia N72 Cellular Phone
Slow boot time for Windows XP Pro
You can do that by using "MSCONFIG"
Click 'start' then goto 'run' and type 'msconfig' then click 'Ok'
That will open the Microsoft System Configuration Utility. You can then disable the unnecessary services and apps
For more information, please refer
http://support.microsoft.com/kb/310353
Dec 18, 2009 | HP Compaq Business Notebook 6910p
PC BOOTS HALF WAY
Try booting into safe mode. If it's a driver problem, safe mode will allow you to start Windows with only the bare minimum of hardware and drivers being engaged. To get to safe mode, press the F8 button on your keyboard during the Windows boot process until it takes you to a screen to let you select Normal, Safe Mode, Safe Mode with networking, etc. I would suggest not using anything other than just Safe Mode. From there, uninstall any software or new drivers that you recently installed. Alternatively, you can use the System Restore feature to rollback to a previous restore point.
Aug 10, 2009 | HP Computers & Internet
Nokia N72 hangs up
if yon know how to repair mobile so change boot ic othervice contact your nearet mobile repirer..
Jun 02, 2009 | Nokia N72 Cellular Phone
Nokia 6680 Handheld Logo
59 people viewed this question
Top Nokia Computers & Internet Experts
Anthony Ward
Anthony Ward
k24674
Ekse
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
