Question about Welding Tools
Stays hi idle all the time
3oo vantage with 21oo hrs, my machines problem is she will no longer idle down,plus the oil psi,engine temp and fuel gage bounces and continues to give a fauls reading,,,Hmmm
    President:
  • 1,723 Answers
Is the throttle linkage hung up or stuck? Other wise, the idle control board is bad.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 03, 2009
1986 dodge d100 225 engine dodge oil light goes off when idle stays on when giving it gas
It sounds like the oil sending unit is bad. the safest way to check it is to pull out the sending unit and install an oil pressure gage directly to the motor start it up, bring the RPMs up and see what the oil pressure is. Ideally you want at least 15 psi at an idle and prefereably anything above 25 psi at crusing RPM.
Apr 26, 2014 | 1986 Dodge Ram Wagon
What should the oil preasure gage read
Hi Mike, if your oil pressure gauge is acting eratic or your oil pressure light stays on you could have a faulty sending unit, gauge or air in the system or a restricted oil filter, start by checking oil level in tank and make sure it is between the add and full mark. With engine at normal operating temperature 180-230 degrees and the use of a 10 micron synthetic media oil filter, oil pressure will be 30-38 psi at 2,000 RPM and 3-5 psi. at idle. The oil pressure light is designed to come on at 2 psi. or less. To accurately test oil pressure remove oil pressure sending unit and install known good oil pressure gauge that reads 0-50, there might possibly be some plumbing required for hard to access points. If you are out in the middle of nowhere and there is no cell phone service and your oil pressure gauge isn't working and your oil pressure light is burned out, despair not, you still have one last line of defense left HYDRAULIC LIFTERS, as long as those tireless workers are quiet, you have oil pressure, maybe not much, but enough to get you down the road at a slow to moderate speed using the least amount of RPMS as necessary. Good luck and have nice day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 22, 2013 | 2003 Harley Davidson FXSTDI Softail Deuce
Engine starts , and dies. Only when weather is cold.
hello there
I looks like your oxygen sensor,Try to disconnect and then see what the car does?Let me know.You may need to adjust the fuel mixure,seem it is running a little rich that is why the car in idle goes up and down.
proporsche@yahoo.com
proporsche
Jan 09, 2012 | 1991 Porsche 911
What are the maintainance action in machine
Maintenance activities should be done at so many hrs of run time. Your manual should list recommended service hrs. Telling you to change oil or filters every 3 months may be wrong. It all depends on how many hrs it has run. Maintenance items include air filters,belts,oil in both engine and compressor, fuel filter and battery if equiped on the engine.
Nov 20, 2011 | Ingersoll Rand 25 CFM 175 Psi, 13 Hp...
93 jeep cherokee-while cruising down interstate jeep sudenly started jerking, stalling, and lose of power. I pulled over to station. checked oil level, pressure, temp, alt output--all ok. jeep will start...
I don't know engine size? The fuel pressures I found was 31--39 psi, 92--95. I would use a gage and check proper fuel pressure.
How long since over-all tune-up? Any applicable trouble codes?
Apr 28, 2017 | 1993 Jeep Grand Cherokee
Oil gage buries all the way past high. After driving with it like that for a while, the truck engine konks out and will not start. Last time we waited on the side of road for 40 minutes and then it started...
Do you believe oil gage? Oil psi sensor can go bad. If PSI correct then is PCV valve clear?
I'm more inclined to think you have some kind of electrical problem, false gauge, ignition quits or fuel delivery problem. Extreme high oil PSI would blow out your engine seals, leaking oil everywhere. When you get high oil psi, does removing oil cap make it drop? Do you have good clean oil and filter?
When it quits do you have spark, fuel to delivery system? (throttle body or fuel inj) High oil psi shouldn't make truck hard to start. Baffling.
Mar 09, 2010 | 2005 Chevrolet Silverado
What is the check gauges light
CHECK GAGES light (1) indicates a potential engine failure(low oil pressure, low coolant, coolant overheating) has occurred.
· Check gages and shut down engine. Gages should read as follows: Oil pressure 5 to 10 psi (34 to 69 kPa) at idle; Water Temp gage below 230 degrees (110 C).
· Check engine oil level (Para 2-11) if OIL PRESS gage indicates low reading. Check coolant level (Para 2-11) if Water Temp gage indicates high reading. Notify Unit Maintenance if levels are low.
If CHECK ENGINE light (2) is on, check engine oil pressure gage (3) and water temperature gage (4). If both indicate normal, proceed with mission and then notify Unit Maintenance. If either one does not indicate normal, stop engine immediately and notify Unit Maintenance
Oct 16, 2009 | 1999 GMC Jimmy
What should a 2002 Pontiac Bonneville oil pressure gage read at
at what? depending on engine temp and rpm, normal oil psi should read 30-40 psi at idle and at cruising speed of 1500 to 2000 rpm should read 60-70 psi. most bonnevilles from 1992 to the last year run of 2005 have the 3.8 liter V6 which was updated over the years.
Oct 13, 2009 | 2002 Pontiac Bonneville
Oil pressure gage
At idle, at operating temp is there any ticking from top end of engine? Are there any knocking noises brom bottom end?
If no noises, change oil and add some Marvel oil to clean out galleys. If that dosent work, change oil pressure sendingf unit. Also, if you have a mechanical oil pressure gauge, hook it up and take a direct reading. Oil pressure (in any vehicle) at idle should NEVER be less than 15psi. Generally in 4.0 jeep engines it's never less than 30, with a high reading at driving rpm of about 40-60! (but, you did not mention what engine you have)
Dec 27, 2008 | 2000 Jeep Grand Cherokee
Engine running hot
Check the condition of the coolant.
If you have any indication of oil, the headgasket could be bad.
Oct 14, 2008 | 1983 Jeep CJ5
Welding Tools Logo
89 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
