Question about Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF100 Fabric Cond not rinsing thru & PreWash lite flashing
Two things happening to me when I put a wash on. Firstly, the Pre-Wash light flashes constantly throughout Normal Wash cycles sometimes stalling the wash for up to half an hour and then to add to this my fabric conditioner doesnt seem to have rinsed through either. Can anyone assist? Have recenly moved into new house whereby the builder hooked the machine up to the water pipes in utility etc....
  • Finola Masterson Oct 01, 2007
    Found the suggestion very helpful thank you, however found out the reason why the machine wasn't working properly thanks to my Dad! Pulled out the machine to check the water mains pipe was hooked up properly etc as per suggestion posted to me.....when noticed that there was a major kink in the water-supply pipe to the machine! (Due to me pushing the machine right back into its place under worktop!)Once "unkinked" dare i say it, the machine has been working as per normal! Also, just an observation, watch out when using the likes of "colour catcher" sheets, as they can make their way out of drum and towards filters thus blocking/clogging water coming into machine if not put in a little net bag or something similar!!!
    Thanks for the help - great website, Im sure i'll be on it again!
  • jaredinoz04 May 19, 2009
    my hotpoint aquarius wma50 starts washing and after about 5 minutes it stops and the pre-wash light starts flashing. I have recently been fitting my new kitchen and have moved the washing machine around a few times, the pipes are connected and not kinked, i can hear the slight buzzing when the water is turned on. I dont know what it is but if it is the water solenoid where is and what does it look like as I am an electrician. I would be greatfull if you could advise me thanks Jared.
  • 209 Answers
This sounds like cold water supply not getting to the machine, test the supply from the house is working, is the machine buzzing slightly when it should be filling, if so the fault is the house supply to the washer, if the supply to the washer is fine, check the cold water solenoid for open circuit, thats about all it could be, if it worked fine before, if i have helped rate me please
Posted on Sep 18, 2007
  • Hotpoint Master
  • 744 Answers
Hotpoint Aquarius WF100.This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 02, 2013
SOURCE:
My hotpoint washing machine WF560 mini load and reduced creases lights are flashing and also the on/off light is also flashing, please help. Thanks
Heating eliment or PCB, is this when doing a prewash? or a normal wash excluding pre wash?
if you can manualy pump out and manualy rinse and spin, my guess is heating eliment is broke £20-£30
Jan 27, 2011 | Washing Machines
Hi my wf220 won't do a full cycle the prewash flashes all the time if i put it onto wash it just sticks on wash all the time but will spin if i just set it to rinse n spin or just fast spin could you help...
My guess is heating element, if its broke it wont heat water and because the thermostat does not detect hot water the machine does not move onto next step. i suspect you will not be able to do a prewash.
Part cost ££20 to £30
My machine has same problem but im struggling to pull out the eliment.
Jan 15, 2011 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint wf540 stopping on a rinse and spin and
check pump/filter/outlet hose for blockages. if ok, check pressure switch (disc shaped item at top of machine with 4? wires and a tube) by blowing into it gently - should hear clicks, then blow into tube to pressure chamber - should be clear.
Oct 26, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Wash enhance and on off light flashing.
solved it - kinked hose issue as well i think - hose had being lying loose behind machine - makes sense to attach hose to clips on machine.
Sep 06, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Completely dumb question
Hi, we have a hotpoint aquarius - the "fan" compartment on the left is for fabric conditioner, the blue thing is to save you measuring it out in the bottle cap. Number I is for prewash detergent (only if you're doing a prewash) and number II is the main detergent compartment, the one you would usually use. Hope this helps?
Jen
Jan 17, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WD440
On the power pcb panel, there is an eeprom. This gets corrupted and throws the machine into a frenzy. A replacement should include a new pcb and a new eeprom. Only from dealers unfortunately.
Aug 28, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WF000 Front Load Washer Logo
470 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
