Question about Indesit W 123 Front Load Washer
WIL103 stopped taking conditioner
Hi, All was well with this front loader, but for some reason on the Daily Wash cycle, it now just ignores the conditioner part. It also does this if I just try an extra rinse cycle. Everything else is fine, I've had the tray out and there's no blockages.
  • nert61 Sep 18, 2007
    I'll be right back in the morning when I put the washing on! Thanks for taking time to post an answer. Watch this space! :)
  • keith547 Dec 13, 2008
    i have the same problem only slightly different, when its in a programme cycle it seems to get stuck on the empty and rinse bit. it will happily aggitate the drum all day if i didnt turn it off and turn the switch round to rinse manually. filters clear and the cold supply is fine as it does it manually. if the switch is up the shoot where can i get another one?
  • 209 Answers
Bit of a common problem, this sounds like the cold water supply not getting to the machine, test the supply from the house is working, is the machine buzzing slightly when it should be filling, if so the fault is the house supply to the washer, if the supply to the washer is fine, check the cold water solenoid for open circuit, thats about all it could be, if i have helped rate me please
Posted on Sep 18, 2007
How do I remove the locking function on my washer when already begun cycle so I can add an extra item I forgot put in without having start again. Is it possible?
On later model front loaders they have a Stop & Add button so when engaged you can add more to the wash load. Unfortunately earlier washers don't have it so once the cycle starts that's basically it. That's the reason some people prefer top end loaders as it not a issue
May 28, 2016 | Washing Machines
My GE front loader will filll but won't stop filling and wash, it just keeps filling then clicks to pause
Does it stop filling if you stop the cycle or do you need to turn the faucet off?
Nov 28, 2012 | GE Washing Machines
I have been given an LG WD 1049c front loader and am not sure which section the powder goes in. The tray has three sections?
A quick and easy way to find out which tray is which is to pull the detergent drawer out just so that you can see into it. Start a pre-wash and see where the water runs in, then advance to the main wash and observe. Finally start a rinse cycle and where the water goes in is where the conditioner/softener goes.
In a few cases I have come across, the pre-wash tray shares with the conditioner/softener part but the pre-wash powder goes in the front and the softener in the back.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 01, 2011 | Washing Machines
I have a whirlpool awm 8121 6th sense front loader. when i select the cycle, usually rapid, and press the start button the machine commences to fill with water. when it comes time for the actual washing...
If your machine is reasonably old, perhaps take a look at the bushes of the motor . Before that, take the manual and run the test cycles by following the instructions; it might provide you with answers
Oct 14, 2017 | Whirlpool AWM8123 Front Load Washer
Maytag front loader HE washer.
cheak your tube if there is a nail or an object is stuck in one of the holes
Jan 24, 2010 | Maytag MAH6700A Neptune High Efficiency...
Washing cycle on a 40degree op. takes more than
Don't forget that the reason you bought a front loading washer is for the efficiency of the washing. In other words, front loaders use less water and get clothes cleaner without all the harsh beating that the older agitator units do.
If you're using any of the pre-programmed wash cycles, you might want to tgry another cycle to see how it does for getting your clothes clean with a shorter cycle.
If you check your owners manual, it should provide the cycle times for the various wash and water temp settings. The colder the water you use, the longer the wash cycle typically is, since it takes more agitation and time to get clothes clean, especially with front loading machines. Hope this helps.
Jul 28, 2009 | Whirlpool WFW9200S Front Load Washer
I have the neptune front loader. The lock light wont come on and the door wont lock. During a wash cycle the water just started comming out of the door. If I hold the stop/start button manually the light...
hi there,
you have a door latch problem. the reason you can still push on the button is because this particular washer has a time delay function. i would recommend taking a look at the latch itself and possibly the wax motor that runs the latch.
Dec 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing macine indesit wil103
i need a intrution manual for my indesit wil103 washing machine
Jul 09, 2008 | Indesit W 123 Front Load Washer
Washer keeps beeping
Jun 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Indesit W 123 Front Load Washer Logo
109 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
