Question about ASUS O Asus O - Eee Pc 1000 40G - Pearl White, Linux PC Notebook
How to adjust dark/light on built in webcam?
Neeewbie here!
how do i adjust dark/light on built-in webcam (1.3 megapixels) using pre-installed skype 2.0?
problem: too dark, how do i lighten?
pleeease explain in eeeasy steps....thank you!
(asus eee pc 1000 linux/xandros/easy mode)
How to activate the webcam
Easiest way to activate the webcam I've found, is not to try hunting for the driver, etc... it's usually pre-installed for laptops or netbooks with built-in cameras, best way is to download applications like Skype with video chat, install the software, and then test using Skype. That usually works.
Mar 28, 2011 | Acer Aspire One AOA150-1784 Netbook
During skype connection the picture freezes
1) Ensure you are running Skype 5.0, earlier versions (4.2) are known to have this problem. www.skype.com
2) Ensure you have installed the latest drivers for this device through windows update.
Feb 28, 2011 | Microsoft LifeCam Show Webcam - 2.0...
My webcam is really blurry on skype and no one can see me . Help Me!!
all you can do is ensure the lens is clean without removing the bezel and manually adjusting the focus. if its less than two years old its enough reason to have acer fix it if you give them a call.
Feb 25, 2011 | Acer Crystal Eye webcam
We have connected the webcam to the c.p.u. but the system is not detecting the device... inturn webcam is not working on the system.. plz help us providing the correponding drivers
Visit the Logitech website and browse the photo gallery for your model and click on the photo to navigate to the support page.
Note - Older models on page 2 - look for the link at the bottom right of page 1 and click on it "Still can't find your product?"
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
In addition to the Logitech installer you will need to check the support software - Microsoft DirectX . This comes pre-loaded on most Windows computers but has to be updated - I am currently on version 11
To start the DirectX Diagnostic Tool, click 'Start', click 'Run', type dxdiag in the Open box, and then click OK
Run through the tabs checking the 'notes' windows for information
The version will be shown on the 'Systems' tab
Procedure to re-install Logitech software
Close all programs while uninstalling - downloading and uploading software
Disconnect your webcam
Uninstall the current webcam software on your computer
Restart computer
Download the Installation package from Logitech
Run the installer and choose your options during the installation - You may not want Logitech Chat but the Desktop icon for the webcam toolbar is a must.
Connect your webcam when prompted.
SKYPE SET UP
Connect your webcam
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Not working ? - troubleshoot your drivers and software - get your cam working before moving on
Working OK ?
Set your webcam mic as default ( if it has a built in mic)
Plug in the webcam
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO SKYPE
Connect webcam
Its good practice to disconnect and re-connect your webcam before you start (To reboot the webcam software) - if you have been using it elsewhere the SKYPE software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Start Skype.
On the 'Tools' menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Run down the list setting your defaults
Select your webcam as the default microphone.
Make a free test call
Click 'Save'
In the navigation pane of the Skype Options window, click Video Settings.
This will launch your webcam
Adjust quality of picture in 'Settings'
Check the correct webcam is shown as default
Click Save
Test your webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site:
http://support.skype.com (http://support.skype.com)
Before opening Skype disconnect your webcam for a couple of seconds and do not open your cam for a preview but wait and let the Skype software take full control when you start a video chat.
Nov 11, 2010 | Logitech Quickcam Chat Webcam
Logitech camera shuts off when on skype
Make sure you have the very latest software
In addition to the Logitech installer you will need to run the support software - Microsoft DirectX . This comes pre-loaded on most Windows computers but has to be updated - I am currently on version 11
To start the DirectX Diagnostic Tool, click Start, click Run, type dxdiag in the Open box, and then click OK.
Restart computer
Configure to Skype
Working OK ?
Plug in the webcam
TEST SPEAKERS
Restart computer
CONFIGURE TO SKYPE
Connect webcam
Start Skype.
Click 'Save'
Click Save
When using Skype - do not run the Logitech software but allow Skype full control.
Aug 29, 2010 | Logitech Webcam
Pixelation problem
The problem is on your end. You can try several things. 1) if your webcam has a ring on the front of the lens you can turn it to focus. 2) connect your computer to the router/modem with an ethernet cable instead of wireless so you get better bandwidth. 3) try the tips in the article How To Improve Your Webcam Video Quality, especially the lighting tips.
May 09, 2010 | Microsoft LifeCam Show Webcam - 2.0...
How do i turn on webcam on a acer 3690 laptop
The built in webcam is always on. You just have to run the application, 1) that was pre installed on it to take videos using it. and 2) while using an IM like Skype or Yahoo Chat etc. But they have to be configured to use it when you start a talk session with the other party. In Skype go to Tools->Options->Video. Here you can configure your webcam to startup when you are talking on Skype. And start video talk.
Nov 10, 2009 | Acer Aspire 3680 Laptop
IceCam2 video is very dark
The manufacturer does not list this cam as compatible with Skype. However you can try adjusting it with the Skype settings.
Skype>Tools>Options>Video Settings> Webcam settings>
Mar 14, 2009 | Macally IceCam Personal Web Camera
My web camera not clear
To clear the picture's focus, you should be able to turn the ring on the front of the camera. Did your computer recognize the device when you plugged it in and install all necessary drivers? If you're trying to use it with skype, try to use it just with windows XP and see if there's still a problem. If not then it's skype, and not the camera. Also in the settings of the camera program you can probably adjust the brightness. Try setting it to the highest setting.
Nov 07, 2008 | Logitech QuickCam Messenger Web Camera
ASUS O Asus O - Eee Pc 1000 40G - Pearl White, Linux  PC Notebook Logo
480 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
