Question about Sony KV-36FS12 36" TV
NEED TO ADJUST VERTICAL SIZE FOR PRECISION TV , MODEL # PTV-2145
I need a screen for a Sony TV KP-51WS500. Is there any make that's interchangeable with my model?
Your ptv Projection TV's screen isn't proprietary to SONY.
So You might try and find a CL listing for a non working PROJECTION tv / or post a CL ad looking for one with the same SCREEN size (measure VERTICAL and HORIZONTAL size ) as a virtually obsolete technology you might find a give away (if you are willing to transport and dispose of) .. you likely will be unable to find a screen to buy online / besides because of the dimensions and size of the non bendable screen it probably would be cost prohibitive.
Mar 30, 2018 | Sony Televison & Video
How do I adjust the Vertical size or position?
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 23, 2016 | Zenith SY2765S TV
Zenith TV B27A24Z, Vert Size Adjust
To do this adjustment, you should enter the service mode option. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 27, 2014 | Zenith Televison & Video
Tv no enciande
i have a (PTV) that it,s SMPS is not working i need to two thing.
1-shematic diagram of PTV.
2-shematic of STR x6954 or equivalent that used to this model.
model:SP-43910hex
SP-43R1hex/ha3
Nov 18, 2010 | Televison & Video
How to adjust vertical size my hitachi c29-r30sp
You could go into the user menu and look around to see if it has an adjustment. If not you will have to access the service menu for your tv. There may be a setting to adjust vertical size there. If that still isn't possible you may have to open the tv and look for a pot or a switch that can control the vertical adjustment. It may be by the vertical output circuitry. This could also mean that you have a defective component in the vertical circuit or inadequate voltage to that circuit.
Mar 11, 2010 | RCA F27440 27" TV
27 inch Zenith TV Vertical too big
If you are using a DTV coverter box, you may have changed the aspect ratio with your remote control. look for a button marked "aspect" or "picture size" use that to change size.
If you have a cable box, you may have a similar button.
Or you may find a picture size adjustment on your TV remote.
If you do not have "aspect" button on your remote try going to set up menu and look for picture size.
Older TVs used to have a vertical size adjustment at the back. look in the manual.
If none of the above, you have a biiger problem with the TV internal parts needing attention
Mar 03, 2010 | Zenith C27A24T 27" TV
Image adjustment for GE 24GP65
Yes you can adjust the vertical size in the service menu, but you must be carefull when doing any horizonal adjustment as this can shut down your set .
Dec 16, 2006 | GE 24GP653 24" TV
Need access to service menu to adjust vertical size
No service menu for this set. Sounds like you have a bad yoke winding on this one....accordianman
Oct 25, 2006 | Emerson SpongeBob SquarePants TV
Sony KV-36FS12 36" TV Logo
256 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
