Question about Toshiba Satellite M100 Notebook
System spyware my computer shows the message that the system has been affected by the antispyware applications and it will perform a bad impact on my computer,what to do
    Sergeant:
  • 457 Answers
Go here http://www.spybot.com install it and hen update it while you are online its free then get you the free Antivirus here http://www.avast.com good luck you will be cured if you use spybot believe me!
Posted on Sep 18, 2007
SOURCE:
How to stop pops-up ?when I open my internet connection so many pops-up about malicious pictures
Most of the spyware programs on the Internet that will infect your computer log the websites you visit so that they can launch pop-ups and advertise products for you to buy.
If you have recurring pop-ups caused by spyware that appear whenever you connect to the Internet, you will need to completely remove the spyware causing the problem.
The most effective way to remove all spyware from your machine is to use at least two different antispyware programs while your computer is in safe mode so that the spyware cannot open itself.
Navigate your web browser to a website that offers a spyware removal utility such as "Spybot" or "Lavasoft Adaware".
http://www.safer-networking.org/index2.html spybot
http://www.lavasoft.com/ lavasoft
Download and install the antispyware software.
Navigate to a second website and download a secondary antispyware utility.
Restart your computer and wait for the manufacturer's logo to appear on the screen.
Press the "F8" key repeatedly until a new menu pops up.
Scroll down through the list of options and highlight the entry labeled as "Safe Mode."
Open up the first spyware utility you installed earlier once the operating system has finished loading in safe mode.
Click on the antispyware utility's "Update Now" button at the left side of the window.
Wait for the program to finish downloading the latest spyware detection routines.
Disconnect your computer from its Internet connection either by unplugging its Ethernet cable or by powering off your wireless router.
Click on the "Search For Problems" button above the "Update Now" button.
Wait for the program to finish scanning your computer's hard drive for spyware, and then click on the "Remove Selected Problems" button.
Close down the antispyware program.
Reconnect your computer to its Internet connection.
Open the second antispyware utility you downloaded earlier.
Run the program's update feature and then disconnect your computer from the Internet again.
Run the program's scan, and then remove any problems it finds.
Reconnect your Internet connection and then restart your computer to finish removing the recurring spyware pop-ups from your PC.
Hope this helps
Nov 10, 2012 | Computers & Internet
Macbook pro and belkin router
Can you check if you have problems with your internet connection?
How about your browser? i recommend using mozilla firefox browser because i assure that it it the fastest browser.
If you have no problems with your internet connection probably you may want to check if your device are working properly.
Consider:
The type of Internet connection you use is the most important factor in determining your connection speed. The three most common ways to connect to the Internet from home are dial-up, DSL, and cable. If you have a choice, cable is usually the fastest, but both DSL and cable are faster than dial-up.
The health of your computer can affect your Internet connection.Spyware and viruses can definitely cause problems, but your Internet connection speed can also be affected by add-on programs, the amount of memory the computer has, hard disk space and condition, and the programs that are running.
Two of the most frequent causes of poor Internet performance are spyware and viruses. Spyware can slow your system by interfering with your browser and monopolizing your Internet connection. Spyware monitors your Internet use and keystrokes, which adds delays. The problem is compounded when there are multiple spyware programs running at the same time. If the problem is severe enough, you can lose connectivity altogether. To get your Internet performance back, you should regularly run an antispyware program to clean out any spyware infestation.
Computer viruses can also cause poor Internet performance. When a virus infects a computer, it installs computer code which will attempt to propagate itself, usually by sending copies of itself through e‑mail. Some viruses can multiply at the rate of hundreds of e‑mail messages per minute, which leaves little computing power and Internet connection bandwidth for anything else. Viruses often do not give any obvious indication that they are running, so it is best to run your antivirus software at all times.
Thank you : ) i hope my information works.
Please pm me if none of the options work. :)
Aug 08, 2009 | Belkin (F5D72304F5D7000) Router
My toshiba laptop will not load
Would suggest booting your system in Safe Mode and running anti-spyware (SpyBot) and anti-malware (Malwarebytes) software. Hope this helps.
Jul 12, 2009 | Toshiba Satellite A60 Notebook
All of a sudden pc gotinfected by trojan
Download Malware Bytes and do a scan and clean, it should remove MS Antispyware 2009.
Please post back here if you need additional help...
Apr 06, 2009 | Compaq Computers & Internet
How can I get rid of CA parental control? I never set it up!
AntiSpyware 2008 is a rogue anti-spyware program from the developers as Antivirus 2009. This program is advertised through misleading and deceptive web sites that pretend to be malware scanners that find infections on your computer They do this to scare you into thinking your infected, even though a web site can't possibly know this, in the hopes that you will download and install the AntiSpyware 2008 program. If you decide to install it, the program will scan your computer and come back with a list of security risks found on your computer that you cannot remove unless you first purchase a license of the software. It is important to remember that these people are preying on your fear and for the most part you do not have the infection they say you do.
Antispyware 2008 Automatic removal http://www.2-spyware.com/spyware-doctor.exe
Antispyware 2008 XP manual removal: Kill processes:
  1. application data
  2. secure solutions
  3. antispyware 2008 xp
  4. as2008xp.exe
  5. as2008xp.exe
  6. %profile%\\application data\\secure solutions\\antispyware 2008 xp\\as2008xp.exe as2008xp.exe setup_100527_3_.exe %profile%\\application data\\secure solutions\\antispyware 2008 xp\\as2008xp.exe setup_100527_3_.exe
Click start,Run,Type REGEDIT,click ok.
Go to the following keys and delete.
Delete registry values:
HKEY_CURRENT_USER\software\secure solutions\antispyware 2008 xp lgid
HKEY_CURRENT_USER\software\secure solutions\antispyware 2008 xp lid
HKEY_CURRENT_USER\software\secure solutions\antispyware 2008 xp pid
HKEY_CURRENT_USER\software\secure solutions\antispyware 2008 xp\2.1 installtime
HKEY_CURRENT_USER\software\secure solutions\antispyware 2008 xp\2.1 start counter
HKEY_CURRENT_USER\software\secure solutions\antispyware 2008 xp\2.1\config
Please rate this a fixya
Feb 11, 2009 | Computer Associates Anti-Virus Plus...
Internet connectivity
TCP/IP network transport not installed
Symptoms: After you run Microsoft Windows AntiSpyware (Beta) or other anti-virus/spyware/adware software, 1) you may receive one or more of the following interactive error messages:
Could not start the Windows Firewall/Internet Connection Sharing (ICS) service on Local Computer. Error 10047: An address incompatible with the requested protocol was used.
or
Windows Firewall settings cannot be displayed because the associated service is not running. Do you want to start the Windows Firewall/Internet Connection Sharing (ICS) service?
or
This application has failed to start because SPORDER.dll was not found.
2) Third-party networking products may not function correctly.
3) Computers may not be able to connect to the network because they cannot obtain an IP address.
4) You may receive the following error message when you are using Microsoft Internet Explorer:
Error 404: Page cannot be displayed.
Cause:
There are known spyware programs that install layered service providers (LSPs) on client computers to gather user data. When Windows AntiSpyware (Beta) removes spyware programs, it also removes the spyware-based LSPs. However, Windows AntiSpyware (Beta) does not restore any LSPs after it removes the spyware.
Resolutions:
How to rebuild the Winsock LSP chain on Windows XP SP2
How to rebuild the Winsock LSP chain on Windows XP, XP SP1, and Windows 2000 __________________
Bob Lin, MS-MVP, MCSE & CNE
How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com
Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net
Oct 17, 2008 | HP PAVILION A6230N DESKTOP PC
I downloaded the program Antivirus 2009 Professional but i cannot access it or find a way to make sure it is installed
Antivirus 2009 is a hoax. It a virus/spyware intended only to harm your computer. To get it off is way hard. Check my website.
http://sites.google.com/site/turbospeedmycomputer/
Aug 22, 2008 | F-Secure Anti-virus Client Security...
Pop up showing System Error. it reads Your system is infected with a dangerous virus----Note- strongly recommend to install Antispyware to clean system and avoid total crash of your computer. click OK to...
WINANTIVIRUSPro2008 spyware at its worst.
here are some removal options:
http://www.removeonline.com/remove-winantivirus2008-org-winantivirus2008-removal-instructions/
http://www.xp-vista.com/spyware-removal/win-antivirus-2008-removal-instructions
http://www.virtumonde.net/Winfixer/winfixer_removal.html
Sorry to tell you, but removal can be a pain
Jul 16, 2008 | Computers & Internet
Monitor or Desktop itself problem?
that status line was designed together with your OS, it seems that your PC was getting slow in boot..
A number of factors, having little to do with the age or capabilities or your system, can create excruciating system slowness. They include the following:
Operating System
File System (how you've organized files on your PC)
Applications
Hardware
The Windows OS (operating system) is notoriously inefficient, which can affect performance. The file system also impacts Windows and hardware performance. How you work with applications can improve system speed, as can some basic hardware updates.
Jun 18, 2008 | Computers & Internet
Spyware problem in Laptop Satellite M100
I haven't checked the link out but the chance of it not being a malicious site is too small to be worth bothering. DON'T EVER GO TO A SITE THAT POPS UP PROMISING TO HELP YOU OUT. My preferred anti spyware products are Spybot Search & Destroy and LAvasoft's Ad-Aware. If you can download the installation files onto another computer and then install and run them on your computer when it is disconnected from the internet and in safe mode, you are more likely to be successful.
Sep 18, 2007 | Toshiba Satellite M100 Notebook
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
