Question about Gateway FPD1760 17" LCD Monitor
Monitor Picture is Blurry because of shadows
This Gateway monitor now has an unclear picture. All the icons and letters are blurred by a shadow affect and difficlut to read. If I lay the monitor face down for a period of time, the picture becomes much clearer. However, after further use it goes back to its blurry ways.
    President:
  • 1,996 Answers
If you've already checked all your cable connections, to make sure they're tight, check your windows settings: Go to Start>rt click My computer, choose properties, settings on performance, and choose adjust for best performance. (This will uncheck the shadow options for menus and icons, etc.) Take a look at your desktop. Is that better? If so, you might want to do some maintenance to improve your system performance by clicking here.
If no improvement, download or open the .pdf user guide for your monitor by clicking here. See pages 22, 17, and 12. They will show you how to use the auto button on the monitor to reset to optimal settings, to adjust the refresh rate (control panel>display>settings>advanced) to its optimum. (Normally, higher refresh rates indicate clearer pictures, but some LCD monitors seem to run better at a default 60hz rate. Check your Gateway documentation for your graphics adapter to see what it supports, (your monitor supports 60, 70, & 75), or experiment.)
If adjusting settings doesn't improve anything, you could search for updated drivers for your graphics adapter. Go to windows update and see if you're offered hardware updates, or search Gateway support for newer drivers.
Not many options left. See here.You could take it in to a local tech and have them take a quick look.( or try it on another computer).
If it's on its way to a sad end, I'm sorry. We have the same monitor at home and it's been great. Aside from a scratch someone put in it years back, it provides very clear resolution.
Posted on Apr 18, 2009
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 149 Answers
SIMPLE ! The "shadowing" you talk about is due to cables in back of your computer, touching or too close together. I had this happen to mine. I moved the cables apart, and no more shadows !! Sounds too easy, but it works. Takes a few seconds. Immediate results.
Posted on Apr 29, 2014
Monitor has a shaddowing or blurring of the letters, icons, everything
control panel,display,settings you can make adjustments for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general
dpi normal size,larger size or custom settings
hope this helps
Nov 22, 2010 | LG Computers & Internet
All the icons, pictures and letters are creating shadows on the monitor. How do I get rid of them?
try this right click on your desktop , click on Appearance tab . then click on effects , see if Show shadows under menus is checked if so uncheck it . click ok then click Apply .
Sep 20, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
All typeset and pictures have shadows/blur have changed out video card on Lenovo computer - seemed successful for a while but now back to square one. any ideas
Try a different "data" cable between the monitor and the computer.
Connect the monitor to a different desktop/laptop.
If the "shadowing" is still visible, then it's the monitor that has gone "bad'.
Connect a different monitor to your Lenovo computer.
If the "shadowing" is still visible, then your monitor is OK, and your video-card is the problem.
May 18, 2010 | Lenovo ThinkVision L192 19" LCD Monitor
Blurry picture
Sounds like convergence failure. (Colored shadows of images.)
Apr 13, 2010 | Televison & Video
Blurred icon graphics
This is usually caused by windows display properties is operating incorrectly. One of the options is to default everything under your display options using control panel. If it still is blurred then try using the optimized screen resolution and enable the cleartype in Windows. If after doing that.. it remain blurred, try to use the Cleartype Tuner by Microsoft at http://www.microsoft.com/typography/...ePowerToy.mspx
See also http://www.microsoft.com/typography/...ner/Step1.aspx
Hope this helps. Let me know.
Mar 29, 2009 | Samsung SyncMaster 793DF 17" CRT Monitor
Fonts and pictures on display are deeply shadowed
unplug the monitor cable and check for bent pins. If there is one, that could be the problem.
Sep 29, 2008 | Computers & Internet
Red shadows to picture and letters on Sony TV
its most likely a warped lcd plate in the optic block if thats the correct model number which would require a optic block change out
Jul 05, 2008 | Sony KDF42E2000 42" HDTV
Double Images / Shadows on the monitor screen
Hi..there,
Have you guys...try to open your OSD on your monitor and blanced the colors or adjust the WB (white blanced) settings....
Jun 30, 2008 | Gateway FPD2275W LCD Monitor
Desktop icon shadow in acer monitor as 1024*768 resolution
go into your graphics card config and change the brightness levels
Feb 03, 2008 | Gateway FPD2275W LCD Monitor
Problem with shadows showing on monitor
LCD Monitor Shadow Effect
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this is very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
Solution: Keep the two cables - (power cable and monitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
Nov 02, 2007 | Dell Computers & Internet
Gateway FPD1760 17" LCD Monitor Logo
2,277 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
