Question about Philips Standard 104SLE 14 in. CRT Monitor
104s philips monitor
My monitor blackout. I suspect its the horizontal ic or vertical ic that was destroyed but I dont know the number of these ic's.
    Problem Solver:
  • 5 Answers
Why do you suspect the horizontal or vert curcuits? I would suspect the HV curcuit since no display at all. Gary(Honkity Hank)
Posted on Sep 18, 2007
How to solve horizontal lines on a CRT TV monitor and what could be the possible courses for it
Monitor horizontal lines problems usually caused by a defective vertical output/driver ic. A missing supply voltage to the vertical output ic may caused similar faults which is one horizontal line across the display. Dry joints and missing vertical output pulse from vertical oscillator ic also could contribute the same symptom. If you discovered that the protection resistor (usually from 1 to 4.7 ohm) open circuit or burnt, then replacing it won't solve the problem. The resistor burnt or open circuit was due to a short in the vertical output ic. Thus you have to replace the vertical output ic and the burnt resistor together before you switch on the monitor.
Jun 12, 2015 | Televison & Video
My TV picture has collapsed to a single horizontal line
If it is an standar analog tv, I'm sorry to tell you but, is time to get a new one.
Dec 05, 2009 | Panasonic Televison & Video
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Remove dry solder at Vertical IC if problem not solves replace VERTICAL IC and pf104
Darshan
Jul 05, 2008 | LG Studioworks 552V 15" CRT Monitor
Sony tv there is sound but no picture only horizontal line
hi there, one horizontal line means a vertical section prob., check some resistor with low value and a defective diode, possible ic part is defective. do some test and check up. ty
Feb 25, 2008 | Sharp 27C-240 27" TV
Philips 104 series monitor
pls help my philiphs monitor 105s vertical probelum i need service manuval pls help
Feb 14, 2008 | Philips Standard 104S 14" cRT Monitor
Ic
TDA 4841 IC IS USED FOR horizontal and vertical scaning IF YOU WANT its ckt you can get it from www.serviceinfo.com good luck
Sep 18, 2007 | Philips Standard 104S 14" cRT Monitor
Pin assignment for 104S monitor cable
you will get right pin alignment& complete ckt from web site IF YOU WANT its ckt you can get it from www.serviceinfo.com good luck
Feb 14, 2007 | Philips Standard 104S 14" cRT Monitor
No horizontal red convergence control
Probably the red convergence output IC has failed. The chip is basically a stereo amplifier that serves as a horizontal amplifier and a vertical amplifier. I suspect the vertical part has failed and is not uncommon. Should be generic STK392-150's or maybe STK392-110/120 I believe. By the way when the line moves up and down that means the vertical is working when it moves side to side the horizontal is working.
Feb 03, 2007 | Philips 60PP9202 60" Rear Projection...
LED remains OFF
Please out power amplipier section. Power driver Transistor may have been destroyed. Also chekc rectifier diodes.
Tell me if your problem has been solved.
Good luck
shadab_a4u@yahoo.com
Oct 27, 2006 | Philips Standard 104SLE 14 in. CRT Monitor
Computers & Internet Logo
76 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Steve Allison
Steve Allison
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
