Question about Garden
We have a john deere pressure washer 3000psi, 196cc. There is a small stem near the pressure controller that shoots water straight up when in use. Why? and what to do about it, plz?
5 Suggested Answers
  • 60 Answers
SOURCE: my john deer 3800 psi gas pressure washer
I would suggest taking it back if its brand new, even if you lost the receipt most stores can look up the sale to verify that its with the time frame for return.
Posted on Dec 13, 2009
nova2nv
  • 197 Answers
SOURCE: john deere 3800psi pressure washer will not siphon
The only way the washer will draw soap into the line is with either the black tip installed or with no tip in wand at all.There is a ball and spring inside of the pipe that the siphon hose hooks to so when you use the washer with alot or even a little pressure the ball is forced up and blockes off the soap inlet port.So if you use it with no tip in the inlet port is open cause the ball isnt being forced up by back pressure.I hope this makes sense.
Posted on May 22, 2010
  • 5 Answers
SOURCE: John Deere 3000psi pressure washer stalling
Mine is having the same issue...I googled and found this with no answers. I'll update if I can find a cure on my own...
Have you checked your oil level?? Small engines have a cut-off switch if your oil is low...mine is topped off so this is not the solution for me..but it could possibly for you.
Posted on Sep 26, 2010
spraydoctor
  • 97 Answers
SOURCE: pressure washer, john deere 3000 psi, honda engine
It sounds like your intake is plugged with debris. What usually happens is a water hose that has been laying around will get various stuff in it -- dirt, grass clippings, small insects (and whatever they take into it nest building). These days most homeowner pressure washers do not have a proper inlet filter, but just a screened hose washer like on a washing machine. The unloader valve can cause pressure variance, but usually not in the manner that you described. The pump is being "starved" for input water. Just use a pair of needle-nose pliers and pull out the screen and clean it or replace it.
Posted on Feb 21, 2012
Why my water seal want stay on my pressure washer
Hard to understand this. Make sure your fittings are strong and o-rings are good.
Jul 29, 2014 | John Deere 020297 Gas Pressure Washer
Operation of John Deere Hyd. Control Valve on right side of transmission on a 401B Diesel tractor/loader?
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Mar 18, 2017 | John Deere 420,1020,2010,2020,2510,2520...
Karcher 2400 psi with honda motor started up big puff of white smoke from exaust it shut off noiw wont start whats going on
I have a john deere 3000psi pressure washer with similar problem. Running fine then a puff of smoke and it shut down. I checked the oil and found it full of water. Not only that but since I still had the water turned on, the water was flowing out of the dip stick tube. I'm trying to find a solution online and will pass any information on.
Nov 13, 2010 | Karcher 2500 PSI Pressure Washer
May 01, 2010 | Garden
John Deere 3300 PSi pressure washer shutting off while in use.Everything appears fine Oil level,Gal level,Air cleaner ok etc.. May run 2 minutes or 12 minutes then spudders a bit then Bang "Off" as if i...
John Deere will replace the cap for free; they acknowledge the vendor who supplied Briggs & Stratton gas caps provided faulty caps. Call 1-888-228-3068 then 1 (English), 2, 1 and a technician will ask you for model number and Serial Number (which they need to replace the cap). Don't drill a hole in your cap: debris will find a way into the gas tank and end up possibly fouling the engine. Bob from NJ
Nov 03, 2009 | Dewalt 3800 PSI Pressure Washer
Water comes through nozzle, but no pressure. it is a john deere, with a honda engine.
The engine doesnt matter. Most pumps are DeVille Bliss. Get the model off the pump and go to their website for trouble shooting information.
Apr 22, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
787 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
