Question about Vacuums
Stihl ac 25-2/gsb 230-4 trimmer attachment. how to connect spool
How do you attach the spool on a stihl trimmer? I know to turn it counter clockwise, but how do you secure it?
My machine will spray from the hose attachment, but not when I am doing floors.
Check Flow Indicator Filter under the Flow Indicator. Turn Indicator cap counter-clockwise, remove rotor. Filter is under rotor and pulls out. Clean filter. Additionally, check LINT FILTER in the clean water tank cap. Check you User's Guide if you have more questions or call the Bissell Consumer Care at 1-800-237-7691 The other thing you can do in this case is reseat the tank. It may be blocking the housing connection but the sprayer connection is smaller and open. Cleaning the filters after each use though is recommended.
Dec 06, 2015 | Bissell ProHeat Pet Upright Deep Cleaner,...
Water wont spray from cleaner how to fix
Try cleaning the Flow Indicator Filter. Turn the Flow Indicator Cap counter-clockwise to remove, lift rotor and filter. Clean filter and replace in reverse order. Bissell's Consumer Care # 1-800-237-7691
Sep 16, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
Cannot remove attachment from proteam super quarter vac
Greetings, The ProTeam backpacks us a 1.5" hose and attachments. The way that the floor tool is removed is by unscrewing the collar of the attachment. Simply turn counter clockwise on the the part of the attachment that is secured to the wand and doesn't rotate. This should loosen the floor attachment, and you may then pull it off. The other floor attachment can be fitted, and then screwed on by rotating the opposite way, clockwise which will secure the attachment to the wand. I really hope that this information was helpful to you. If you ever need parts or supplies for your ProTeam, please be sure to check out GoVacuum dot com. If this was helpful to you, please rate the repair as helpful by clicking the 4 Thumbs up icons in the top part of the repair. Thank you very much, Chris J. GoVacuum
Mar 23, 2010 | Vacuums
Kirby sentria
remove the cloth bag from the bottom it twists counter clockwise, un clip the bag from the top remove the head piece, turn the belt lifter clockwise and release the lever to remove the head, take off the head, in your attachments there should be a screen that covers the impeller that the belt rides on it goes on like the brush head, put your hose onto the bag port by turning clockwise. there it is it will not work without the screen cover. thanks Rene
Aug 29, 2009 | Kirby G6 Bagged Upright Vacuum
I need to know how to change my kirby into a blower?
Raise the light assessory on the front of the vac. Remove the roller assembly by rotating the square dial as indicated by the arrows. Then you must attach the accessory that sort of looks like a 4 inch square open box to the front of the vac where you removed the roller assembly and lock into place. Next you remove your bag assembly by unsnapping at the top of the handle to the vac, then at the base of the bag assembly you must unlock the plastic base from the metal vac unit by turning it counter clockwise and then pulling off. Finally you attach the hose assembly where you removed the bag assembly and lock into place by turning clockwise (reverse of taking off bag assembly base). Put vac in neutral and power on. Now you will blow from the hose assembly.
Apr 20, 2009 | Kirby G4 Bagged Upright Vacuum
How do I attach my hose to the vacum to use the accessories
Make sure the height adjustment is all the way up on the highest setting.(This makes it easier to remove or replace the brush head or accesories.)Turn the belt lifter knob on the brush head all the way counter clockwise.Raise the headlight assembly to expose the brush head lock.Unlock the brush head and remove,then attach the hose to the machine,and lock it down.The hose is now ready to be used.
Note:When removing the brush head,make the belt lifter knob the fist thing you turn when removing it,and the last thing you turn taking it off.
Dec 10, 2008 | Kirby Vacuums
Connecting hoses on Kirby G4
The hose attaches in place of the beater-bar head unit. To remove the head unit, lift the headlight assembly, then turn the square gray Kirby emblem counter-clockwise 3/4 of the way around until the red triangle on the square portion aligns with the red triangle on the base unit (this disengages the belt). Then flip the silver metal fastener that was underneath the headlight to release the head unit and remove the head unit. To attach the hose, simply line it up so that the safety button is engaged by the hose assembly and then use the metal fastener under the headlight to secure the hose to the base unit.
Nov 17, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Carpet vacuum attachment quit working after sucking up a bedskirt. Bedskirt has been removed but carpet attachment will not work. My old vacuum had a reset button on the carpet attachment for use when...
I have a Hoover Conquest approx. 4 yrs old. The turbo head is not working Model No. PB4 230-240V AC 50Hz 200w CS4901N (N127) I have been trying to locate another one or another one similiar to fit my machine
Jun 12, 2008 | Hoover Vacuums
How do i put together my kirby carpet shampoo system?
Vacuum thoroughly before shampooing for maximum cleaning. Then, remove the bag and the Power Nozzle to prepare for shampooing. Turn the Carpet Shampoo System Nozzle Belt Lifter to the right of the center position (fully clockwise) until the green arrows line up. a4bbc62.jpg Slide the slots on the side of the Carpet shampoo system over the outer shoulders of the Carpet Shampoo System Tray. e14fe2e.jpg While pushing up on the Belt with your finger, turn the Belt Lifter left (counter- clockwise looking at it from the front) until the red arrows line up. (The Belt Lifter Hook will catch and stretch the belt.)
Press the bottom Toe Touch Pedal all the way down to raise the front of the Kirby.
While sliding the carpet shampoo system Nozzle/Tray Assembly toward the Kirby and over the Motor shaft, connect the hooks on the bottom rear of the nozzle to the Attaching Bar.
Push the nozzle up against the Kirby and turn the Accessory Lock to the
right (clockwise) to lock the nozzle in place. To engage the belt, turn the Belt Lifter
all the way to the right (clockwise) until the green arrows line up. Then lower the Headlight Hood
Apr 18, 2008 | Vacuums
Vacuums Logo
215 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
