Question about Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner
Deck belt does not engage blades on riding tractor
Just changed the deck belt on my 42" MTD lawn tractor. When I engage the PTO lever nothing happens.
  • tclark4 Apr 30, 2009
    mower deck was working disengaged and now it will not engage. Replaced belt and blades was working.
  • 45 Answers
Be sure the belt is the correct size and is routed correctly.
If you are not sure, you can download a manual here:
http://manuals.mtdproducts.com/mtd/public/list.jsp
You will need the model & serial numbers.
Posted on Aug 25, 2009
  • imskid Aug 25, 2009
    http://manuals.mtdproducts.com/mtd/publi...
rockitman187
  • 2559 Answers
SOURCE: loud screech noise from deck area
This can be due to a belt slipping or a bad spindle bearing.
And on the difficulty scale,10 being extremely difficult, The belt would be a 1 or 2 and the spindle about 6 or 7 (because the deck usually needs removed for this job)
Posted on Apr 04, 2009
  • 57 Answers
SOURCE: Craftsman 42" mower deck won't disengage
Try pulling on the cable coming down to deck. This cable might be your problem. Also check that the spring on the end of this cable is present and functional.
Posted on May 19, 2009
wadembly
  • 462 Answers
SOURCE: 42 inch Craftsman blades won't engage
is the belt spinning & smoking when blades are engaged or the belt won't spin if the belt spins but blades wont go then there is something stuck under the deck or the bearings are gone out do to not being greased
Posted on Jun 14, 2009
  • 138 Answers
SOURCE: Engine dies when clutch is released or PTO is engaged
flop the seat forward, locate the seat switch in the middle of the seat, push the connector onto the seat switch firmly, start it up and drive away
Posted on Aug 17, 2009
bbreton
  • 437 Answers
SOURCE: tractor starts, stalls when blade is engaged, or brake released
you have a safety switch malfunctioning or a transistorized relay not working properly. Go to www.partsdirect.com, this is sears website. It should be able to find and illustrated parts list for your mower.
Posted on Sep 28, 2009
A PTO that is engaged constantly,
On that type PTO engagement there is slack in the belt that disengages the deck, in some case there is a arm with a idler pulley that swings against the belt to tighten it and engages the deck , in other cases like older MTD:s the deck swung backwards as it was let down and tightened the belt and was lifted to turn it off. Most of the decks had a brake of some kind on the deck pulleys to stop freewheeling of the blades when disengaged .
May 26, 2016 | Garden
Where is the safety switch to engage the blade
Your lawn tractor will have a lever that raises and lowers the mower deck which houses the two cutting blades. By lowering your mower deck to the desired cutting height, the blades should automatically engage. By raising the deck back to it's highest position, the blades will automatically disengage. Should be simple enough. You can consult your mower manual. If you don't have one, you can easily find it online using the make, model and year of the lawn tractor.
Jul 08, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a 42" mtd lawn tractor. The blades do not
The blades engage via a belt, that goes around a series of pullies, one of those pullies is a tension pulley that is connected to your pto lever by springs, the engine has nothing to do with your blades until after you engage the lever, I would check your belt. It could be loose, and if you engage the blades it could take it a few to get up to speed, thus making it seem like its only when the engine is warm.
Does everything else work fine? As in the tractor moves when the blades are not engaged?
Jul 11, 2012 | Garden
Have a Craftsman 26 hp, 48" mower...mower starts runs but when I try to engage the blades nothing happens. Checked all the belts, ck for blockage but nothing...what would the next step be?? Tks
When you say nothing happens...is the PTO engaging? You said that you already checked the belts...if none of these are off...you maybe looking at a new PTO clutch.www.nnyparts.com
May 29, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blades will not engage when lever is engaged.
is that the manual one or the electric pto? can you see if the belt is on all its pulls?
Apr 22, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Smoke when blades engaged on yardman 42'' yard tractor
The oil on your pulley could definitely be the culprit. You need friction in order for your belts to work properly.
Apr 17, 2010 | Mtd Garden
Need a owners manual for troy bilt 17.5 hp 42 inch pony lawn tractor
HOW TO CHANGE A BELT ON
  • Troy-Bilt 17.5-HP Manual 42" Riding Mower
  • Nov 30, 2009 | Mtd Garden
    I need a belt diagram for a ranch king king plus also i need to know the size for the main drive belt
    Ranch King is a brand name of the manufacturer MTD.
    Product manuals with part blow-up diagrams are available from MTD's web site,
    http://www.mtdproducts.com/
    Models are identified from the model number printed on a label under the mower seat.
    The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
    Parts can be ordered directly from MTD or other distributors on the web.
    It is my experience that original brand name MTD belts work best.
    The 22HP, 46" mower deck Ranch King Pro has 3 belts:
    The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
    A mower has either an electric PTO or a manual PTO, not both.
    The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
    The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
    The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
    In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
    Sep 07, 2009 | Mtd Garden
    I have a craftsman riding lawnmower and the blade engagement is not starting the blades when i lift it. It feels loose when i lift it.
    Sounds like you PTO cable is broken. Part # 175067. It goes from the lever on the dash down to a deck mount and hooks to the idler pulley. When you lift the lever, it should pull the pulley and idler arm towards the rear of the deck to tighten the belt to engage the blades.
    Jul 29, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
    Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner Logo
    1,011 people viewed this question
    Top Oregon Scientific Garden Experts
    Dennis Key
    Dennis Key
    Colin Stickland
    Colin Stickland
    roeb
    Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
