Hello, I got a problem on my ILO05. That is ?NO DISC? to any dvd disc .I need to know this is from the Laser or from the Spindle motor? I don?t have a Circuit Diagram for this. I saw the laser read when it?s play. But the spindle motor doesn?t work (doesn?t rotate)So if any one who repair this please help me. I?m from Sri Lanka
2 Suggested Answers
  • 1139 Answers
Hello senaka, First I would check the motor with an ohmmeter to see if it if blown out, if it is replace it if the motor is ok then check the motor supply circuitry. I believe that the motor is not getting the proper voltages. This may have caused or be the result of your capacitor failure. Also clean the laser with a DVD cleaning disk .
Posted on Sep 18, 2007
Ps3 not spinning disc, replaced spindle motor, did not fix. Please help
Hi there, this is because the actual laser needs replacing, not the disc spinner motor. With the PS3 the laser reads the disc data type, whether it be a DVD, game , audio cd or blu ray movie. It then spins the disc up to the required read speed. When the laser is faulty is cannot read the disc type so will not spin at all.
Hope this helps
Jan 23, 2011 | Sony Playstation 3 (PS3) Console
I have a philips hts6510 home theatre system and when i put a dvd in to play it says no disc
Normally a dvd player shows the message NO DISC when,
1. The disc inserted is bad.
2 The lase pickup unit inside the dvd lost its reading intensity, dirty lens or the spindle motor damaged .
In your case the second one happened. the intensity of the laser pickup unit has lost or the spindle motor faulty or there is some dust on its lens. just insert a cleaning cd in it for two or three times. then check again is the DVD is reading or not
if the problem remains then you have to check the motor and the laser pickup unit. the lase pickup unit have two laser emitter and receiver in its inside . one for reading and playing DVDs and the other for CD and MP3. also the spindle motor runs in different speed when u insert dvd and cd.
Open the cover of your dvd player and power it on insert an audio cd and watch is it reading or not also notice the speed of the spindling of the cd. if the audio cd reads and play. then the possible problem is the spindle motor
To conform it remove the audio cd and insert a dvd. watch the rotation of the dvd. if it feel very hard to rotate it then, the spindle motor is damaged. if so replace the spindle motor if it runs more the the speed of than audio cd then the laser pickup unit is faulty. Then u have to replace the laser pickup unit.
if you need any further assistance from me , feel free to contact me through fixya.
Jan 16, 2011 | Philips HTS-6500/37 System
The disc has appeared to stop rotating. The info window continously says "reading".
DVD/CD Read/Write process: 1. The tray or carriage places the disc into the spindle or motor. 2. The spindle motor locks into place to prepare motor to spin - the disc is in free space and does not touch anything except the spindle motor. 3. The laser assembly moves into home position and attempts to focus on the disc by emitting infrared light to disc. 4. If a disc is present, the light should reflect back to the laser lens as the lens attempts to focus on the light - you will notice the lens moving up and down to focus. The lens should NOT touch anything. 5. Upon a successful focus, the spindle motor spins. 6. Data is read and sent to a buffer for decoding. 7. Success.
Dec 27, 2010 | Yamaha DVX-S120 System
Sony 5 changer dvd player won't work. displayed code 31
This may be caused by one or two causes. The laser pickup assembly is bad or the most common failure for DVD and CD players is the spindle motor. This motors bushings fails over time and does not spin the disc at the right speed so the unit times out. You can repair the by purchasing what sony calles the Mech Assembly it comes with new laser and stepper motor as well as the Spindle motor.
Mar 14, 2010 | Sony DVP-NC600 Multi-disc DVD Player
Doesn't play any dvd or cd
you need to see if the disc is spinning inside the unit, if it is then you need to either clean the laser with a clean cotton tip or replace the laser, if the disc doesnt spin, it may be the spindle motor(held within laser assy,which is easier to replace) or it could be the mpeg printed circuit board. Good luck.
Sep 26, 2009 | Durabrand DUR7 Portable DVD Player
Hi, My Samsung DVD F1080 cannot read disc. Please, Why ?
I have 2 of these units and both suffer with spindle motor problems. With Samsungs track record with Very Bad DVD drives (2xHR734 2xDVD-F1080 + a load more I'm repairing right now) I would go with the spindle motor not spinning the disc up.
Aug 05, 2009 | Samsung DVD-F1080 DVD Player
if the disc starts to rotate when helped by hand then you definately have a weak spindle motor. dvds spin faster than cds which gives more wear & tear to the motor. i've repaired these faults numerous times. hope this helps?
May 08, 2009 | Technics SC-DV290 System
Ps3 willnot play games or dvd
Hello Mr. Lawley
When you put in a disc, listen for the disc to start spinning. If you do not hear that then the laser and/or the spindle have blown out. You will have to get your Blu-Ray player serviced by a pro or Sony. Sony may fix it for free. They know that the drives are failing. So call them first. If you know how to do it yourself, you will need part KEM-400AAA / KES-400A if it is not spinning. If it's spinning and not reading the laser may be dusty or need replacement. The laser by it's self is part number is KES-400AAA. If you need any more information, please do not hesitate to hit my "Ask Me" button.
I hope this helps! Good luck to you.
Aug 01, 2008 | Sony Playstation 3 (PS3) Console
Play station 2 won't read silver disc only reads blue disc
Hi Elvis,
The Blue back disc is CD format. The DVD laser circuit is giving you trouble. You can adjust the DVD pot some on the back of the Laser. Turn it about 3 degrees clockwise. Then put it the laser back in. Test the PS2 with no cover on, and use the white round disc from the laser drive cover to clamp a disc onto the spindle. Test DVD and PS2 Games that do not have Blue back.
Nov 28, 2007 | Sony PlayStation 2 (PS2) Console
ILO05 "NO DISC" Fault
Sep 18, 2007 | Televison & Video
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
