Question about Gateway 450ROG Notebook
Gateway 450 ROG screen does not show or freezes
My gateway 450 ROG does not always boot up, it comes on but the screen gives you nothing! When it does comes up it runs all the way to regular windows starts up and then freezes! Does anyone know why this would happen?
  • Good2bme Sep 19, 2007
    Unfortunately that didn't work! It did the same think you press the power button you hear it and the fan the lights on the computer come on, no beeeping heard and no display is eeen on the screen.
    OK lets go true soem stuff that i did previous to see if this helps any at all. I started using a second monitor attached to laptop to give me a bigger screeb area. It recently told me the display driver are incorrect but the drivers are the onyl one gateway provides for the 450rog. next i just got it to come up but it a gain went only as far as XP.. welcome screen! them the welcome started to become distorted and the second monitor just shut off. The i restarted is and tried to go thte boot menu but it froze this time inside of boot menu settings?
    Brigadier General:
  • 6,966 Answers
Hi, The only easy check I can suggest is on the memory. Flip your notebook so that the bottom is facing up. Locate a small panel (with 1 or 2 screws) roughly 3X3in. Inside would be 1 or 2 memory strips held in place by 2 retaining clips, one on each side. Moving the clips slightly away from the memory would free the memory strip and partially spring up. It can now be easily removed. With a pencil eraser, clean/rub on the little gold contacts at the bottom. The slot where they mate with their holder could also be cleaned with an old toothbrush. If the above does not correct the errors, then perhaps you are better off seeking the services of a qualified professional since the unit may have to be opened up and diagnosis performed on its various components. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Posted on Sep 18, 2007
  • Louie  Role
    Louie Role Sep 18, 2007
    P.S.
    In some models/brands/versions, the memory may be found underneath the keyboard.
  • Louie  Role
    Louie Role Sep 19, 2007
    Hi again,
    Starting to sound like video card problem or its driver(s). But come to think of it, some versions uses the same memory strip for the video card as well as the motherboard. If cleaning did not work, you can try replacing.
    Considering that it even hangs just at the menu selection (Safe Mode or Last Good Configuration that worked), perhaps you can try and use the recovery CD that came with the laptop.
    You can try reinstalling the entire OS either in repair mode or clean/fresh. Should there be data/files that you would want to make sure are not over written, you can back it up using an external 2.5 Enclosure with USB connection to a second PC after removing the HD from your Gateway.
    If this really is a hardware issue, guess you ought to consider having it diagnosed by qualified professionals.
MEDIA TEST FAILURE AND OPERATING SYSTEM NOT FOUND ON GATEWAY 450 ROG. HOW CAN I SOLVE THIS PROBLEM?
The above error message displays your computer hardware gone bad.Please change the hard drive. It will resolve your issue.
Aug 09, 2010 | Gateway 450ROG Notebook
I have hard time finding the Network Controller driver for my Gateway 450 rog. Please provide a Free site.
You can download the drivers for your model Gateway laptop from this WEB site, make sure you select your model laptop and the correct XP or Vista drivers. Click on this link to download the drivers: -
http://driver-pro.com/related/english/hardware-drivers/?a=12221&gclid=COmm19XHtpwCFSMSagodPRuwnQ&hit=1
Jun 27, 2010 | Gateway 450ROG Notebook
Need sata driver for gateway 450 ROG using xp. I installed a new hard drive 250GB. need to format and partition
Are you using sp1? I think that this is the only version of xp that don't support SATA. Then it's time to upgade to sp2 at least.
Stelios
Feb 20, 2010 | Gateway 450ROG Notebook
Looking for my pci modem driver for gateway 450rog
Drivers for the 450 ROG are on the mpcdrivers.com website.
the link is here:
http://www.mpcdrivers.com/apps/filelistc20a.html?ID=19095
Many service manuals are available for Gateway units on the mpcdrivers.com website, Just contact the webmaster at mpcsupport@cox.net
Oct 12, 2009 | Gateway 450ROG Notebook
We have proplem in power damage in mother board the led of power on is on put no power in screen and led of HDD is off model no 450 ROG
Remove the battery and power cable from the laptop. Press and Hold teh power button for 20 sec, connect the power chord and then try to turn on the computer
Sep 10, 2009 | Gateway 450ROG Notebook
450 ROG LCD Display
at the the top of webpage hit arrow on page in tool bar then you can change text sizes or zoom in and out.
let me know if that helps
also have you gone into device manager and update your display driver
if this does'nt help i can give another solution
Jan 23, 2009 | Gateway 450ROG Notebook
Gateway 450 ROG Dispaly
then it sounds to me as if the interface cable/connector is loose or damaged for the video feed to monitor screen itself might try to check or have some one to ,it could be bad monitor also but i would ck interface first ,also a couple of other things to try is reload drivers from hp and see if makes a difference , also the video output board could crapped
Jan 12, 2009 | Gateway 450ROG 15inch SXGA+ LCD Display-...
Gateway laptop 450 rog
be sure to circle through possible screen.
use FN key + a key with a screen symbol on your keyboard (or check your doc) to switch from main screen to external monitor and back.
sometime some techies use external monitor for pc final test and forgot to restore configuration to laptop screen.
At restart XP is expecting the last used monitor and nothing shows on laptop screen.
try also connecting any external monitor to vga plug.
let me know if is fixing
Jan 04, 2009 | Computers & Internet
Gateway 450 ROG will run only on battery.
If it's still under warranty, it's definitely worth repairing. If not, get them to quote for the repair they say it needs before agreeing to it. If their quote is anything close to the current price, I would say it's not worth it.
May 09, 2008 | Gateway 450ROG Notebook
Gateway 450ROG Notebook Logo
474 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Steve Allison
Steve Allison
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
