Question about Troy Garden
How do you change the oil? I have troy built lawn mower with this engine.
  • 15 Answers
SOURCE: oil drain plug
Drain plug is not necessary. Remove the dipstick and tip the mower to the side the dipstick is on and use the dipstick tube as a drain.
Posted on Apr 23, 2009
vincob
  • 718 Answers
SOURCE: lawn mower won't start /troy built 100706
First check to see that you are getting a spark. if you are getting spark (if same plug when you bought it change spark plug) make sure it is correct plug for that mower, make sure you have good gas. If still not starting and the machine probably was sitting for a while, clean the carb and then it should run fine.
Posted on Sep 26, 2009
bbreton
  • 437 Answers
SOURCE: troy built lawn mower (riding) won't go full
I did not know riding mower had a gas pedal. I know if you leave the throttle control up all the way the engine will choke out. The pedal you are pushing, I think, is the forward/reverse hydrostatic transmission. You may need a new drive belt. The one you have now may be stretched out.
Good Day.
Posted on Oct 07, 2009
SOURCE: i have a 18/42 troy built lawn mower and gas is
TUBE UNHOOKED
Posted on Aug 09, 2010
  • 37 Answers
SOURCE: change blades on a lawn tractor pony? troy built
just jack it up so you can get under the deck and unscrew the bolt on center of ech blade take note on how the curves of blade are angled do one at a time incase you forget but bolt back up tight and you are ready to cut if you try to resharpen the blades make sure you balance them or they will mess up the deck bearings
Posted on Nov 10, 2010
Where is drain plug for oil on Troy bilt Tb230
It does not have a drain plug. You can remove the dip stick and tilt the mower to pour out the oil, or you can use one of those hand pump syphon units to pump it out.
Mar 23, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
How much oil goes into Troy built self propelled mower
Your engine should take about 20 oz of oil to fill from empty.
Oct 23, 2011 | Troy Bilt 5.5hp Self Propelled Mower
How to change the oil in my troy built pont where is the drain plug
Not sure what a pont is, or what motor you have, but on some of the Troy built small engines from Honda the geniuses designed the motor with no drain plug. You have to tilt or flip the engine over to drain oil out the filler
Feb 24, 2010 | Troy Garden
Can't find owners manual for troy built 21''. How do I drain oil from engine.
Not knowing what model number mower you have, there are a couple of possibilities for draining the oil.
Number one: You can tilt the mower back on the handle bar and look at the bottom side of the engine for a drain plug that is easily accessible and unobstructed so that the oil would drain straight into a container with the mower elevated on something high enough to get the container under it. Loosen the plug then put it up on the blocks, saw horses or whatever you are using, get your catch container under it and remove the plug.
Number Two: Start the engine and warm it up for a few minutes to make the oil flow easier. Set it up on a work bench with the oil dipstick tube toward the outer edge of the bench. Line up a catch container on the floor below it and tip the mower over on its side and pour the oil out the dipstick tube into the container. Just use caution not to touch any hot parts of the engine when lifting it up. This is the way Briggs & Stratton recommends changing the oil in their engines which do no have an accessible drain plug.
Oct 25, 2009 | Troy Garden
I have changed the air filter and bought a new spark plug but my troy built with Honda 160 cc engine will not start.
there is a possibility the c oil is bad, pull the plug and with wire attached pull cord to see if any spark
Aug 07, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy built lawn tractor won't start.changed plugs.
i have a troy bilt riding mower,i start the mower it only runs for 15 to 25 min's ,so i changed the coil to see if it would run long. but after a few minunts it stop again so i don't know if maybe it's my carb. what could it be.... help
Jul 03, 2009 | Troy Bilt 5.5hp Self Propelled Mower
After changing oil in troy built riding mower the oil light is still on and wont crank
That is a safety feature with a lot of engines, there is a reset somewhere, call your Troy built dealer and ask him, I'm sure he will help. I will be a simple fix.
May 16, 2009 | Troy Bilt 5.5hp Self Propelled Mower
I have a troybuilt push lawnmower with a honda motor, I was wondering where the oil plug was where I can drain the oil.
It is under the mower, you will need a 3/8 ratchet and extension to take it out...make sure NOT to tip the mower over, you will have to raise it, but make sure the spark plug end stays up!!!
Apr 25, 2009 | Garden
Oil drain plug
Apr 20, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Oil drain plug
may be under the blade plate under the mower, usually a plug with a quarter inch square drive, you can use a ratchet to loosen it if it is quarter drive, maybe a half inch drive
Apr 20, 2009 | Garden
Garden Logo
151 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
