I own a Prive TFT LCD TV and am just getting what I cn best describe as a 'Colored Bar Code' on the TV. It will not let me access anything, ie: The Menu etc.........
  • 3 more comments
  • jeeveseyjeff Apr 19, 2009
    Sorry about that.
    It is Prive MT-PRTPT3208NB.
    I hope that helps.
    Thank you.
    Thank you for the prompt reply.
    Tried powering off for 1 hour then powering back on. No success I'm afraid. probably have a dud eh!
    No blinking at all, nothing I am afraid.
    I can turn the TV on. Takes some time to warm up then all I get is the Colored bar code. No blinking of any lights at all.
    Good confirmation that I need professional help
    Brigadier General:
  • 3,614 Answers
may i know exactly the model # that your tv have.
thanks.
Posted on Apr 18, 2009
  • 3 more comments
  • micromaster
    micromaster Apr 19, 2009
    try unplugging the unit for one hour, to reset the unit.
    let me know
  • micromaster
    is there any blinking codes on the switch led... The timing of the blinking you see would be as follows: two to nine
    blinks, (depending on the fault), about a third of a second apart, then
    a pause for 3 seconds, then the two to nine blinks about a third of a
    second apart again.
  • micromaster
    is there any power coming into the tv. have you try to check the electrical outlet & the plug
  • micromaster
    do you mean the unit was dead, cnt turn it on
  • micromaster
    ok i got it.
    this cab be either that you have the problem on the bulb, or in the color wheel. you may need to call a technician to check the tv immediately. you can never work this alone & it very complicated & you need to call someone to help you.
Picture comes on ok to my LN40C550 Samsung, then colored lines begin to appear through the middle of the screen, almost like a colored bar code
Sounds like a T'Con board fault. Contact any service technician to confirm. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 25, 2014 | Samsung LN-S2651D 26 in. LCD Television
Weird colored bar
screen is starting to crash ,
Mar 23, 2012 | RCA 46 46LA45RQ LCD TV
Describe your ATEC TFT LCD TV AV320w Problemproduct name:TFT LCD TV,Model no :AV320w,system:pal/secam(B/G,D/K,I,L) ,serial no 5CAQS50685,configuration no AV320w-BNP-11EU. I need a remote control for this...
Overseas Model - This is an overseas model. There are no replacement parts for this model in the USA. Please contact the manufacturer directly for replacement remotes. Hope this helps u out. Good luck... HDTV GURU JAY
Mar 17, 2011 | Televison & Video
32" TFT LCD TV remote
You can get a 'Universal' remote from most electrical stores. You will need to get a set up code for your TV - try this site http://www.xdiv.com/remotes/
Feb 18, 2011 | Hyundai Electronics Televison & Video
I have a 32inch prive remote dose not work how can i get one
i have a 32inch prive remote that dose not work how can i get one or find a code or the replacement remote
Sep 20, 2010 | Soyo Atlas DYLT3212 32 in. HD-Ready LCD...
Prive lcd tv remote codes
no manufacture has that brand in the code list. but soyo did come out with their own remote that will work satellite/cable boxes. Go on their website. www.soyo.com
May 28, 2008 | Soyo Atlas DYLT3212 32 in. HD-Ready LCD...
Remote codes for a cable STB Explorer 3200 cable box and a Prive 26" TV
Call the provider of the box and they will walk you through it on the phone...usually.
Mar 24, 2008 | Directed 434MHZ Remote Control
TFT Screen Loose Connection?
Hello!
These models sometimes have a problem with flickering screens, screens going black, etc. This is caused by the cable running from your LCD lid area to your motherboard.
To gain access to this cable, flip your laptop upside-down, but make sure the back is facing you (vents and such). There are 4 screws along this side, you only need to take out the middle two.
Once that is done, flip your laptop upright again, open the lid and pry up the power bar. The cable you seek is running on the right side, should be wrapped in gray-colored tape.
Adjust this cable so that it cannot move and is not being pinched, and you should be set.
If that didn't work, and since your LCD is no longer lighting up at all, I'm almost leaning towards your problem being your inverter board. Very easy to swap out, and cheap at around $20 at darntoothysam.com.
The LCD inverter board is located at the bottom front part of the LCD lid. Just take off the front frame of your lid by removing the power bar (as instructed above) and then removing the screws under the rubber bumpers on the LCD frame. Then it's just a matter of carefully peeling the glue holding the frame down at the bottom.
Your inverter board is the long green-colored board you should see with the front frame removed. This board will have two connections plugged into it. Quite the easy swap, yes?
Nov 06, 2007 | E-Machines M2350 Notebook
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
