Question about Sanyo PLV-Z2 Multimedia Projector
DVI will not recognise now ?
The DVI port used to work ok with my PC until I changed the GFX card. Although the new GFX card has a DVI output I cannot get the PLV-Z2 to pick up a signal ? Is the projector broken or does it just need adjusting or maybe a different graphics card ? Thanks pete
  • Jstier Dec 10, 2008
    Tried this but the Sanyo still do not detect any signal. I use a Apple TV connected to the PLV-Z2
Presumably, you're going directly from DVI port on computer to DVI port on Z2?. Here is a Q&A list based on all the possible sceanrios for this hook-up...
Q1: Is it DVI-D or DVI-I (with unencrypted DIGITAL output from graphics card)?
A1: Choose 'Input 2', then 'RGB(PC Digital)' on Z2.
Q2: Is it DVI-D or DVI-I (with HDCP-encrypted DIGITAL output from graphics card)?
A2: Choose 'Input 2', then 'RGB(AV HDCP)' on Z2.
Q3: Is it DVI-I or DVI-A (with ANALOGUE output from graphics card)?
A3: Choose 'Input 2', then select 'RGB(Analog)' on Z2.
After making sure the correct 'Input 2' is chosen to match the signal coming from the card's DVI port, make sure your card is outputting a suitable screen resolution that the PLV-Z2 can display correctly, e.g... 1280x720 (native, and preferable!); 640x480; 800x600; 1024x768 (choose this if you don't have 1280x720); 1280x1024, etc. Also, if you have multiple refresh rates availble for the resolutions, choose 60Hz.
You should end up with an image.
Posted on Dec 26, 2007
I am having a Problem with my video card not letting me run an addition monitor off the vga output on the motherboard. I know it works because I can go to the bios and change it and it works but they want...
When using a PCI or PCI-E graphics card, it will disable your standard VGA output port because the up-dated graphics card and your factory VGA port require different display drivers. Usually, the drivers are conflicting and will make your system unstable and cause it to crash. In short, you can't use both at the same time. I have a Radeon HD 5450 graphics card installed on my PC and it too has disabled my standard VGA port. If you are trying to use more than one monitor, you have to install a graphics card that supports a multiple display output. The graphics card will either have 2 VGA ports, 2 DVI-D ports or 2 HDMI ports or even any combination of the 3. My card, for example, has 1 VGA, 1 DVI-D & 1 HDMI. I can run up to 3 monitors at a time via my graphics card, but I cannot run a 4th monitor from my factory VGA port. My graphics card uses ATI/AMD drivers while my VGA port requires the use of Nvidia drivers.
I hope that you find this useful.
Mar 26, 2015 | Lenovo ThinkCentre Computers & Internet
Tip
How to Connect PC to HDMI TV Step 1 Turn your...
  1. Step 1 Turn your computer off, and turn it around to view the rear of the unit. Find the cable that comes from the computer's monitor, and follow it to the back of the PC. The cable will be plugged into the output of the video card, which will be either a 15-pin VGA port or a 29-pin DVI port. If you are fortunate, there will be a second port directly next to it, of either the DVI or VGA variety. On the newest machines, you may even find a regular HDMI port on the card.
  2. Step 2 Choose the connection for video output. If your computer has an HDMI port, you can simply connect an HDMI cord of the correct length between the computer and the TV. Otherwise, you will need to make a few decisions. If your computer has only a single video output, and it will not be used solely with the television, you may want to invest in a new video card. Purchase one with either a DVI or an HDMI output, and install it in an available slot, according the instructions included with it. If you intend to use the VGA output on a single-output or dual-output card to drive the HDMI display, then a special device will be needed to convert between the formats, and the price of the converter is actually about the same price as an entry-level video card that will be easier to use with your TV. In that case, it may be a wise idea to upgrade the card in order to obtain a DVI or HDMI port. However, if your chosen output port is of the DVI variety, an inexpensive DVI to HDMI cable can be purchased to convert your computer's output into the proper HDMI input for your TV.
  3. Step 3 Connect the HDMI cable from your television to your computer. Install the correct adapter or converter for your computer, if necessary. Unless your computer has HDMI output, cords will also need to be connected from the sound card output to the HDMI video cable or adapter, because HDMI carries both video and audio signals.
  4. Step 4 Boot your PC, and configure the new display, by selecting "Control Panel" from the "Start" Menu. Then double-click the "Display" icon and click the "Settings" tab. The manual for your HDMI TV will list the screen resolutions it supports, along with the refresh rates. Configure the resolution in the "Settings" tab, and then click the "Advanced" button to set the refresh rate. If you are using the HDMI TV as the second monitor, you will also have to configure how it is used by Windows, according to the instructions pertaining to your video card. Most cards offer a "Clone" or "Mirror" mode, where both screens display the same content. Alternately, the "Extended Desktop" mode can be used, in which each monitor will operate independently.
  5. Step 5 Reboot your PC to apply the changes, if necessary, and prepare to relax on your couch and watch your movies on the big-screen HDMI TV.
on May 24, 2010 | Computers & Internet
The display conacted to DVI galaxy card output didn't recognise conection
u need to activate the second port /dvi from the nvidia controlpannel *cpl* if u don'thave it u need to install the latest driver it's emdded on
Sep 19, 2012 | Nvidia GeForce FX 5500 Video Card Graphic...
No DVI video output from dell xps 210
It sounds like your video card has gone out. Is the VGA and DVI ports on the same video card? If so the card is probably bad.
Mar 25, 2012 | Dell XPS 210 PC Desktop
HOW To Make MY TV WORK ON MY COMPUTER ?
Hi
Reboot your PC to apply the changes, if necessary, and prepare to relax on your couch and watch your movies on the TV.
Oct 04, 2010 | Computers & Internet
DVI output problems with Acer Veriton M464
If you are comfortable with opening the case, you can try this: Unplug the power supply, make sure are constantly grounded (touching metal)remove add-in video card. Locate the "Clear CMOS" jumper (usually 3 pins in a row with two shorted via a plastic jumper). Remove the jumper and short the other 2 pins (if originally pins 1-2 with 3 open, short 2-3 with 1 open) for a few seconds. Then replace on original pins. Plug monitor into motherboard video port and power on. If it works, you can leave as is or try to re-install your video card following the same precautions when opening the case and probably changing BIOS settings to utilize the add-on card.
Sep 12, 2009 | Acer Computers & Internet
Card not getting detected
does this card have another power source (6 or 8 pin on top of the card) that has not been connected? Also be sure that it is fully seated in the slot. if it has 2 DVI or VGA ports make sure to use the one closest to the rear of the pc.
Other than that If you removed it you maybe have shorted something, ESD (eclectic static discharge) may have shorted out a circuit or transistor on the card.
Apr 20, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
Screen not starting after installing graphics card
Hi rohit1987,
The XFX NVIDIA GeForce 8600 GT 256MB DDR3 PCI Express card uses two DVI ports on the back of the card. Display is most likely coming from the second port. Try moving your monitor cable to the next DVI port. You can do this while your system is running.
If you still do not receive display, post that here & we'll go over some other possibilities.
Good luck rohit1987!
Thank you for using fixya.
Mike
Jan 13, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
No connection to monitor
i would try the card in another mainboard, if available and watch the refresh rates. hope this is useful. and try other cards.
Nov 04, 2008 | Evga 512-P3-N862-AR GeForce 9600 GT GDDR3...
Dvi port not workink
Change monitor input on nvidia control panel and /or change the input on the onscreen display. mine uses the same thing
Dec 27, 2007 | MSI FX5200-TD128LF GeForce FX 5200, (128...
Sanyo PLV-Z2 Multimedia Projector Logo
497 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
Rod Donovan
Rod Donovan
Level 1 Expert
k24674
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
