Question about Philips 32PW6006 32" TV
Wont turn on...
My tv wont turn on from the remote...Ive tried doing it from the normal tv button on there, but all i get is a red light were the light colour shud be green..ive just got it back from the repair shop...it has happened to me b4, my cousin had done sumthing on the remote and it came right there after...any idea's?
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
As it has came right by your cousin. it means your set is ok no problem with it. problem in remote only. 1 check battary contact & battary weak. 2 foreign particals deposited on contact or loose or broken print. 3 remote defective.replce it.
Posted on Sep 18, 2007
SOURCE:
My sony tv wont turn on
There is a powerbutton on my sony TV - no amount of pressing the remote will activate the telly unless I forstpop the power button on the top. Once it has been initiated teh remotes work fine.
ALSO check the remote is working by activating a digital camera - can even be a smartphone - point the remote at the lens and you should see a flashing light on the camera screen, if not, check the batteries etc (try another remote for something you know is working to compare the result)
If all that fails, it may well be the TV that's broken.
Jan 03, 2015 | Sony Televison & Video
Tv on standby wont turn on either by remote or buttons on tv
Its not the remote but the set itself, Have it looked at and get an estimate for repair
Dec 05, 2012 | LG MKJ32022813 Remote Control
Hi ive got a teco 32 LCD television it doesnt seem to be responding to the remote and also the buttons on the the tv.on the screen it keeps saying 'Switching to DTV' and wont go off that.we have tried...
One of the things I'd try ( I can't say for sure if you can or not because you didn't provide a model number) is to disconnect the front panel buttons.
You can only do this if it leaves the infra-red still connected.
Turn the unit on with the remote.
This will eliminate a stuck front button as the cause.
If the infra-red transistor is part of the front panel board, you cannot use this method to eliminate the front panel as the possible cause.
Mar 12, 2011 | Televison & Video
How do you tune Sky+ remote into Sony KDL46W5710 Television
The Sky+ remote should automatically default to Sony TV's. Leave the batteries out for a few minutes and try again. The Code for Sony is 0000.
Or try this :-
With TV and sky box on.
Press the 'TV' button on the remote.
Hold down the 'select' and the 'red' button (of the four coloured buttons) together, until the red light on the remote blinks twice. (takes 2 seconds)
Press the 'TV' button again.
Now enter four zeros, the red light on the remote should blink twice.
Press the 'standby' button (top right).
If the TV turns off, then press 'select' and the light should blink twice again, job done.
If the TV does not turn off then press 'TV' followed by 'standby' again.
Alternate pressing 'TV' 'Standby' until the TV turns off.
When it does, finish by pressing 'Select.
Check the red light on the remote, if it blinks 3 times, then it has run out of options for 0000.
Dec 19, 2009 | Televison & Video
LG flat screen wont turn on. Ive tried unplugging from wall
The flashing light indicates the TV is in protection mode. Most likely logic board. Not sure what your model is but its usually the board that has your digital inputs in it ex HdmI etc. Post your model and you should get some one to post more info Ex ( LG XXX has a common problem with tuner board)
Oct 16, 2009 | LG 42LC2D 42 in. LCD HDTV
I have a toshiba tv with a broken power button
Generally the power button has to be on first to put the TV in standby mode. If you cant do this no remote can ever work. Remotes are not capable of turning on a set that has no power mechanically turned off. and that is what the master switch does. once that standby light is off it is not live and consuming power and not under the control of a remote anymore
please rate our help++++Y=Thanks for using FIXYA
Sep 25, 2009 | Sharp 27N-S100 27" TV
Rca Universal remote RCR311W
Try with the philips this method:
Manually turn on the tv or the device to be controlled.
Push and hold the code search button until the red lights stand.Now release the button push and release the tv button,then you got to push and release the on off button until the device turn off stop push and release the enter button.
You might need to push the on off button 1 to 150 times.
Good luck
Aug 22, 2008 | Televison & Video
Akai PT5598HDX/SMS won't turn on
Just a thaught, I could be wrong, maybe a problem with the power button on the remote ? It might shut the TV off, and when you do keep pressing the remote button, the red light on the TV will keep flashing like that also. Ive seen this prob on a few other blogs, so seems to be pretty common. I know I like to keep the remote pointed at the TV all the time, maybe try pointing it away for a while, just to see.
Dec 30, 2007 | Akai PT5598HD 55" Rear Projection...
Codes wont work on sanyo tv
Yes there is search mode, but unfortunately you have to look in the manual. I am using 3 universal remote controls (one from sony) and all of them have different procedures for entering the code or searching for the code. The idea is, once the rm is in search mode, you have to wait until the TV turns off (or no) and you have to stop the search and save the setting. If you have no manual and the code is just 2 digits, you can try the 99 codes. This may take you maybe an hour or so (better than nothing). If it has 3-digits, it's a problem.
May 31, 2007 | GE RM24970 Remote Control
Philips 32PW6006 32" TV Logo
52 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
