Question about HP Compaq 6830s Notebook PC KS014UTABA$210 instant savings (KS014UT)
SATA driver Hi, I've HP 6830s laptop and installed XP pro with IDE mode. When trying to swith back to SATA mode, bluescreen appeares and system is restarting. Tried to install ICH9-B driver, no result. Can anyone try to find another way? Thanks,
  • 432 Answers
Use nlite ( http://www.nliteos.com ) I think thats the website to slipstream the sata drivers with the xp installation disc and re install.
Posted on Apr 18, 2009
Pavillion P6000 won't recognize any drives
If you are trying to install Windows XP then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Jun 15, 2012 | HP Computers & Internet
Dear sir i'm unable to install xp on my compaq presari cq57. setup don't detect hard disk.. i'm facing blue screen error please help me..
hello,
  • Turn off the laptop.
  • Unplug from power if connected
  • Disconnect the hard disk power supply and re-connect after a while.
  • Now start the PC and run set up.
thanks!
Sep 24, 2011 | Computers & Internet
On sata HDD xp pro is not going to installed
In case of installing XP in your laptop you must make some changes to the BIOS first. This is the common issue in new laptop which are shipped with Win 7. You must change the HDD configuration from SATA to IDE or compatible mode . After that you will be able to install XP on it. OR just write back if you have any doubt.
Apr 18, 2011 | HP Compaq nx6310 Notebook
Every time i try to install windows xp on this laptop i just keep getting an error message. i was told i need to disable the AHCI, how do i go about doing this?
Installing XP on a SATA drive requires an additional step:
http://xphelpandsupport.mvps.org/how...ws_xp_on_a.htm
However, Most newer BIOS allow an Alternate method for SATA . . Go into the bios and check the "Sata Operation" setting,
change it to "Raid Autodetect/ATA if it is not already. Now try to install XP ( could be IDE Mode, Compatibility Mode or Legacy Mode - different BIOS use different terms )
some will say IDE instead of ATA)
If there are no such settings you'll need to slipstream the sata drivers on the XP CD, follow the instructions in this guide :
http://www.digitgeek.com/how-to-slip...rs-into-xp-cd/
or
http://www.howtogeek.com/howto/windo...-installation/
Or, you might consider installing Windows 7 . .
Jan 24, 2011 | HP Compaq Presario CQ61420us Notebook
Pavilion dv7 laptop driver problem BSOD
DV7 is not designed for XP, to get around the issue you may be able to change the BIOS setting for the SATA controller to work in IDE mode(depending on the BIOS) or you can use the XP installer option to install a SATA/RAID driver during the installer boot sequence. To offer you this I will need to know the model # and Serial # on the white sticker on the bottom of your laptop or the make and model of the SATA controller.
Try the Bios option and reply back with the requested info if it's not a viable option and I will see if there is an XP driver available for your controller.
Chris
May 15, 2009 | HP Pavilion dv7z Notebook
Tel me how to install xp and.sata ahci driver
try to install windows by the help of following link :-
http://support.microsoft.com/kb/316941
http://www.microsoft.com/windowsxp/using/setup/winxp/install.mspx
for sata :-
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00758841&dlc=en&lc=en&cc=us
http://techrena.blogspot.com/2009/01/download-intel-sata-ahci-drivers-for.html
May 09, 2009 | Microsoft Windows XP Home Edition
Compaq presario v3700 windows xp not instaled
You require Xp Pro that supports SATA - standard Xp is IDE - you must aquire a copy of Xp that is SATA compatible.
Jan 27, 2009 | Compaq Presario C700T Notebook
Installing XP on HP m8120n
The Blue Screen of Death (also known as a stop error, BSOD, bluescreen, or Blue Screen of Doom) is an error screen displayed by some operating systems, most notably Microsoft Windows, after encountering a critical system error which can cause the system to shut down, to prevent damage.
Bluescreens on NT-based Windows systems can be caused by poorly written device drivers or malfunctioning hardware. In the Win9x era, incompatible DLLs or bugs in the kernel of the operating system could also cause bluescreens.
Bluescreens can also be caused by physical faults such as faulty memory, power supply issues, overheating of components, or hardware running beyond its specification limits. Bluescreens have been present in all Windows-based operating systems since Windows 3.1; earlier, OS/2 and MS-DOS suffered the Black Screen of Death, and early builds of Windows Vista displayed the Red Screen of Death after a boot loader error.
I hope it helps!!!
Dec 04, 2008 | MSI K8MM-V Motherboard
Hp530 software from vista to xp
hi there,
it seems that this particular message can be related to problems with drivers being loaded. so i guest is u are using a xp cd with SP1 try a copy of XP Pro SP2 included .... also check out the ram on your system... ddat could be a bit of a problem also....and last ... in Bios change hdd from AHCI to IDE mode ... xp has a bit of a trouble seeing sata drive
Apr 08, 2008 | HP Pavilion dv6000z Notebook
ACER Aspire 5720
Hi All,
We are a workshop in Spain & I have had several problems with "Down grading" to XP. There is essentially one problem which causes an issue with the XP installation & that is if the the BIOS has a "Fixed" sata configuration. By that I mean you cannot change it to some sort of IDE or P-ATA (Symantics). Our current problems are with an Acer 5720 & an HP Pavilion DV9700. The Acer solution is exactly as "kraken3000" had mentioned before:
1. On POST (Powerup). enter BIOS by pressing F2
2. Tab along to the second option "Main"
3. Goto last option "SATA mode" & press enter.
4. From the small selection display select "IDE mode"
5. Save & exit the BIOS. This will then set the SATA mode for XP to be recognise.
DONOT set this back to SATA Mode after you install the XP as it will NOT boot. This setting must be kept untill you "Upgrade" (If ever) to Vista. The HP is another story...
Visit the Acer Panam site & download & install the XP drivers & your good to go...
I hope that this was of help...& good luck folks
Nov 23, 2007 | Computers & Internet
HP Compaq 6830s Notebook PC KS014UTABA$210 instant savings (KS014UT) Logo
237 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
