Question about XO Vision XOD1742BT Car DVD Player
DUAL XDVD9101 PARKING BRAKE BYPASS
WHAT CAN I DO TO BY PASS THIS WIRE?
  • 15,935 Answers
STEP ONE. Ground the E-Brake wire.
No matter which method you use, you must ground the brake detection wire. I suggest you tap it into the ground wire on your wiring harness (ensures a good ground).
FACTORY RESET METHOD (not permanent)
1 Go to the Menu
2 Get to the Settings Menu
3 Select <yes> to Reset to Factory Settings.
Have recently heard complaints of this method not being permanent, as this is needed whenever they want to watch a DVD. Also, radio and screen angle presets are lost.
METHOD 2
AUDIO CD METHOD (Permanent)
1 Insert Audio CD
2 Press PLAY
3 Press STOP twice on remote
4 Enter 26604 on remote
5 Press ENTER
6 Take out Audio CD and Insert a DVD
METHOD 3
DVD METHOD (Permanent)
** Insert a DVD
** Let it play until you hear sound
** Press STOP twice on remote
** Enter 26604
** Press ENTER
The blue warning screen should immediately go away after pressing the last digit of "26604." Still press ENTER as a precaution.
The 3rd method seems to work with most of the duals
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 18, 2009
    Problem Solver:
  • 5 Answers
The 9101 is built were it cant be bypassed
Posted on Sep 04, 2009
I used a toggle switch for my panasonic. This should work for all.
Use a toggle switch. 1 to power, 2 to signal wire or wire that is suppposed to be connected to the e-brake, 3 to ground to chassis.
When you turn on the deck, turn the toggle switch to on position for 2 secconds. Then turn off. That should work.
Posted on Dec 31, 2009
  • Dannyreds06 Feb 04, 2011
    That option works the best
Use a toggle switch to break and complete the cerkit three times works great with a ground and the blue and yellow wire works like a champ thank u
Posted on Feb 04, 2011
White and brown
Posted on Oct 14, 2010
It didnt work on my 9101 any more suggestions
Posted on Jun 20, 2009
I just bought a dual xdvd9101 indash dvd player and cant get the brake bypass to work
However, some units use different methods. Some require seeing a pulse (i.e., power-ground-power-ground-etc.), resulting in the annoying need of pushing the e-brake a few times before your video will pop up. This can generally be recreated by using a 3-prong switch (you can get one at AutoZone). Connect it backwards -- the ground to power, power to ground, and the "Load" to the Parking Brake wire on the back of the radio. Flip the switch back and forth a few times and sometimes the video will pop up.
Some fancier units cannot be cheated. They use an internal gyro mechanism that detects movement.
Some even feature bypass codes. By pressing a certain combination of buttons on the remote then entering in a code it will permanently allow video.
Be good.
Dual DVD
Play Dvd for few seconds until you hear sound
Press Stop Twice
Then enter on remote 26604 the press enter
Nov 15, 2009 | Car Audio & Video
How to by pass the e brake wire
at this time there isn't a code bypass for this model. the easiest thing to do so that you can play video while in motion. is to put a toggle switch on the parking brake wire of the dual screen. then do the ebrake pattern on the switch instead of the ebrake in the car
1. disconnect the parking brake wire of the dual from ur ebrake wire in your car.
2. take your 2 wire toggle switch and connect one wire to Ground(metal)
3. take the other wire and connect it to the parking brake wire of the dual screen.
if i remember correctly, the pattern for the dual screens is.
1. starting in the off position.
2. on for 2 secs
3. off for 2 secs.
4. then on .. the the video will show.
hope this helps
Oct 04, 2009 | Dual XDVD8181 Car Video Player
Parking brake bypass
the 9101 was built so you can not bypass it
Aug 01, 2009 | XO Vision XOD1742BT Car DVD Player
Parking brake safety bypass
here is what you need to do is, get a toggle switch and hook one side to a ground and the other side to the parking brake wire on the unit.
use the switch as a brake because you have to set brake for a few seconds then release and set again but keep it on this time.
you will have to do this every time you start the car.
Jun 26, 2009 | Dual Electronics XDVDN8190 GPS Receiver
Dont know how to bypass e brake on a dual xdvd9101
you need to buy a switch that u can use to bypass the brake. you have to run it to the wire that you are suppose to run to the brake and you will have to switch the off and on button and then your tv will work without the brake.. i had to do it to my same exact TV..
May 15, 2009 | Dual Car Audio & Video
I need help to bypass the brake with my Dual XDVD9101
did you try connecting the bypass wire to the ground wire?
Apr 22, 2009 | Car Audio & Video
Isn't there a way to bypass the parking brake so my video plays anytime i want how to bypass parking brake(not hooked up in a car) DUAL XDVD9101
it is illegal to do that you know but simply removing the sensor wire or attaching sensor wire to ground.
Apr 13, 2009 | Car Audio & Video
Parking brake bypass code on a Dual XDVD9101 head unit
there should be a wire that connects to your e-brake swith, located near the e-brake all you have to do is connect this wire straight to earth and you should be able watch movies all the time,
hope this helps you
Mar 13, 2009 | Car Audio & Video
How do i by pass the parking brake no video
Well on the eclipse unit you just ground the wire for the parking brake
Jan 09, 2009 | Dual XDVD8181 Car Video Player
Bypass e-brake wire
Normally, to by-pass, you need to ground the yellow/blue wire of the Dual XDVD 8183. This would simulate the condition where the vehicle is in “Park” and the parking brake is engaged thus allowing the unit to operate even if the vehicle in reality is not in “Park” and/or the parking brake is not engaged. Some regions have restrictions on this condition.
Additionally, some versions would require a SPDT switch moving the yellow/blue wire from 12V+ to GND to be bypassed.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information. A friendly reminder pls, "Drive Safe".
Good luck and Kind regards.
Jan 07, 2008 | Car Audio & Video
XO Vision XOD1742BT Car DVD Player Logo
8,565 people viewed this question
Top XO Vision Car Audio & Video Experts
jason
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
