Question about Nokia 6600
No Signal, No Network, No Display
My daughter dropped her Nokia 6600 while sidestanding her bike. Problem 1: No SIGNAL, NO Network (Auto or Manual); Problem 2: After disassembly/exposing the inner board and making the usual checks for cracks, contacts etc., I put it back together. On powering up, NO DISPLAY, LCD backlight lits up, Nokia tone sounds (phone is booting). Just an empty white nothing. Opened it again check the small connector top right, cleaned the contacts, made sure all pins are aligned, did a low hot air on the solder joints, put it together, STILL NOTHING. Appreciate any assistance.
  • 2 more comments
  • Louie  Role
    Louie Role Sep 23, 2007
    Many thanks for responding. I did open it up again and visually checked the LCD Filter just below the topright connector. I also re-applied hot air blower jut to make sure of the solder. Unfortunately, no joy.
    Any other idea(s) pls?
  • Louie  Role
    Louie Role Oct 02, 2007
    Hi again bejoy,
    Sorry took some time to get back. The phone is still not working. In any case, I bought my daughter a new phone.
    Though the problem was not solved, I appreciate your assistance.
    Please let this not discourage you in responding to other/future problems.
    Cheers.
  • jugnow Nov 23, 2007
    hi, my nokia 6600 was working great, but all of sudden it stopped geting signals, i formated it, even mmc card, but stiil the problem is there
  • ronncruz Feb 19, 2008
    got a nokia 6600 , backlight lits but no LCD display, what could be the problem, can make & receive calls
I think that the LCD is not aligned with the phone. Had the same problem when i open my phone.. Just realign the LCD and it would work..
Posted on Apr 23, 2008
Biu
Posted on Mar 11, 2010
No network in 6600 changed the network iv but gain the sme prblem.
network connection ie no network signal dispplay and unable make/receive calls
Posted on Mar 24, 2008
    Problem Solver:
  • 4 Answers
Atinaply heat on antinaswitch and pf if problem still not finish reples antinaswitch and pf also cheak the dust on conector
Posted on Mar 02, 2008
    Problem Solver:
  • 12 Answers
Since it's physical damage care has to be taken near dislay contacts.pls check the filter ( LCD FILTER ) which lies just below the connector.
Posted on Sep 22, 2007
6600 network soluition
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Jul 22, 2012 | Nokia 6600
Why I don't have network signal on my nokia 6600?
If you are not getting any network from your phone it my be be due to:* sim card issues* network / outage issues* phone issues
SIM Card issues:1. turn off mobile phone2. remove battery3. remove SIM card and memory card4. clean the SIM card from any dirt or dust5. wait for 2 minutes then plug back battery6. insert memory card and SIM card properly7. turn on mobile phone8. check if you will be provided with a signal from the upper right corner of your phone's screen. if not, try a different SIM card.
Outage:1. call your service provider and confirm if there are outages in the area or outages from the BTS where your SIM card is registered.
Phone Issues:1. if the phone is open line, try to enter a different SIM card2. try to insert the SIM card into a different phone, check if it will be provided with a signal3. if the second phone still dont get any signal and your service provider stated that there is no outage that may affect signal issues from your phone, check it from them if your sim card is still active.4. last resort is asking for a SIM replacement with the same phone number
Dec 11, 2011 | Nokia 6600
Nokia 6310i - Low and No signal
It's possible that you could fix it, but not entirely likely. It depends on whether it's just a bent antenna connector or if a circuit board is broken.
Some phones have a small spring-type piece that makes contact with the antenna. If this is merely bent, and not making a great connection, you might be able to coax it back into shape and that might fix your phone. Otherwise, it's probably beyond the ability of an amateur to repair.
Nov 06, 2009 | Nokia 6310i
Net work problem
- make sure your phone is open line, so all sim you insert can be use,
- make sure you are using your phone in the area with a network signal
- try to check with celphone technician, some nokia phones have problems with their network when its coming of age.
Aug 25, 2009 | Nokia 6600
Nokia 6600
i think there will be a problem in network ic it's better to change that
Nov 05, 2008 | Nokia 6600
No network coverage/signal problem
i had no display on my nokia 3230 cellular phone. now its ok but it has no network coverage/no signal . plz help me..... .
Sep 24, 2008 | Nokia 3230 Cellular Phone
your fon probably have a hardware failure... just visit your nearest repair shop to help you...
Oct 28, 2007 | Nokia 6600
SIGNAL BAR ON DISPLAY WAS FULL BUT CAN'T DO COMUNICATION
isn t your phone blocked at your imei? did you tried any other network?
Aug 17, 2007 | Nokia N70 Cellular Phone
Nokia 6600 Logo
801 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
Damen Wong
Damen Wong
