Question about MixSonic MX-31000 (1 GB) MP3 Player
Mixsonic MX-31024 how do i upload music to this MP3 player? i have used the sync option with Windows Media Player. you can see the songs on it when you open the player up under 'my computer' and even play the music on WMP. but it will no play independently. I have also tryed to drag and drop into the player and that wont work. The only songs that will play are the 2 songs that came on the player. thanks!
2 Suggested Answers
SOURCE:
  • 4102 Answers
SOURCE: MixSonic MX-31000 MP3 Player
are you using it through the usb lead if you are you should be able to open the file on the mp3 this should allow you to delete leave this file open but put the music you want on it in a shared file then open this file alongside the file on your mp3 this should allow you to drag and drop but try doing this with your mp3 switched off before you plug it in make sure its off and then when you plug it in it should switch itself on but dont touch the mp3 player and you should be able to drag and drop the files make sure their is enough free memoy on mp3 s some music files are massive you wont need to touch your mp3 player at all while it is plugged into your computer and it should work with no battery in it hope this helps
Posted on Oct 30, 2007
On my computer it will not let me download songs to my player
You can use the following two metheds:
  • **Drag and Drop**
Connect your MP3 player to the computer. Some MP3 players connect directly to a USB port, while others connect to a USB port by way of a specific USB connector that comes with the MP3 player. Open the folder on the computer that contains the music files you want to transfer. This is usually the "My Music" folder; available from the "Start" menu, but it can be any folder where you save your music files. Scroll down to the song you want to transfer to the MP3 player. Right-click on the title. When the options are displayed, click on "Send To." Scroll down the "Send To" options and select your MP3 player. This can be listed as your MP3 player's name or as "Removable Drive." Click on this selection. Continue this process until you have transferred all songs that you want to your MP3 player.
  • --**Windows Media Player**--
If you have a large playlist to transfer, you may prefer to do it from your media player, such as Windows Media Player. Once your MP3 player is connected to the computer, open Windows Media Player. Click on the "Sync Music" tab. Drag songs that you want from your Windows Media Library over to the "Sync Music" column to create a playlist. Click the "Begin Sync" tab at the bottom once you have all of the songs on your playlist. This action will sync all of the songs to your MP3 player with one click. Disconnect your device once songs have been transferred by clicking on the "Safely Remove Hardware" icon in the bottom-right side of the desktop tray.
Dec 06, 2009 | RCA M4204 MP3 Player
I cant get my coby mp 815 to pull up its music manager on my new computer, I pluged it in, but it just plays whats already loaded on it? whats the music manager?
If I was you I would use either Windows Media Player or Drag and Drop your files to your player. If you choose to use Windows Media Player you will have the same functions that you will have with the coby music manager. Here is the following ways to add music and files to your player if you choose the above ways to add music:
**Drag and Drop**
Oct 31, 2009 | Audio Players & Recorders
NO SONGS ARE UPLOADING TO sony nw-e003f
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the Sony's website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
OR Try This:
**Drag and Drop**
Connect your MP3 player to the computer. Some MP3 players connect directly to a USB port, while others connect to a USB port by way of a specific USB connector that comes with the MP3 player. Open the folder on the computer that contains the music files you want to transfer. This is usually the "My Music" folder, available from the "Start" menu, but it can be any folder where you save your music files. Scroll down to the song you want to transfer to the MP3 player. Right-click on the title. When the options are displayed, click on "Send To." Scroll down the "Send To" options and select your MP3 player. This can be listed as your MP3 player's name or as "Removable Drive." Click on this selection. Continue this process until you have transferred all songs that you want to your MP3 player.
Oct 01, 2009 | Sony NW-E003F MP3 Player
Cant get song from meida player to mp3 player
That's a DRM error and should be solved by the FairUse4WM which you can download for free from the following link.:
http://undrm.info/remove-DRM-protection/FairUse4WM-freeware-DRM-removal-Windows-software-Strip-copy-protection-from-WMV-ASF-WMA-Windows-Media-Player.htm
This will rip the DRM off the tracks and you should be able to sync it or listen to it without a problem.
Feb 15, 2009 | Delstar DS 31024 MP3 Player
How do i download music onto sony walkman if i dont have windows media player 11
try these methods
and any windows media player should work
**Drag and Drop**
Jan 22, 2009 | Sony Walkman NWZ-S616F MP3 Player
Philips GoGear: delete music from library & are there any Unicode
Here's the deal:
Open the Philips Device Manager that came with the install cd, and do a Repair - this will erase everything so you can start over from scratch. This will also take care of your squares issue.
No dice on the playlist issue - sorry.
Next, you have to disable the auto sync feature in Windows Media Player to prevent it from auto-loading all of those songs/files that you don't want. by opening Windows Media Player, highlighting the Sync tab, clicking on the little black arrow to bring down the drop-down menu, clicking on "Set Up Sync" (make sure your mp3 player is connected to computer, or this option will not appear), and unchecking the box that says "automatically sync files to my device". This will give you manual sync instead.
Aug 11, 2008 | Philips GoGear HDD1830 MP3 Player
HELP ME PLEASE with my "sony walkman NWZ-B105F MP3 PLAYER."
make sure your downloading it to the right folder on the mp3 player its usualy the music folder or you can try and use windows media player here are some instructions for that option.
Apr 12, 2008 | Sony Walkman NWZ-B105F MP3 Player
Music folder says no files
Check your local memory on your mp3 player. That's where the files actually loaded.
Dec 22, 2007 | MixSonic MX-31000 (1 GB) MP3 Player
Problems uploading song
Try using Windows Media Player 10 or 11 to put music on instead of the samsung media studio.
Connect your MP3 player then go into Windows Media Player, if you haven't got the latest Media Player download here - CLICK HERE
Once you've installed it connect your mp3 player then open Windows Media Player up then click on the link called "Sync", now your on there it should show your device in the top right of the screen, now all you need to do is drag and drop music you want on your mp3 play where it says "Drag items here", once you've finished choosing songs to put on just click "Start Sync", that's it.
And for future reference you can format using Windows Media Player as well.
Good luck. Hope my solution was helpful in some way.
Nov 27, 2007 | Samsung Yepp YP-T9 Digital Media Player
Oct 30, 2007 | MixSonic MX-31000 (1 GB) MP3 Player
MixSonic MX-31000 (1 GB) MP3 Player Logo
46 people viewed this question
Top MixSonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a MixSonic Audio Player and Recorder Expert? Answer questions, earn points and help others
