Question about Singer Sewing Machines
Singer sewing machine 7422
thread is not catching,,
it seems that the needle is hitting the bottom and not catching the thread
  • cwarfield42 May 20, 2009
    Same problem, also the tension is horrible. The machine is threaded properly as well... Ugh. >.<
  • Diane
    Diane Mar 20, 2014
    Just took mine apart and was watching the threaded needle enter the empty bobbin case. I noticed it was catching and when I took my bobbin case out it had a break where the needle must have struck it. I don't know if this is the cause or a result of the problem but I obviously have to replace it. I'll post again if it fixes the issue.
Not paying for this
Posted on Apr 19, 2009
Bottom thread not catching with top thread
The first thing you need to do is change needles, then check to make sure that the end of the needle is all the way up in the needle clamp, with the flat part against the BACK of the machine. The needle you're using may be bent or inserted too low, and that will cause the upper thread from not being able to catch the bottom thread.
If you do that and it still doesn't catch, your timing is off and will need to be corrected by a technician; however, it does not have to be an authorized Singer technician; it's a very common adjustment that any technician can do. I believe Sears services all machines. The most common reason for the timing to go off is by turning the hand wheel repeatedly away from you. ALWAYS turn it towards you, and ALWAYS thread your machine with the presser foot UP.
Jul 12, 2014 | Singer Advance 7422 Electronic Sewing...
Singer advance 7422 bobbin jumps
Did you get it fixed? Here is a video that may help.
Mar 20, 2014 | Singer Advance 7422 Electronic Sewing...
Singer model 7442 bobbin thread will not catch
have you tried changing the needle?
is the needle in backwards?
is the needle inserted all the way into the needle holder?
clean under needle plate & in the bobbin area for lint or loose thread
did you hit something with the needle?
Mar 03, 2012 | Singer 7422
Threading
could be the timing. check your needle first. Use a new needle and see if that helps. Make sure it is installed with flat side in proper place. Make sure it is correct length.
May 31, 2010 | Singer 7422
Singer Sewing Machine 7422: I cannot catch the thread bobbin, would appreciate anyone's advice, thank you.
do u check needle firest? try to rplace with new one.
chack if timing is ok between needle bar and hook is ok or no when needle bar is in dead lowest position
best regards
Aug 17, 2009 | Singer Sewing Machines
Singer advance 7422
My Singer 7422 seems to be jammed. When I start to make a stitch, the thread from the needle gets caught on something on the bottom and the thread goes over the bobbin.
Jul 16, 2008 | Singer 7442 Mechanical Sewing Machine
Bobbin case turns in its place
You need to remove the needle plate and take out the bobbin case. Examine it for any rough spots, scratches or burrs. When you find them, you will need to remove them with an emery stick and then buff it with very fine steel wool. Reinstall the bobbin case and the needle plate. Put the bobbin in the machine so that it turns counter clockwise when you pull the thread. Rethread the top of the machine and change the needle. Hold the needle thread , turn the handwheel and see if the bobbin thread is picked up without snagging anyplace. If it's okay, sew away.
sewman7
Jul 14, 2008 | Singer 7422
Singer 7422
Make sure you have the machine threaded for the bobbin and not threaded through the sewing path. Also, check to make sure that the bobbin is pushed directly against the post as far as possible.
Apr 13, 2008 | Singer 7422
Sewing Machines Logo
138 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
