Question about Cameras
Out door High speed dome cam
My problem is duw moistore it is getting water in to the dome what shall i do to solve the problem even though their is a heater and cooling fan in side
  • sumanth_cms Sep 18, 2007
    ok thank u
    i will tell my boy to do it
    comming to the place it is at
    INDIA
    Andhra Pradesh
    RAjamendry
    which is adjacent to the paper manufCTURING MILL
  • sumanth_cms Feb 25, 2008
    hi this is sumanth
    thank you for providing the valuble solution for the above problem
    now for the same camera another problem is showing
    the same camera now it is showing the display as
    FOCUS MOTOR ERROR PLEASE CHECK THE CAMERA
    please send me the solution and why it is showing error
    Sergeant:
  • 274 Answers
You have a "air leak" somewhere in the assembly most likely where the dome attaches to the housing. Even where the cables come out of the assembly. Very carefully look at all the seals and make sure they are "seated" properly. One may be slightly damaged. Be aware in some environments you can not get rid all the moisture inside the dome especially in high humidity areas. I don't know where it is you live or where this is mounted so I can't address that. Check and make sure the "heater" is coming on. The fan will just blow air around. You might try placing a small silica moisture bags anywhere inside where it might fit. Those you can reuse by drying in a very low heat oven for a few minutes also. It'll tell you on the package. Do that at least until the moisture goes away. When you open the camera you need to be in a "dry" as possible room or area.
Posted on Sep 18, 2007
  • Jerry Hess Sep 18, 2007
    You have very high humidity due to the weather. Plus you have moisture coming from the paper processing, right? That will make it even harder, but let's try what I suggested first.
    If that doesn't work then try the next thing.
    I have another solution but I'm not sure you can get what I'm thinking in India. Can you get small cans or 7lb bottles of "dry air" (Dry Nitrogen)? If you can, attach a hose and blow a steady stream of air over the camera assembly while you secure the dome in place. Freon, CO2, or electronic dust off does not work because they have moisture in them. "Dust off" may work if you don't spray at a fast rate. It's cold and causes condensation when it comes out.
    Genius:
  • 2,985 Answers
Silica gel bags if you can find then. or a cloth bag of rice or salt these absorb moisture
SOURCE:
GE GFWN1100LWW. Can the high speed spin work on the lower wash cycles?
From my experience, the lower wash cycles are set to only do certain things. For example: the Delicate won't do a high speed spin, even though a high speed spin wouldn't really be destructive to delicates, but would force more water out of them! I usually just run a "Drain/Spin" after the Delicate cycle.
Nov 27, 2015 | GE Washing Machines
Radio, dome light and door open warning bell doesn't work
try changing fuses any way somtimes there dirty or coroted and dont make good contact even though they test good and look good still could be the problem
Mar 02, 2012 | 1997 Dodge Neon
2000 F250 dome light will not go out ,even with door cosed. had to pull fuse.
THE SWITCH FOR THE DOME LAMP IS ON THE DOOR LATCH, INSIDE THE DOOR ITSELF, I AM NOT SURE IF YOU NEED TO REPLACE THE SWITCH ONLY OR THE WHOLE DOOR LOCK, CALL FORD DEALERSHIP PARTS DEPARTMENT FOR CORRECT INFORMATION.
Oct 21, 2011 | 2000 Ford F250 Super Duty Crew Cabs
I have 92 Ford Tempo. My Dome light doesn't want to turn off even though the door is closed and everything is turned off. Any ideas what i can do.
spray wd-40 in the door/hatch latches and close and open doors a few times, it should unstick the door switch that controls the dome light
Jul 27, 2011 | Car Audio & Video
No water is going into dishwasher duting cycles. there is water going to the unit though
open the door, in the dishwasher, left front corner there is a white dome. Light grey if ss tub. Remove the dome, 1/4 drive screw holds it down. under that is a float. Make sure it's moving freely. if you lift it you should here a faint click. thats the flood switch. try the water again to see if it fills.
Mar 25, 2011 | GE GLD4450NCS Dishwasher
Brake juddring
Dear sir
if barke juddring is in high speed then replace fr both brake disc and pad or if don't have that much budget then get fr both disc scamming dome form any lade work shop.problem will solved thanks.
Sep 14, 2010 | 2006 Honda Accord
Dome lights won't turn off
Been having a problem with the dome lights on a 99 chevy blazer. Still can't figure out what the problem is. There is a dome light overide button located under the dimmer wheel. When I push the overide button in the dome light goes off, but when I open any of the doors the dome light will not come on. When the overide button is out the dome light stays on all the time and will not turn off even though every door is closed. I checked all the pushbuttons and everything tests good. Has anyone had this problem and know how to fix it?
Sep 04, 2009 | 1997 Chevrolet Blazer
How to increase top speed
High performance spark plugs..
High performance * individual * air filters - K&N is the best..
Octane bost..
Tune up,, jeted & synced carbs..
Racing cam..
Shall I go on ?
Hope this helps !!
Please rate me good ;o)
Jul 12, 2009 | Bajaj Pulsar 180 Motorcycles
Cameras Logo
75 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
