Question about Solis Crema SL-70 Espresso Machine
Coffee barely drips out. I cleaned everything. Do I need a new portafilter basket? The unit is only 6 months old.
How about with the basket and portafilter in place, but no coffee in the basket? Does the water flow reasonably when you turn on the pump?
Posted on Apr 28, 2009
  • kyrrian Apr 28, 2009
    I meant to leave that as a comment, not a solution yet. Sorry...
Few days ago, the brewing light on my Aroma Seaco coffee machine does not turn on anymore. I could still make coffee but I noticed that the water took a longer time than usual to warm up. Yesterday, I had...
Clean the porta filter mesh by sm all pin.if you have pressurise filter basket then you have open it.because pressureise filter basket contain 2nos mesh .one mesh is multihole and another is single hole .you have clean both.
Jan 28, 2015 | Aroma Coffee Makers & Espresso Machines
Coffee squirts/sprays out of the machine rather than gently flowing or dripping into the cup. The machine is brand new.
Fit the small black Crema enhancer between the filter basket and portafilter, or buy a non pressurised filter basket - lots of holes...
Jan 17, 2011 | Gaggia Baby Espresso Machine
I am using my new silvia with the ese pod adapter with illy pods. When I press the coffee dispense button with a pod in place, coffee begins to come out of the right orifice, then after a few seconds it...
"leaks noisily from what appears to be the contact between the grouphead and portafilter"
* Leaks from top of portafilter and group head are caused by poor sealing at head gasket.
* wipe top lip of portafilter before inserting into group.
* check if group is clear of coffee grounds, paper bits, tissue, dry crud. Use a head cleaning brush (tooth brush works) and wipe group clean (do not use screwdriver to scrape!)
* Make sure when inserting portafilter it is seated properly. (check your manual for procedure) Note the position of the portafilter handle if it's in the right position AFTER you tighten it. Is it far to the left? or stuck and barely hangs on to group?
* Barely hanging on to group? Check if pod is too big. Note; you can't double shot or use 2 pods in a single pod basket! Make two separate shots for a double.
* Handle tightens but slips off group or still leaks when pulling shot? Worn out or missing gasket. Gaskets are made of rubber and can crack, drop out, or pit. You will need to have the gasket replaced. Check with vendor or MFR for service/parts.
* Make sure you have the correct portafilter. Many look the same and may even fit but when making fine adjustments or critical shots they don't work right. Check manual or vendor for confirmation.
* Make sure you have the correct basket. The portafilters may have different baskets or cups that can be inserted. Many have special uses that can affect the pull of a shot. Fewer holes causes slower flow and longer brew time. Many holes gives a weaker shot but smoother less bitter taste. There is a blank basket that has no holes which is used for backflushing and cleaning of the group. Check your manual or vendor for which basket you should be using. Odds are that you have a standard basket ment for ground coffee and not pods. (you can remove the coffee from the pod but it will be messy.) Ask for the optional 'POD' basket insert.
* Finally if everything checks out and your still having leaks then your machine needs service as the group head or valve needs replacement. Call your vendor or MFR direct.
Aloha! ukeboy57 (youtube)
P.S. Looking back at my service with pod conversions, I've found that most if not all pro-machines don't really like the pod adapters. Sure it will work but shots are weak and poor. Pods really like a very tight fit with a very small portafilter basket(chamber) I mean like the size of a soup spoon! They like very slow and very hot water pumped with a vibration type pump to extract all the essence from the paper filtered coffee. Illy is an excellent coffee pod with a very rich aroma and good creme. The best for them (pods) are the dedicated pod machines (won't do ground coffee, only pods). If you must use a pro semi-automatic machine then I would suggest adding a port constrictor to the portafilter output. There may be a third party supplier that has a compatible adapter for your brand. I've come across some of these very extreme tools for the elites coffee affectionato. It restricts the flow at the output thus causing the hot water to brew longer and at a higher pressure to force the hot water and steam into each coffee grain. (think pressure cooker) Some of the better ones are adjustable. But note that these will need daily or cleaning after each use as these restrictors have very tiny holes which clog unless flushed after each use. Good luck 9on your pursuit of the perfect cup!)
Jan 17, 2018 | Rancilio Silvia Espresso Machine
We have a new coffee house with new machines. Our rancilio sometimes has water coming out all around the basket when trying to pull a shot. What is causing this?
You need to change the group head gasket. They only last about 1 year and then should be changed. Get 2 because they usually fail on Friday and you have a party on Saturday.
The gaskets get hard from the heat and don’t form to the filter any more so they leak.
When you get the new gasket.
Empty everything out of the machine (water tank, drip tray, etc.) Turn the machine upside down on a towel. This way you can see what your are doing.
Remove the filter screen and diffuser from the brew head. The black O-ring is your gasket. Carefully pry it out. Clean the opening good before you install the new gasket. Insert the gasket with the beveled side down (on the inside edge of the O-ring is the bevel). Once you have the gasket in place, use the portafilter to finish seating the gasket.
Sep 04, 2010 | Rancilio Silvia Espresso Machine
I have a Mr. Coffee ECMP50. After about 8 months of daily use, it has gone bad. It started spurting coffee at the edge of the basket instead of dripping it through the two holes in the bottom of the...
I would guess that you normally keep the portafilter in the machine? If so, this compresses the gasket and leads to premature over compression and leakage. Unless you can order a new gasket, your out of luck.
I've learned a ton on this unit reading reviews. I discovered that this issue and failure to descale will kill a good machine faster than anything.
Aug 13, 2010 | Coffee Makers & Espresso Machines
Coffee sprays from portafilter spouts while pulling shot
Either the group gasket is dirty or damaged. Also check the basket for damage.
Jul 21, 2010 | Gaggia Classic Espresso Machine
Frothing works perfect....water is extracted just fine. BUT when I put coffee in the basket and tamp it down and put it in the machine it just makes noise like it is about to drip and nothing comes out,...
I have a brand new Via that never worked right out of the box. Could barely get any espresso to come through the portafilter. Got a new portafilter and the espresso now flies out of the machine beautifully. Seems they are shipping2_bing.gif units with faulty portafilter. Bad news is a new portafilter is like $65. See if you can get them to give you a new one. I had the same issue as you, very little espessso comes out.
Dec 29, 2009 | Saeco VIA Venezia
Broken portafilter!
I had a brand new Via Venezia that I could barely get to make espesso, nothing or very little came out. Got a new portafilter and now it work beautifully, espesso flies out of the thing wonderfully. Bad news is a new portafilter is like $65. I can't believe they are shipping these with bad portafilters, but they are.
Dec 18, 2009 | Saeco VIA Venezia
Francis francis x5-espresso splatters all over
1) The coffee you are using may not be ground finely enough to provide a proper extraction time, resulting in water rushing through the ground coffee much too quickly. Think of it like water running through a handful of pebbles as opposed to a handful of sand. You want "sandier" coffee.
2) Your gasket (the rubber part that seals the portafilter to the group head) may be worn/damaged and is leaking water when you are brewing. Attempt to contact FF! or Saeco to secure a replacement gasket. When you are not using the machine, don't tighten the portafilter all the way in to the head, either leave it completely disengaged or only loosely attached. This saves wear on the gasket.
3) Your brew water may be too hot. Purge your boiler right before brewing by running water into a bowl without the portafilter locked in. After a few seconds the superheated water will be run out and you're ready to brew.
Mar 13, 2009 | FrancisFrancis! X5 Espresso Machine
Solis Crema SL-70 Espresso Machine Logo
153 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
