Question about Tricity Bendix AW1400W Front Load Washer
Machine stopped mid cycle - door light illuminated
My Tricity Bendix AW1400W appears to have stopped during the wash cycle with the "door" light illuminated - no other lights showing. I have removed the door lock/combined switch, dismantled and replaced it. The door light now doesn't stay on but after what seems like a normal display of lights the "end" light comes on followed by a series of beeps. Could this still be a door catch/switch problem?
  • Adrian_Bru Sep 23, 2007
    Thanks for the advice - I replaced the door switch and cleaned out the outlet and hey presto everything works as normal.
    Many thanks for this invaluable service
    Adrian
  • Anonymous Mar 19, 2014
    door sensor dos,nt seem to work
  • 209 Answers
This appears to me that you have had one problem and created another, based on what you say i guess the original fault was the pump or a blockage in the outlet system, now you have dismantled the door catch and made that a fault, if possible replace the door catch with one that is known to work, then retest to get back to original fault its a bit like "my telly doesn't wok it must be the on off switch" there's much more than the switch to anything, hope i have helped, if so rate me please
Posted on Sep 18, 2007
SOURCE:
Tricity Bendix AW1400W Loud noise when spinning
The turning tube's belt or bearing may have problem.
If you know how to tighting the drive belt, you may try.
If not, maintenance or service persone should to call.
May 28, 2017 | Tricity Bendix Washing Machines
My bendix washing machine door does not open after wash cycle ha finished
  1. Is there still water in the machine when the wash cycle has finished? If so, the door doesn't open because there is still water in the machine. Try clearing the filter at the bottom of the machine, in the front. If this doesn't work, check that the drain hoses are cleared. If it still doesn't work, try replacing the drain pump.
  2. Is the "door" light still on? You may have a faulty door lock assembly, or your control board may be faulty.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 27, 2011 | Tricity Bendix AW1400W Front Load Washer
Trying to organise changing brushes in Tricity Bendix AW 1400. I'm in Scotland, daughter and machine in England! Does top or back come off machine to allow access and is motor fairly accessible for...
Washing machine motors are usually induction motors and do not have brushes? Anyway, the back comes off and that normally gives access to the screws that hold the top on, but the motor is normally located at the bottom of the machine.
Feb 14, 2011 | Tricity Bendix AW1400W Front Load Washer
Washer stoped working wont fill up wont spin it bleeped a few times now wont go on a cycle
The door catch (interlock switch) is the usual suspect for that fault. If it can't detect the door is shut it does not fill.
Dec 05, 2010 | Tricity Bendix AW1400W Front Load Washer
Leaking during spin from underneath the machine
Check for a hole /rip in the door boot seal. Also could be pump or drum in extreme case...
Jun 19, 2010 | Tricity Bendix AW1400W Front Load Washer
Machine will fill and turn slowly but will not
Check motor capacitor first.Try moving the drum and see there is no extra friction. If your washer has got braking mechanism check the brakes also. ( I have no idea about this model regarding break)
Mar 30, 2010 | Tricity Bendix AW1400W Front Load Washer
Washing not being spun properly or machine emptying fully
If it has a filter, remove and clean, check for blockage and or obstuction in drain hose
Dec 12, 2008 | Tricity Bendix AW1400W Front Load Washer
Tricity bendix aw1400w will not spin
We had a similar problem, where it washed okay but didn't spin and just 'beeped' with end light flashing. When the drum was empty it was not moving round very freely.
Try unplugging the machine from the electricity. Then take top off machine off so you can see the casing outside the drum. There's a small rubber tube on top. If you disconnect that you can look through into the drum. Try turning the drum round slowly while looking through the hole. We found a sock wedged in which we managed to pull out through the hole (not easy and don't expect the sock to come out in one piece).
It worked - and we've had to repeat the procedure a couple of times now. Think I must be putting too much in the machine in 1 go, although there's always space at the top.
Jan 22, 2008 | Tricity Bendix AW1400W Front Load Washer
Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Aug 26, 2007 | Tricity Bendix AW1400W Front Load Washer
My tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Dec 14, 2006 | Tricity Bendix AW1400W Front Load Washer
Tricity Bendix AW1400W Front Load Washer Logo
307 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Bobby G
Bobby G
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
