Need proper interface to jack for internet access from port
My phone jack and port on old umax model 333t dont match. I need to go online with either modem interface or just the proper cable.
  • 70 Answers
What you need is acat 5 internet cable isalittle bit bigger than aregulare phone plug
Posted on Aug 05, 2009
I cannot set up my answering machine on this model. Why
Hello Glenys Fisher,
No mind readers here...
(include MAKE & MODEL... pretty please).
ELSE... you get GENERIC answers
No idea if you are talking about Plain Old Telephone Service
(POTS)... or digital interface...
Even if "digital" f it has a RJ11 (phone jack)
should run an old style (central office powered phone
(the kind you want/need in an EMERGENCY)).
Only the center two wires (tip & ring (typically Green & Red))
are required. Key is always... Red = Right = RING.
If you are buying Off-The-Shelf (two wire) RJ11
phone cords the plugs are already properly oriented.
Line comes from the phone company (plugs directly
into answering machine)... Tel jack can go to a telephone
OR NOT.
All wiring is in PARALLEL.
If ANY phone is OFF-HOOK (in use) the recorder
will not work.
Is this helping...??
Carnac the Magnificent
Oct 18, 2017 | Lands Phones
Magicjack doesn't always work right sometimes the phone works , sometimes I get an error 3002 message when I try to call out.
Actiontech what, they many vast models, and routers, and mix.
what are you exact connections here>
NO PC stated, HP model number, this is HP forum. so.....what?
no OS stated, opr. system , windows WHAT?
No modem models stated.
No ISP service stated,
what ISP, what service,? DSL> must I GUESS that?
My guess is not DSL no land line but it is possible to buy DSL
with Landline, disabled, I did for years.
or cable modem, ? uses COAX ! not 2wire twisted like DSL.
or are you doing the MAGIC jack , with NO COMPUTER owned
yes?
The magic jack does not plugin to any modem ethernet port
ever. its usb.
t
Broadband, high-speed internet, cable internet, DSL - WiFi, Fios fiber. and more , dial up? nah you dont have LAND LINE./
error codes,. the first page in the manual states !
Contact your Internet service provider to verify your modem allows more than one device to access the Internet if you receive error 3002 when trying to use MagicJack Plus. Some modems and modem/routers-in-one may not be compatible for use with MagicJack Plus if multiple devices are connected to your network.
We dont know what ISP you have nor the connection type
cable tv modem, DSL, FIOS what?
nor the modem you have , you never said,
this is far more complex
its not magic at all,
fire walls set wrong
ISP blocks you, at your mixed, router and modem
using the routers, USB port is a FAIL.
if you want great help answer what you have and what is connected
in details.
the MAGIC jack as 3 ways to connect,
USB or ethernet.?
Jun 11, 2017 | HP Computers & Internet
I had 1 modem and router with 4 pc and shared the internet connection. but now i need to add another broadband router so that i can use the internet. how can use another router and share the internet...
  • 1Unplug one of the network connections from your old router.
    Ads by Google
    '; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
    ' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+5860073694+9911500640+7416705818+8388126455+8941458308+6876289738+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //-->
  • 2Use this open port to connect the old router to the new routers WAN(wide area network) port. If your old router has an uplink port, use this instead of the last LAN(local area network) port and keep the last LAN port open.
  • 3Connect the computers to the ports on the new router.
  • 4Configure the new router settings to match the old router settings.
  • 5Use IPConfig to check you current IP address
  • 6Use this information to create a static IP on the computers connected to your network.
  • 7Set the Default Gateway to the IP address of the router in which the computer connects.
  • 8Check that all computers can access the internet and "see" each other on the network.
  • Oct 24, 2010 | Computers & Internet
    I want to connect my computer through the RS232 port on the amp to display image on TV. How do i tune in to the TV from the amp? Roger
    The RS232 Port on the back of the computer is not designed to send display signals to a television, this is called a "serial port"
    In order to display video on a television, you need a video card that supports the proper video-out format for your television. Older TV's use either a Coax (usualt a screw-type connector onthe back of the TV), an RCA jack (usually a slip on type connect and usually yellow) or an S-Video connector (black connector with multiple pins, line an old keyboard) - newer televisions use an HDMI interface and provide much greater resolutions.
    Check the television to determine what type of connection you can use, then search online for a video card with a TV-OUT that matches.
    Another option would be to allow a company like "geek squad" to install the proper card for you. Any local computer store can easily handle this task as well if you're not comfortable opening up your own computer.
    Jan 22, 2010 | Computers & Internet
    No screen
    pleas check your laptop ram.and pleas vot for me
    Aug 01, 2009 | Umax ActionBook 333T Notebook
    Wireless Internet Connection Being Blocked
    Do they have there security setup to match your netopia? If your not sure surf to the modems interface 192.168.1.254 go to expert mode and make sure the wireless settings match the settings (wep,wpa, 128 bit or 64 bit,open, shared key, etc..)on the laptop if not change them in the laptop
    Nov 15, 2008 | Netopia (3347NWG-ENT) Router (3347NWGENT)
    UMAX parallel port Driver
    Dear
    The UMAX US website claims that there is no driver available for this device or requires you to purchase a driver CD. (I have the 1220P model myself) However, this driver is freely available from the UMAX Germany site. Just go through the menus and download the parallel port driver version 3.55. Windows XP uses the same driver as the 2000 one. When the prompt comes up for "unsafe drivers" just click "continue anyway" and it will be installed properly.
    Linux Problems
    Oct 19, 2008 | Computers & Internet
    Adaptor
    Hey,
    Have a look is this the power adapter,
    CLICK HERE EBAY PRODUCT
    Aug 29, 2008 | Umax ActionBook 333T Notebook
    UMAX 2100U problem...
    Try a different USB port. Check if the cable works with other systems. Have you installed drivers for the USB ports?
    S. Mohan
    Mar 09, 2008 | Office Equipment & Supplies
    LCD Display keeps flashing "INITIALIZING"
    It needs to be plugged into a properly configured Avaya Definity digital port / wall jack. (NOT a regular telephone line as this can damage the polycom!!!) Does another Avaya digital phone work in that jack? If it does then call polycom for a RMA and eturn the phone under warrenty. If another Avaya digital phone does also does not work you need to check the PBX configuration or there is a wiring error at the jack or the PBX.
    Jul 10, 2007 | Polycom SOUNDSTATION2 AVAYA 2490...
    Computers & Internet Logo
    24 people viewed this question
    David Payne
    David Payne
