Question about JVC AV-48WP30 48" Rear Projection Television
Red horizontal lines
We have a JVC AV48WP30 and when we turned it on yesterday there were red lines that seemed to start on the left and look as if they were bing "pulled" across the screen to the right (looking at the tv) side. We bought this used so I don't have a manual. Please help. Also seems to have red ghosts now.
  • michmike Apr 19, 2009
    Do you have an estimate on replacement cost, the TV repairman told me $170 X 3 (for each color)
  • 10,594 Answers
Misaligned red lines in your TV is due to failure of Convergence Out ICs and requires replacement.
Let me know if you are familiar with TV repair to provide you part number info OR call local TV tech to fix the TV.
Thanks.
Posted on Apr 18, 2009
I CANT ADJUST THE RED VERTICAL LINES ON MY JVC REAR PROJECTION TV. i HAVE DONE CONVERGENCE AND MANUALLY ADJUSTED THE RED LINES HORIZONTALLY, BUT NO LUCK WHAT CONTROLS TO USE VERTICALLY
If it will not adjust up or down or left and right the convergence chips need to be replaced.
See attached photos of board that is in your set:
This can be a do it yourself repair and the parts do not cost a fortune.
Can I help?
SD TECH
Oct 16, 2011 | JVC AV-48WP30 48" Rear Projection...
Double faces with red 'halo' around people...after TV 'popped' and went off then back on.
Replace the convergence ICs and resistors. You can get the JVC repair kit called the AV48WP30 - AV65wp30 convergence repair kit from www.tvrepairworld.com which contains the ICs, Resistors, and the CD with repair instructions.
May 25, 2011 | JVC AV-56WP30 56" Rear Projection...
JVC AV48WP30 Projection TV..Half picture distorted and flickering
Ur convergence is dead.Must replaced the 2 convergence ICS and all it resistors.The shop will cost U $300 for parts and parts.
Feb 10, 2010 | JVC AV-48WP30 48" Rear Projection...
I have jvc av-56wp30 all of a sudden the red in the picture is doubled. any ideas what that could be?
That sounds like a convergence failure. The AV48WP30 convergence repair kit from www.tvrepairworld.com should solve the issue. The kit contains the components and the CD with instructions.
Dec 14, 2009 | JVC AV-56WP30 56" Rear Projection...
The red tube is not acting right. When you go to convergence, the red lines are not straight. They are concave, I think is how you would describe it.
You need to install a convergence repair kit. You can get the AV48WP30 convergence repair kit at www.tvrepairworld.com the kit contains the parts and the Cd with detailed photos with instructions.
Dec 08, 2009 | JVC AV-48WP30 48" Rear Projection...
Split color red blue
THE JVC AV48WP30 convergence repair kit from www.tvrepairworld.com usually will fix that issue. The kit contains the parts and the CD with detailed instructions.
Sep 28, 2009 | JVC AV-48WP30 48" Rear Projection...
Screen is red with lines when channel is changed
If its a kp-51hw40 : go to an unused video input and look at the screen---if it is redish in the background with curved faint trace lines you have one of two things wrong; First: the red "screen" control may be set too high. Second: you may have a problem with the RED picture tube.
To try to adjust the RED screen down you have to remove the entire front grill plate on the front of the TV(some have screws on the back on either side that have to be removed---and then you should be able to pop it out. Behind it there is a masonite inspection plate held in with screws----Once you have that off look for a SMALL SQUARE BLACK PLASTIC BLOCK; it has 6 black adjustable controls---you have to use a flashlight and look carefully---one row left to right will be marked FOCUS--DON'T TOUCH THOSE---THE OTHER ROW left to right will be marked SCREEN; if you look carefully you will see marked by each r (red) g (Green) b (blue)
you want to locate the RED SCREEN CONTROL.
WITH the set still on a blank video input where you can see it clearly turn the RED Screen Control to the left until the lines and red tint go away---do this slowly and make sure you are adjusting the RED screen--not the FOCUS.
IF this has been helpful give me a vote here as I do this for free; yesterday I adjusted one of these in a home that was blue with the faint lines---about 15 minute job for me.
if you have questions or need help:
etower.766@netzero.net
Aug 23, 2009 | Sony KP-51HW40 51" Rear Projection...
Model# AV48WP30 Picture show double vision. Colors cant be adjus
you need to replace the convergence ICs and associated resistors you can get the repair kit at the following link for your model which contains the two ICs and all the feed resistors plus step by step instructions with detailed photos how to do the repair. Heres the link to the kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/av48wp30-convergence-repair-kit/cName/convergence-repair-kits
Mar 05, 2009 | JVC AV-48WP30 48" Rear Projection...
Sony 65 inch screen tv
Yes the red tube is shorted. I will post a link to the site where I work as they have an entire AV48WP30 with a bad tuner they are selling parts off of including the Tubes. they also provide free info on how to switch out the tubes as a unit which is a fairly easy job. Heres the link.
May 21, 2008 | JVC AV-48WP30 48" Rear Projection...
Vertical color lines
Here is a picture of my TV problem, the green horizontal line is from the camera flash. thanks for the help.4d2ca33.jpg
Jan 15, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
151 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
